Question about Jenn-Air JXT8136ADS Kitchen Hood
Control Panel Display
The small LED display on the control panel has several bars that remain light (though dim) when range is off. Otherwise, the overall unit works fine. Is this an electrical problem? Can the unit be reset? Will it lead to more electrical problems.
  • Anonymous May 24, 2008
    mine had the same problem and then the lights went out,removed the board inside it's plastic housing and it had fried were the 50 watt lights connect.! $165.00 part and the thing is fairly new. A defect for sure but will the new board be any better?
  • Anonymous Jun 26, 2008
    same problem here and the $165.00 new board looks exactly the same...ohh no!
  • 91 Answers
May be wiring ....at switch...reversed...polarity...or control replace..
Posted on Nov 04, 2009
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Which fuse is for the instrument panel back lighting?
Does the radio play ? Are any other back lighting components not lighting ? Does the HVAC control panel light up ? You probably need new radio !
The second interior lighting group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination, LED illumination and incandescent lamps.
When the ignition switch is turned to the RUN position, the radio VF display turns ON at maximum brightness. When the park lamps are ON, all incandescent and LED back lighting turn ON at the dimming level indicated by the instrument panel (I/P) dimmer switch. At the same time all VF displays dim to match the indicated dimming level. The panel dimmer switch potentiometer is an input to the body control module (BCM). When the driver selects a dimming setting by moving the I/P dimming switch potentiometer, all incandescent back lighting lamps are provided with a specific voltage. When the I/P dimmer switch is moved from MIN to MAX, all VF displays, as well as all incandescent back lighting respond from minimum intensity to maximum brightness in response to the I/P dimmer switch.
Dose
Jul 14, 2015 | 2008 GMC Sierra 1500
The led display lights have dimmed so much I can't read the. THis is a built in double oven - Kenmore. not sure of the model #
you will need the model # to get the correct control panel for this range . the display has failed and ony repair is to replace it . part # may be on control . and inside the control area there should be a tec sheet with this info .. mm hope this helped ..
Jul 11, 2010 | Kenmore Ovens
Engine stalls at stops and inst cluster goes off w/headlite on
check the alternator charge level .
check the battery + and - are not lossing
if nothing then you have wiring short
Sep 15, 2009 | 1989 Pontiac Grand Prix
Electronic Display
Go to, fixitnow.com for a cheap fix on these displays. It worked on my jenn air.
Oct 29, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air JXT8136ADS Kitchen Hood Logo
217 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
