Re:System not booting
IBM desktop 8311-63U Model
System not booting up..Blank screen. When insert the WinXP disk, this is what comes on the screen....
Any sloution for this issue?
  • 4 more comments
  • odai Mar 25, 2008
    I copied and pasye the web address you send me but I could not get connected to that site. can you send it again, this time as a link so i can click directly.
    Question: How will I be able to upgrade firmware on the HDD if the computer is not booting?
  • odai Mar 28, 2008
    Message says txtsetup.sif corrupt or missing!
    I change cables and hard drive and the system boot but the screen is black and white and there is no icons on the desktop . Neither is there any start button at the bottom to click on.
    What should I do next.
  • odai Mar 29, 2008
    I want to suggest that the hard drive is no longer any good because the system went through the firmware process but nothing happened because it says there was no device detected.
    I have reset the BIOS jumper as instructed by your expert and also taken the battery out and replace it back.
    I removed the hard drive from another system which has WinMe and was able to have it booted, the only problem now is that the desktop background is greyish black without any icons and start button. Don't know if I am experiencing any resolution setting or video card problem. What does a video card look like and where is it located.
    This set was working fine up until lately.
    I am depending on your expertise to get through this.
  • odai Mar 29, 2008
    Will appreciate also if you send me info on connection a hard drive as a slave to the other DELL system.
  • odai Apr 07, 2008
    Just a few more concerns:
    I upgraded the hard drive from my other computer from WinMe to WinXP and was successful. however the screen resolution is 640 x 480 and color quality is lowest(4bit). The slider to adjust is not working in display properities.
    In the advance tap the adapter type has no name: chip type (unavailable) DAC type (unavailable) memory size (unavailable) adapter string (unavailable) Bios information (unavailable)
    On the Monitor tab: Monitor type is default monitor, properities is greyout : screen refresh rate (greyout) and there is no color management.
    The is still nor Interner explorer icon to get to the internet..
    Need help?
  • odai Apr 12, 2008
    You never responded to my last posting on 07 Apr.
  • 101 Answers
Are you using the standard hard drive which came originally with the pc. You either need to choose S and specify a hard drive which may be a Seagate Barracuda ATA IV. Try that first. If there is still a problem you should upgrade your firmware on the hdd by running the patch which you will find on
This site will also give you additional drivers if you need them. IBM tend not to use generic drivers.
Posted on Mar 22, 2008
  • 1 more comment
  • Julie Judson
    Julie Judson Mar 25, 2008
    This is a long link so you may have to cut and paste it into your browser
  • Julie Judson
    Julie Judson Mar 28, 2008
    Let me get this straight.
    You have had trouble booting your computer and get a blank screen.
    Then you tried to reinstall your operating system.
    You got an error that windows requested additional drivers for the mass storage devices.
    Now you seem to have changed hard drives and have an error txtsetup.sif is missing or corrupt. With a blank screen. Did windows install or not.
    I need some clarification here.
    Are you trying to reinstall windows from a CD? Is it a good quality CD with no scratches?
    Are you still working on your original hard drive?
    Did you apply the firmware to your hard drive?
    Have you checked your bios as suggested by Ekse to see if the hard drive is recognised in there.
    Try running through the windows installation again. If it stops on the mass storage device item you need to run it again but press F6 at the beginning and add the drivers for your HDD.
    All this is assuming that you have nothing on your hard drive you want to keep by the way.
    It is possible that your hard drive needs changing. Has it been making a clanking noise? This indicates a failure.
    If you do have any data on the disk you may be able to recover it by adding it as a slave to another computer. If you have a computer available and you dont know how to do this I can send you some info.
  • Julie Judson
    Julie Judson Mar 29, 2008
    Here is a link which explains how to add a hard drive. You need to pay special attention to your jumper settings. They are the little tiny pieces of plastic which cover the pins on your hard drive. IDE ribbon cable connected hard drive only.
    The ME hard drive needs to be designated as master and the old one as the slave. There will be a diagram on the drive which says which pins the jumpers should be on. If you have SATA then dont worry. SATA 0 or 1 is the master SATA 2 or above is the slave. Depends on what your sata connectors on the motherboard are called. Some start at 0 some start at 1.
    Make sure you have power to all components.
    The graphics card is the 15pin holed blue connected at the rear of your pc. It may be built onto the motherboard or a separate card. Dont press too hard and crack the motherboard though.
    Your grey screen maybe due to having disabled the explorer.exe process.
    Try this, and you will be working blind so do it precisely
    Press the windows key once (has picture of flying windows on it)
    then press R
    then type explorer.exe
    press the enter/return key
  • 13,433 Answers
Hey, that a common problem if your harddrive is SATA
but first, check that your harddrive is seen by bios.
If not check cables, you can try reconnecting the cables incase seomthing isnt touching.
If hdd is seen and working
your going to need a SATA driver for your windows setup.
Il tell you more about that after you have checked the harddrive.
