Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
JVC AV-56WP74 Red Convergence is Off
Red color is casting a shadow of everything on the screen. Please email instructions and anything you think I might need to have replaced to fix. Thanks! email: [email protected]
    Genius:
  • 1,694 Answers
Sorry,I don't send E-mail instructions......see my powered
products for many convergence repair solutions........T.
Posted on Mar 23, 2008
6ya staff
SOURCE:
JVC AV-56WP74 56 in. Rear Projection red projector is not showing images and big red line in tv
If the red line looks like a swoosh of red across the screen it may be the convergence Ic having an issue.
Jul 04, 2011 | JVC AV-56WP74 56" Rear Projection...
Convergence is out...trying to manually adjust but only have blue and green lines....no red...how can i fix this?
Tv have 100% convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 22, 2010 | JVC AV-56WP74 56" Rear Projection...
Double Images
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | JVC AV-56WP74 56" Rear Projection...
My tv is a jvc av-56wp74 it looks like 3Dwithout the glasses the colors dont line up
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 04, 2010 | JVC AV-56WP74 56" Rear Projection...
I have a JVC AV-56WP74 Rear Projection HDTV Ready Television...I had a problem with the convergence with dual pictures on screen...I replaced the convergence card with 110's.....This fixed the screen...
The STK392-110 are the stock ICs for your JVC. Chances are one or more of the feed resistors are bad. JVC TVs will usually have at least one bad resistor when the original ICs fail
Sep 06, 2009 | JVC AV-56WP74 56" Rear Projection...
Convergence problem
Did you lock the adjustment into the TV's memory? This step is the most often missed. Please follow the directions on the Users manual or on the service manual on how to set your memory to hold the configuration.
Find the menu item on setting the convergence adjustment into memory (the menu should have an informational screen on this topic)
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 06, 2009 | JVC AV-56WP74 56" Rear Projection...
TV PROBLEMS
If the images are different colors (red,green,blue) then the convergence has diverged. Some TV allow re-convergence through the menu screen, older sets my need to be physically adjusted (aimed) to clear this up. a strong knock to the TV may have cause this.
Apr 21, 2008 | JVC AV-56WP74 56" Rear Projection...
Red Wavy lines running across the screen...
Yes - - that indicates one of your convergence amps have failed. That unit takes two STK392-110 Sanyo amps which I personally would replace with STK392-150's for greater reliability. Also check all of the return resistors in that circuit 1.5 ohm 2w and feed resistors 3.3 ohm 1w all are flameproof. You'll likely find that one or more of the return resistors are bad, with suspecting the red is the failed amp check in particular R846 for change in value or open.
Bill
Mar 24, 2008 | JVC AV-56WP74 56" Rear Projection...
Blue shadow across my screen
Go into the convergence function from the menu and see if it works. If it does not then the convergence board has a problem. JVC still sells the part.
Jan 20, 2008 | JVC AV-56WP74 56" Rear Projection...
Double vision On JVC AV-56WP74 56
You have an convergence problem, There are 2 IC's that go bad and a few resisters that can change value. If you flip the board with the Chips inspect the pins for cold solder joints. The IC's can be purchased from matelectronics
Jun 17, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
122 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
