Question about Dishwashers
Zanussi ZSF 6161 Dishwasher with Error 30 Code
Zanussi ZSF 6161 Dish Washer with Error 30 Code, meaning Anti Flood Device Activated. Any ideas on what to check? Have had Drain Pump out and all appears ok.
  • Anonymous Apr 03, 2008
    EXACT SAME PROBLEM, WE TILT UP MACHINE, WATER COMES OUT THEN YOU CAN RE USE IT BUT ONLY 2/3 TIMES THEN THE PROBLEM REOCCURS!
  • donwhelton Sep 11, 2008
    same problem. can move the dishwasher around and it will start again but have to do this 3 times during wash
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Posted on Sep 06, 2009
  • pat forde Apr 11, 2013
    followed your instructions, job done ,thanks
What is code.30
Zanussi ZDF 511 User Manual
anti flood device is activated,call for service
Mar 31, 2015 | Electrolux Genuine ZANUSSI ZDF511...
Replace bulb zsf6161
see your instruction manual, and go to the section troubleshooting.
however is very simple, unplug the power and proceed taking the first wire and make note for color wiring, and replace.
If you do not i.manual download from www. retrevo.com
God bless you
Jun 18, 2012 | Zanussi Dishwashers
Anti-flood device activated
Check your debris trap usually found at the bottom of dish washer and clean. May need to reset or unplug to reset devise. See what happens after cleaning, good luck, best regards.
Jan 30, 2011 | Zanussi 23 in. ZDT6255 Built-In Dishwasher
THE anti flood device has been activated. I have emptied the salt tank, how do I reset the safety valve on the water inlet hose?
The answer is that you don't reset the anti-flood device. The anti-flood device re-sets itself when there is no risk of a leak. I don't really understand why you emptied the salt tank . . . ?
I cannot help you any further than this as you haven't specified your brand and model of dishwasher. If you can post these, I will try try to help further - if it's a model I support.
Oct 17, 2010 | Dishwashers
Machine not starting ...Programme Progress Display light flashing
This normaly indicates an error code. Could be the anti flood device activated due to water leaks etc. The anti flood device (polystireene float and micro switch at base of machiene) puts the washer on pump out mode and shuts off the inlet water. Dry the water at the floor of the washer and check and rectify any leaks.
Jan 21, 2010 | Dishwashers
I have a Zanussi Electrolux Jetsystem Progress ZSF 6161 Dishwasher which, no matter what programme I use, stops after 2 seconds and a -10 flashes.
I have a Zanussi Jetsystem Progress ZSF 6161 Dishwasher stops after a few seconds and flashes -30 Any ideas? thanks!
Jul 28, 2009 | Zanussi Dishwashers
Zanussi ZSF 6161 Dishwasher error codes
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Bosch dish washer SGS56E02GB
anti flood device has been activated, this means you have water in the base of appliance. most likely a leak, or if you have been using 3 in 1 tablets, and rinse aid this will over foam appliance and foams leaks into base.. try tipping d/w back to let water out of base..then try d/w again... if anti flood activates again...call an engineer.. ps check big nut that secures salt container to base of d/w, it can come loose which will cause water to leak into base ally
Jul 01, 2007 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwashers Logo
2,300 people viewed this question
Top Dishwashers Experts