  • Ekse Apr 07, 2008
    tell me is your harddrive SATA or ATA
    This here is a SATA drive witch needs you to enter a disket in windows xp setup to install on such drive
    This here is a old ide drive which should work right away
    If your drive is a SATA disk then you need a disket with the Sata drivers for your motherboard
    if your drive is ide then the disk is most likely broken.
    let me know if its SATA and Il find the drivers for you and get this solved.
    PCBuilda.. is typeing alot useless information.
    This is very simple.
    If the drive is ide and not detected, jumpers and cables are ok. then the drive is broken.
    if its SATA then you need the driver diskette and il give you instructions after you confirm this.
    after you install xp you need to install the device drivers thats why your settings are as you said.
Install windows 95 from floppy
Microsoft Windows 95 employs the use of a bootable floppy disk to begin the installation of the Windows 95 operating system or to troubleshoot problems with the system. Microsoft Windows 95 uses the MS-DOS system to boot the computer first and then loads the Windows 95 operating system onto the machine. Windows 95 Boot Disks may be created in one of two ways: The Startup disk may be created from within Windows or a boot disk may be created from a free downloaded boot disk image. After the boot disk is created the disk may be used to boot the computer and install or troubleshoot Windows 95.
Click "Start" and then click "Settings" in Windows 95. Click the "Control Panel" option. Click "Add and Remove Programs." Click "Startup Disk" and then click "Create." Insert the blank floppy disk into the disk drive. Click "OK." The operating system will create the Windows 95 boot disk. Click "OK" when the disk is finished. Create the Windows 95 Boot Disk using Downloaded Boot Disk Image Open a Web browser and navigate to the boot disk image site (See "Below"). Download the Windows 95 boot disk image and save the .EXE file to the desktop. Click the .EXE file to unzip the enclosed files. The formatting application will start. Insert the blank floppy disk into the disk drive and click "OK." The Windows 95 boot image will be created on the blank floppy disk. Use the Windows 95 Boot Disk Insert the Windows 95 boot up disk into the computer's floppy disk drive. Power the computer down by clicking "Start" and then clicking "Shutdown." Power on the computer with the Windows 95 boot disk in the floppy disk drive. The computer will boot up into MS-DOS to enable installation or troubleshooting of Windows 95.
Feb 13, 2013 | Dell OptiPlex GX270 PC Desktop
I jst bought used IBM 8183 Thinkcentre every time
You will need to install Windows. If you have an install disk, insert the disk into the optical drive and restart the computer. Go into BIOS and select "Boot from CD/DVD". Follow the install instructions on screen.
Apr 12, 2011 | IBM Computers & Internet
Ibm deskstar model dtla-307015 invalid system
For some reason, the computer isn't able to read the hard drive and Windows isn't being found. If this computer has a floppy disk drive, make sure there's no disk in it. (Some people still use floppies, and the normal setting for systems with floppy drives is to try booting from that drive first. You may have a disk in it that isn't bootable.) Other possible causes are hard drive failure, a virus or other malware program has damaged the drives boot sector, or a motherboard problem. The most likely cause would be the hard drive; as a mechanical device they are more prone to fail than other parts.
Mar 08, 2010 | IBM NetVista M42 PC Desktop
Dell Dimension 5150 (& WinXP) - failure to boot up
you could try booting into safe mode, then you could try a system restore
look for the F8 option at the bottom after the first boot window,
youll know youve got it when you get the option to boot into safe mode, if this works you should get to your desktop, if you get the admin login its normally admin as user and leave the password blank.
if you cant get into safe mode, wait till you gt the recovery disks and try a system recovery before reinstalling
Oct 21, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 8400 Refurbished by with WinXP Pro preinstalled will not boot up. Gets past Dell XP Logo, then goes to blank screen with curser...however, keyboard locks up and can not get any further? What's th
windows is not loading properly.
if you're not worried about anything on the computer:
insert the recovery CD, boot the system to the CD, and reinsatll windows.
May 19, 2009 | Dell Dimension 8400 PC Desktop
Ibm netvita 2179 sreen flaches when booting then goes blank
Hi, My Name is Henry. I am one of the technicians here.
To solve your problem you need to re-install the drivers of the video card by using the Drivers CD that came with your system.
If that does not work. try using a different Monitor for your system to ascertain where the problem is from.
Mar 18, 2009 | IBM NetVista X40 PC Desktop
Safe mode boots okay but not in normal boot - no error either
Do you have the original recovery disk? I recommend inserting the recover disk, restart the computer while continually pressing F12. Select boot from CD, press any key when asked, and you would want to do a "repair". That should fix your problem.
Jan 12, 2009 | IBM ThinkPad 600X Notebook
Booting problem
apparently the boot setup screw up.
my best suggestion is to restore windows after you found a way to save all your files....
Apr 12, 2008 | IBM ThinkPad i Series 1412i Notebook
Re:not booting up
اريد برنامج نوكيا 6630 ممكن
Mar 22, 2008 | IBM NetVista PC Desktop
Computers & Internet Logo
345 people viewed this question
David Payne
David Payne
