Question about Cameras
Ricoh Caplio GX. won't switch on, green and red lights flash and error code comes up on screen. 00-00-00 30-01-23 can still view previously taken photos on the screen,chaned batteries twice,so not that...
  • 4,889 Answers
Firstly try to perform a soft reset. Press and hold the power button for 10 seconds..
If it doesn't work try the hard reset. Take out the battery. Leave it like that for 1 min. Then put the battery back in and see if works.
If it still doesn't work then its time for a firmware update
Posted on Mar 22, 2008
    President:
  • 1,944 Answers
Did you ttry leaving the batteries out for a few hours to reset the camera?
Code error 00-00-00 30-00-28
If the lens got stuck, you have a problem. It can be caused by many things. A broken sprocket, a broken gear, just a little dent in the lens barrel, dried out grease and many other things. Even a defective motor or just a bad contact or a broken connection can be the cause. Non of them can be repaired by yourself. Sometimes, tapping the camera on the palm of your hand, could solve the problem (temporarily), but don't bump it to hard, or you could damage it beyond repair. Tap it with the lens barrel down ward, asif you want to tap it out. But only in a few occasions it really would work. If the battery has enough power, to switch the camera on, pulling it through a setup and displaying the error message, the battery should not be the cause. Getting out the battery and replacing it after a few moments, could reset the error, so i tries again to switch on normal. But if the error keeps coming back, I think it is wise to start saving for a new camera. Most camera's on the market now, perform better and will cost a fraction of what you paid a couple of years ago.
Oct 28, 2014 | Cameras
I have a ricoh 500G caplio camera stuck in play back, I push the Green Arrow as per the instructions, but it will not switch back to the shooting mode.
When an error occurs with a digital camera, try switching it off. Wait till no light is burning or flashing and then remove the battery (batteries when there are more) Leave the battery out for a few seconds and reinsert the battery. After switching on, the camera should work normal. But if the error comes back, you should contact a service centre of your camera brand and make an appointment. (Or you could start looking for another camera?)
Jan 31, 2014 | Ricoh Caplio 500G Digital Camera
Screen black r1
Can you come into the menus? Just to check you did not change anything? Sometimes the monitor or display stays black in record mode, because the camera was put in power save mode. In the manual you can find hoe to switch it on again. Has to do, with what you want to see during record mode. Just the image, image with info, sometimes with a grid and then display off.
Nov 23, 2013 | Ricoh Caplio GX Digital Camera
Error 00-00-00 30-00-28
The error code will be due to bad batteries. Insert new batteries fully charged the camera will instantly try to zoom in or zoom out to adjust focus. If this does not happen then there is a problem with the Lens Assembly.
Lens has been forced due to an accident or too much sand or dirt is clogging it up.
You need to re-calibrate the focus.
Hope this helps.
Jan 26, 2010 | Ricoh Caplio G4 Digital Camera
Caplio R7 error 30-01-23
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 13, 2009 | Ricoh Caplio GX Digital Camera
1GB Memory Card
try another card - 1Gb is like $10-$15 these days.
Feb 24, 2009 | Ricoh Caplio R5 Digital Camera
Ricoh R7 Lens Jammed
you would love to see what was the truth as link following,
http://xiaolaba.wordpress.com/2009/04/25/camera-ricoh-caplio-r7-a-real-****-lens-error-00-00-00-30-02-23/
it was a **** design by RICOH, sent your message of compliant to them. you may get free service.
Jan 25, 2009 | Ricoh Caplio R7 Digital Camera
Grainy, image
You might have changed the settings; ISO setting too high or something else, just reset it to factory settings if you can't figure out ISO.
Aug 21, 2008 | Ricoh Caplio GX Digital Camera
Ricoh caplio gx 5.1 mega pixels
Email this problem to Ricoh Techincal Support Team This appears to be an internal defect.
May 26, 2007 | Ricoh Caplio GX Digital Camera
LCD screen black, no viewed image displayed.
Internal video out connection may be bad, try using the provided cable to connect to TV and disconnecting to see if it returns to normal.
Apr 30, 2007 | Ricoh Caplio GX Digital Camera
Cameras Logo
102 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
