Question about Konica Minolta magicolor 2300DL Laser Printer
Konica Minolta 2300DL waste box full message
I am getting the message waste toner box full which I can't rectify. I have put in a new toner box, replaced trhe drum unit, taken all the toners out and replaced them, tried pressing restore defaults on the menue display - no joy. Any further ideas before I go mad ?
Thanks
Tom.
  • Anonymous Mar 18, 2014
    PRINTER WILL NOT PRINT
  • 871 Answers
Remove the waste box you'll see blue knob and above there is a sensor now take a look at the waste box and find the place what goes between the sensor. you should cut off one side and clean the other sides and then use some invisible tape to fix the hole. and try again.
Place what goes between the sensor have to be clean. its not good idea to cut or remove the sensor at all because next time the box will be full you don't know that and it will brake your printer
Posted on Mar 22, 2008
    New Friend:
  • 159 Answers
See the services manual and you can find how to clear this massage in the service mode menu good luck
http://printer.konicaminolta.com/service/ASP/mc2300/documentation_manuals/mc2300SM.pdf
    President:
  • 1,944 Answers
Did you try disconnecting the printer for a few hours to hard reset?
  • Damen Wong
    Damen Wong Mar 22, 2008
    Did you try resetting though the menus?
My konica minolta 2300dl tells me my drum is low. do I need toner? Where do I go to get toner?
If it tells you the DRUM is low it has nothing to do with toner, it probably meens you need to replace the DRUM unit (aluminium blue/green cylinder in the device) dont forget to reset the timer after replacement
Jan 04, 2011 | Konica Minolta OEM Konica Minolta...
WHERE IS THE WASTE BUCKET ON PRINTER KONICA 4690MF
Found this on the support site
When the waste toner bottle becomes full, the message "WASTE TONER
FULL/REPLACE BOTTLE"
Konica/Minolta Support
Go to "Ch. 7 replacing consumables" > "Replacing Consumables" > "Replacing the Waste Toner Bottle" this is found on page 165 of the user guide. This walks you through replacing the waste toner bottle.
Hope this helps. GOOD LUCK!
Oct 16, 2009 | Konica Minolta Magicolor 4690MF...
My magicolor 2300dl printer is showing waster toner box full and won't print but the waste toner box is empty and new. Is there a reset button on the printer to bypass this error?
1. Empty the waste box.
2. Read p66 of http://printer.konicaminolta.com/service/ASP/mc2300/documentation_manuals/mc2300SM.pdf
3. Identify the "Waste Toner Full Detecting Sensor" which tries to pass a light beam through the protruding plastic slot on the waste box that engages with the photocell.
4. Use a dry cloth to clean dust off the photocell transmitter and receiver and also off the protruding plastic slot, so that light will now pass through.
5. Refit the waste box and enjoy the $$ saving.
Sep 23, 2009 | Konica Minolta magicolor 2300DL Laser...
Can't make machine print Konica Minolta 2300DL
As soon as you open the door on the right side of the unit the waste collection box is there. You will see it, it is the large strangely shaped item that extends from the middle top to the bottom of the unit.
Jun 25, 2009 | Konica Minolta magicolor 2300DL Laser...
Wast toner full
You need to replace the waste toner kit part number 1710522-001
Jun 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal Error 21H
FATAL ERROR CODE 21H / SERVICE CALL 21 TRANS DET SENS: Malfunction of the OHP detecting sensor
check the OHP detecting sensor (PC3A) (it's at the front above the waste toner sensor pc6)
May 22, 2008 | Konica Minolta magicolor 2300DL Laser...
My Magicolor 2300dl printer displays a 'Waste toner box full' message, even though I have just emptied the waste toner box.
. Remove Waste Box, Empty box, wipe down w/ dry paper towel
. Turn machine off,. Unplug power cord
. there is a blue rectangular pull knob
.above Rectangular knob @an angle R 2 notches (contain ensors)
. Take an AIR can & hold 6-8 inches & spray N2 ea. sensor
. this should clear any particles that generate a false " Full " Signal
. credit to Nightangel for getting the ball rolling. Thx
Feb 28, 2008 | Konica Minolta magicolor 2300DL Laser...
Waste Tone Box
Your machine catch's excess toner and puts it in a container and needs you to replace/empty it soon or it will have to stop work, sorta like needs just a dash of attention for all its effort.
The bottle at a guess for this model will be apparent when opening front door, instruction are probally on the inside of door but it is just a container full of black messy stuff that needs to be emptyied and replaced....hang on I'll google it....looks like you need to buy a new box and that will have instructions even.
Some links for your product toner box
http://www.precisionroller.com/catalog_display.php?mfname=konica_minolta_bizhub_c450p_waste_toner_container_details&m=297&d=7597&c=40&i=31526
http://www.tonermax.com/KONICA-MINOLTA-BIZHUB-C450-WASTE-TONER-BOTTLE/i/24194
Oct 31, 2007 | Konica Minolta bizhub C450P Laser Printer
Toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
632 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
