Question about Epson Stylus C88 InkJet Photo Printer
C88 / T060 cartridge refilling problem
I like to refill to save money. I have a C88 printer and T060 cartridges. I understand that these cartridges are very sensitive to air bubbles when refilling. I refill with a set of quality black and color pigment inks, then put the cartridges through rigorous testing printing solid color blocks on numerous pages. I can get black, cyan, and magenta to print satisfactory. Yellow prints solid blocks of color just fine when printing by itself, but when I engage the other colors to print solid blocks on the same page, yellow starts getting white lines in the print. I run numerous clean cycles to clear the yellow, then cyan and magenta will start getting lines in the print. Why would yellow print solid blocks through numerous pages in a satisfactory manner by itself, but when engaging the other colors to print solid color blocks of Cyan, magenta, and yellow on the same page, I start getting lines in the yellow?
  • Anonymous May 13, 2008
    My computer is rust printing yellow
Sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Posted on Jul 28, 2008
U051 error message. Won't print
Well, you must be using PG30, CL31 cartridge for your printer.
Did you refill your cartridge?
For error 051 means printer is not reading the cartridge. (cartridge is not readable)
When you put refilled cartridge, that's what it happens.
(after 3~4 times of color refill, color cartridge is no long to use, only applies in Canon
and there is no solution for it.)
Pls replace with new one.. and will work again.
Or if you need to refill again with other cartridge, pls....unplug your printer before you taking out the cartridge. In this way, you can re use your cartridge. Little trick... but no solution will work, once cartridge is not readable.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 11, 2011 | Canon PIXMA MP470 All-in-One Printer
My pixma MP145 printer do not starts, just the alarm light lits when ever i connect to mains. Why?
It seems like there are some problem with your cartridge.
U C any sign on LCD display?
If you used unreadable cartridge that's what it happens.
When u take out the cartridge for refill, pls......!!!! unplug the power first!!!!
Once your cartridge become not readable, there is no way to refill and reuse.
May 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I am having cartridge problem. It says: Cartridge error: refer to device documentation to trouble shoot
You must be using HP56.
Have you refill your cartridge at all?
If you did, gentely wipe out the cartridge circuit part with Q-tip (with bit of alcohol).
And wipe out the circuit part in the printer where cartridge goes in as well.
And try back.
Sometimes by having some dust or bit of ink make cartridge unreadable.
May 04, 2011 | HP Officejet 5610 All-In-One InkJet...
Every time i turn my printer on it flashes E, 5... and the alarm button is lit. i installed brand new 40 black and 41 color canon ink cartridges, and the error still isn't fixed
r u sure new cartridge is not refilled one?
E5 error means cartridges are not readable.
When you refill your canon cartridge, especially for color one, it happens. (after 4~5 times of refills)
So you have to replace the cartridge with brand new one.
(for your additional reference, it doesn't happen to black cartridge)
So at least you can refill black...
If you would like to save money, try nozzle injection refill kit by ROADINK.
And will see how easy ink refill can be done.">
Apr 26, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Canon ip2700 after refill of Black cartridge ink status still shows 'low' and print is very poor - breaks, incomplete - as ink running out. How to reset ink level, or to disable warning, and to get print...
For your ip2700, even if you reset your refilled cartridge, they are not going to be usable.
After 4~5 times of color refill, you will see e5 error that cartridge is not readable anymore.
So you need to replace your cartridge with new one somehow.
Apr 20, 2011 | Canon iP2700 Inkjet Photo Printer
Error 5200
Sorry this error cannot be solved.
You must be refilled your cartridge, right?
And your cartridge is not readable from your printer and can see the blinking light.
In this case, there is no way, printer can be worked with cartridge you have.
Somehow this is happening to many canon inkject printer and this is natural and how they set up.
Well solution would be replace your cartridge with new or...some other.
For your CL41 cartridge, at least you can use upto 4~5 times of refill.
And then you can save more than $100.
Apr 20, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
I replaced my ink cartridge and now my printer wont come on Cassyangel29@yahoo.com
Have you refilled your cartridge? or used compatible?
If you refilled your cartridge, either you put in too much ink in it.
Try to **** out the ink and try back.
Your HP60 cartridge can be saved by refill.
Apr 19, 2011 | HP D1660 InkJet Printer
I have a PIXMA MP 110 CANON and when i go to print it says CARTRIDGE IS JAMMED PRESS OK. The computer says it is a ERROR 5100 problem and press OK AND IT SHOULD WORK .but it doesn,t. The cartridges are...
You are facing e5 error which cannot be solved.
For Canon printer, if you refill about 4~5 times, especially color, the printer does not read that particular cartridge.
Well for solution? You need to replace the cartridge with new one.
Just blame Canon....
At least you can easily save $100 for color cartridge (facing e5 error after 4~5 times of refill)
Apr 19, 2011 | Office Equipment & Supplies
I have changed the ink cartridge on my canon mp272 but it keeps saying there is no ink in it
Well have u used refilled cartridge?
It seems like you are facing error called "e5" which cartridge is not readable from printer.
This happens in Canon printer, especially for color cartridge.
In this case, the only way you can do is replace your cartridge with new one.
At least you can use your cartridge 4~5 times of refills and can save more than $100.
Epson c88 shows ink out in all four cartridges but they are full
Are they "original" Epson ink-cartridges, or have they been refilled? Often, the refilled cartridges will show as "empty", but they work, until they _do_ get empty.
Apr 16, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 InkJet Photo Printer Logo
447 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
