Question about Kitchen Ranges
How do I turn on my oven
I have recently moved into a rental house and have no idea of how to turn on the oven, It is a westinghouse equaria, upright, manufactured by email. I have turned on the dial for the oven and no heat, it has a push stop to cook manually, and a start dial also. I can give you the serial numbers, if you need them. Thankyou
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Look closely at ht e 2 dials push to stop cook manually.that s where theproblem lies. you need to set it for MANUAL cooking probably requires turning one knob till it pops out.its probalby set for timed cooking.Its usally labeled around the clock face in real small print "push in for manual operation"
Posted on Mar 22, 2008
Replace fuse in an old Westinghouse 229 fan-forced oven.
Not sure, but if you're lucky the stove will have a schematic inside. Take the back off, see if one is glued to the back or in an envelope. If back is 2 pieces try top behind controls first. Unplug 1st!
Mar 14, 2014 | Dryers
Hi, We have a Westinghouse electric wall oven with a door which appears to have a broken spring inside. We have previously been able to set it back in gap for hinge but now it has given up holding...
You should be able to buy new springs or the hinge complete from most appliance parts outlets. On some Westinghouse, the door will slide straight off the hinges but on others, you have to strip the door to get at them. Try opening the door and see if the door slides up and away from the oven. If it does, its pretty easy to change the hinge, if not, there will be a little clip on each hinge which locks the arm in place. Slide the clip on both hinges to the front and then you can lift the door up and out of the oven. remove the screws holding the door together and then you will see the 2 screws which hold the hinges in. Order a left (or right) hand side whatever one you need, but I would suggest that they are replaced as a pair, otherwise the door may not close evenly.
Jul 31, 2011 | Ovens
Stops mid cycle often
Hi there, did you ever find out what was wrong with your dishwasher? I have a Westinghouse 904 doing the same thing but when we moved into this house the manual was long lost. Any thoughts would be greatly appreciated.
My email address is shaneane@clear.net.nz
Jun 02, 2009 | Westinghouse Dishwashers
Not able to use oven - just moved in
check the breaker and make sure it has not tripped.
Jun 02, 2009 | Ovens
How do I remove the housing cover on a westinghouse vacuum?
Remove clear snap-in lights lens. Remove both lightbulbs. Where the bulb sockets are there is a screw, remove them. Then simply pull up on the housing from the rear where the wheels are and remove the top cover.
Dec 28, 2008 | Westinghouse WST1500 Wired Special Edition...
Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Aug 20, 2008 | Ovens
Pilot lights
you need to plug the oven in; pull it out and you should locate the pwr cord or you may already have it plugged in and have a breaker turned off or a gfi tripped
Jun 19, 2008 | Magic Chef Kitchen Ranges
Westinghouse stove
Turned the self cleaner on my electric stove although oven door at end of cleaning cycle would not open, it remained locked.
Would greatly appreciate any ideas.
Thanks
May 15, 2008 | Westinghouse Bethany Antique Brass- Indoor...
GE SpaceMaker Microwave JVM1653BD004
WoW!! What kind of a rental lease requires you to repair appliances? Most rental properties have maintainance of appliances included. Read your lease. Are you required to have it repaired?
Could be anything from a Cold Solder Connection on the Cook-Relay Board to a Magnetron.No Simple solution for a Novice. It involves step-by-step trouble shooting with power turned on some steps. Very DANGEROUS!!
Call around, Ask how much for Trip Charge and Estimate of Repair.
Good Luck!
Jan 29, 2008 | Microwave Ovens
Kitchen Ranges Logo
728 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
