Question about Watches
Can't reset the time on digital watch
This is my son's digital watch which we have lost the instuctions to.
It is a 4 button design. with 24 hour option, alarm, timer etc.
When looking at the face:
The top left button is "Light"
Bottom Left "Mode"
Top Right "Start"
Bottom Right "Reset"
Hope you can help!
Thanks
dave.mcclure1@sympatico.ca
  • 1 more comment
  • Anonymous Mar 22, 2008
    cannot change time on nike triax digital watch
  • steiman Mar 22, 2008
    Bottom Left "Mode"
    Top Right "Start"
    Hope you can help!
    Thanks
  • 45161 May 11, 2010
    HOW DO I CHANGE THE TIME
I found the solution at http://www.watchliquidators.com/fossildir/Nike.asp
Hold down the button at the top left (the light) for about 4 seconds. The second part of the time will start blinking. I tried this before, I'm sure, but I must not have noticed the blinking and thought nothing was happening.
Once the seconds numbers are blinking, push the top right button (Start/Stop) to move to the hour or minute. Push the bottom right button (Lap/Reset) to change the time. When you're done, push the top left button (Light) again.
Posted on May 20, 2008
This does not work!?!?!?!
Posted on Feb 15, 2015
Change 12 to 24 hr & date
Hi bobwesley,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Nov 17, 2010 | Timex 1440 Nylon watch
How do i change my timex wr30m from 24 hour to 12 hour display
Hi cbrichw,
Hope it helps.
Nov 13, 2010 | Timex 1440 Nylon watch
Resetting the time!
Hi wizgrand576,
To set the digital time and date on your Timex, please follow the steps below.
Timex Digital Watch
Hope it helps.
Nov 08, 2010 | Timex 1440 Nylon watch
How to change from military time back to regular time on a digital indigo watch with 4 adjustment buttons?
Thank you for contacting FixYa.<br /> <ol id="ecxintelliTxt"> <li id="ecxjsArticleStep1"> Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.<br /></li> <li id="ecxjsArticleStep2"> Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.<br /></li> <li id="ecxjsArticleStep3"> Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.<br /></li> <li id="ecxjsArticleStep4"> Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.<br /></li> <li id="ecxjsArticleStep5"> Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.<br /></li></ol> Contact TIMEX for further assistance at:<br /> http://www.timex.com/info/Product_Instruction_Guides_Downloads
Aug 25, 2010 | Timex 1440 Nylon watch
How do I switch from 24 hour time to 12 hour time?
Hi greg780,
Hope it helps.
Oct 12, 2009 | Timex 1440 Nylon watch
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
Hope it helps.
Oct 09, 2009 | Timex 1440 Nylon watch
Military time on timex 1440
Hi bud76502,
Hope it helps.
Oct 02, 2009 | Timex 1440 Nylon watch
Athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Apr 30, 2009 | Watches
How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
Sep 28, 2008 | Watches
Setting a generic one-button digital watch
I too lost the instructions for my generic 4 button digital watch and had to find the functions by trial and error and the results are below.
Adjust Alarm/Time/Date - Press and hold Mode Button. When alarm displays, release. Start-Stop Button SELECTS, Lap-Reset Button ADJUSTS selection. Pressing the Mode Button again changes from Alarm to Time/Date, ADJUST as above. Pressing it again exits.
Select/Deselect Alarm, Hourly Chime or Both - Press and hold Lap-Reset Button, Start-Stop Button TOGGLES through the above options.
Select 12/24 Hour Mode - Press and hold Lap-Reset Button, Mode Button TOGGLES through the above options.
Select Stopwatch - Momentarily press the Mode Button, use the Start-Stop and Lap-Reset buttons to control.
Display Date - Press Start-Stop Button in normal time
display mode.
Display Alarm - Press and hold Lap-Reset Button in
normal time display mode.
Cancel Alarm - Press Lap-Reset Button in normal time
display mode to silence alarm.
Hope this is helpful,
George.
Nov 06, 2007 | Watches
Watches Logo
4,648 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
