Question about Mitsubishi VS-5043 50" Rear Projection Television
WD52327 picture is too high and too low
    Genius:
  • 1,153 Answers
What do you mean too high and too low?
Posted on Mar 22, 2008
I have replaced the lamp on my Mitsubishi WD52327 with a non oem version and the tv started clicking can you tell me what that maybe?
The tv board that call the Ballast board it is also dead too.This ballast board only job are to ignite the tv projection lamp only.
Jun 14, 2011 | Mitsubishi WD-52327 52" Rear Projection...
I have a 1997 Chevy S10 and need to know what one of the ac hoses are called, it has a whole in it. Can I send a picture of the engine?
depending on where its at, it will either be a high side or a low side line, i'm at hopme righ now and dont have my manuals with me, but generally the lines after your compressor up to the dryer are high side, and from the dryer to the compressor are low side, hope i was able to help
Apr 20, 2011 | Chevrolet S 10 Cars & Trucks
Pictures quality is bad on a lot of pictures - lines and blocks are in the picture display but the thumbnail looks ok
Are you taking pictures at the lowest resolution? Most cameras have jpeg settings low medium and high or something like that are you on low. It may be that the pictures taken at this resolution are only good at thumbnail size.
Dec 27, 2010 | Cameras
Mitsu #WD52327 DLP replaced bulb but hazy picture
Did you clean the small mirror. Dust will cover this mirror and give you a very hay picture. This is easy job and takes 15 minutes at the most. Someone posted detailed destructions on how to do this already if you look for it under WD52525 hazy picture.
May 27, 2009 | Mitsubishi WD-52327 52" Rear Projection...
My wd52327 turns on and than turns itself off
Thats a very common problem which means that the capacitors on the power PWB have most likely failed. You can get the repair kit which has the replacement Capacitors and step by step instructions with detailed pictures on how to do the repair . Heres a link to the repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jan 24, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Bad photo quality
The Konika Minolta 7D is a DSLR. With the DSLR you have a much bigger sensor, and can use much bigger lenses (with larger apertures - lower f-stop numbers) to gather light to the sensor. This allows the DSLR to take much better photos in low light. You will never get the same quality out of a small pocket camera like the Nikon S60. Hand-held non-flash photos in low light with this camera are going to have the flaws you have noticed - especially in the darker areas of the image. This is digital noise caused by amplifying the signal from the sensor as the camera processes the image with the high ISO setting.
You said you are sure that you are using the highest picture quality settings. The next thing is to change the ISO - this camera's "high ISO" does not produce images with good quality. The camera automatically uses a high ISO setting in low light, you need to tell it to not use high ISO by setting a lower ISO value. When shooting with a low ISO setting in low light, you need to use a tripod, and your subject can not be moving.
If you need to take hand-held photos, or your subject is moving, then you need to use flash with this camera, or else use your 7D.
Dec 29, 2008 | Nikon COOLPIX S60 Digital Camera
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
