Question about Samsung RS2578BB Side by Side Refrigerator
Frig not cooling
I have frig temp set at 34, its 58, freezer working fine
  • herpdude May 06, 2008
    Exact same problem, however the fridge occaissionally drops back to 34, then back up to 58 ish, and so on. This transition can happen in an hour! I have a feeling it may be a defrost issue, just a thought. I have lost $700 dollars worth of food due to this machine, most due to the failure to reset issue with a brown out condition. I have checked my freezer evap, froze over several times after the brown outs. I have shut off the water supply, just in case, I had some water accumulation previously. This was possibly due to defrost?
  • Anonymous May 22, 2008
    yee ha!!! Sounds like these refers are worthless peices of junk. I'm having the same problem exactly(it is very common on other blogs). I have been trying to get someone to look at it for 7 days now and ( I live in a no coverage area) after multiple phone calls to Samsung ( hung up on 3 times) about the problem not one returned phone call(also common on other blogs) I was told if they don't find someone in 7 days they will replace. Seen this answer used on other people with no results (on other blogs also). Seems like Samsung has the same M. O. over and over again SOLUTION TO PROBLEM: Haul off to junk yard, by a Whirlpool and never buy another Samsung product of any kind again
I had a same problem as what you described. I purchased mu Samsung RS2545SH side-by-side refridgerator from Costco 2 years ago. I contacted Sumsung, who then sent out a local/independently operated repair shop to come and perform the repair. After three trips by the repair shop and more than $400 in repair cost, the same problem persisted, and I'm stuck with a non-functional fridge for more than 2 weeks. Repeated calls to Samsung service line simply added more aggrevation and no results. The repair shop declared the fridge non-repairable, and my attempts to ask Samsung for a refund only get me a standard response: The executive review committee is reviewing your case!
Finally I simply had it, and hauled the fridge back to Costco, and thank goodness, the folks there were so kind and took back the broken fridge after 2 yrs from the purchase date. Thank you, Costco!
I do not recommend anyone to purchase a Samsung refridgerator. They may look nice on the outside, and maybe even a bit cheaper price. But you may very well be stuck with a non-working fridge in a year or two, and a warranty bureaucracy that will bog you down. And Samsung did not seem to care about standing behind their broken product. This will be the last Samsung product I will ever purchase.
Posted on May 15, 2008
  • jimM Oct 30, 2012
    I agree, NO MORE SAMSUNG FOR ME!!!!!!
I have Samsung fridge model RS267LBSH. The freezer works but why won't the frig side cool?
If the door temp is reading low then it will not cool as that is the temperature the fridge thinks it is at (regardless of the real temperature). Try setting the door temp lower and see if there is still a 14 degree difference between the 2 readings. If it does cool down further and the difference is the same then I would suspect the thermostat.
Aug 16, 2015 | Samsung Refrigerators
Hotpoint Rfa52 fridge not working. Freezer ok.
is temp or freezer control turned all the way up? set frig / freezer control in middle and wait 24 hours. do you feel cool air going in freezer from vent? if not change control as stated and see if you have air flow. control door to frig may also be broken or stuck
Jan 30, 2014 | Hotpoint RFA51 Bottom Freezer Refrigerator
OK, here's the problem - Samsung model RB1955SH - plug refrig in it cools both frig and freezer to desired settings - however, once system reaches stttings and turns off compressor, will not restart system...
the temp controller is bad in the fridge once it reaches cooling temp desired it cause the temp comtroller to go into a shut off mode due to being weak on the temp sensor tube
Jan 18, 2010 | Refrigerators
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
We have a LG Two Side Fridge.
Look for the air ciculation regulator sliding vent between frig & freezer section open accordingly. Set both sides to #3 on dials if frig not cooling to less than 40 degrees, might need new cold/temp controller behind frig dial
Apr 30, 2009 | LG LRSC21934 Side by Side Refrigerator
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Frig won't cool, freezer works fine
Defrost unit completely. You're frosting up. Then, avoid leaving the door open, leaving liquids and food uncovered. Clean condenser coils. If it happens again, you need refrigerant.
Jun 09, 2008 | Refrigerators
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Whirpool frig. freezer works frig doesn't
access to the evaporator fan is in the freezer behind the rear wall.
Feb 18, 2008 | Refrigerators
Samsung RS2578BB Side by Side Refrigerator Logo
465 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
