Question about Mitsubishi VS-5043 50" Rear Projection Television
Wide picture my picture is too high and too low
  • 4,889 Answers
See if you have a button called ARC on your tv.. you will have different modes called Wide, Zoom, Noraml eyc., Just put it in normal mode!
Posted on Mar 22, 2008
  • eagle338
    eagle338 Mar 22, 2008
    I mean the tv remote..
SOURCE:
Kv35v-35 picture blinks on and off every 2 to 5 sec
The model is an older set----likely the master screen is turned a little low-------located inside the set either on board at end of picture tube or at the high voltage transformer----set monitors brightness level to picture tube---a little low and picture will blink on and off---age of the set etc.
Oct 30, 2012 | Televison & Video
I have a 1997 Chevy S10 and need to know what one of the ac hoses are called, it has a whole in it. Can I send a picture of the engine?
depending on where its at, it will either be a high side or a low side line, i'm at hopme righ now and dont have my manuals with me, but generally the lines after your compressor up to the dryer are high side, and from the dryer to the compressor are low side, hope i was able to help
Apr 20, 2011 | Chevrolet S 10 Cars & Trucks
Pictures quality is bad on a lot of pictures - lines and blocks are in the picture display but the thumbnail looks ok
Are you taking pictures at the lowest resolution? Most cameras have jpeg settings low medium and high or something like that are you on low. It may be that the pictures taken at this resolution are only good at thumbnail size.
Dec 27, 2010 | Cameras
Need to see a picture of high and low ports and their locations on a silverado pickup. can only find two ports on the same line -one smaller than the other.
That's them, and only ones, there's an orfic tube in between both ports in the line, that's what changes the pressure from high to low, from one end of the orfic tube to the other, the small port will be the low side, that the one you recharge in, and the big one is high side.Hope this was very helpful.
Aug 05, 2010 | 2004 Chevrolet Silverado
Bad photo quality
The Konika Minolta 7D is a DSLR. With the DSLR you have a much bigger sensor, and can use much bigger lenses (with larger apertures - lower f-stop numbers) to gather light to the sensor. This allows the DSLR to take much better photos in low light. You will never get the same quality out of a small pocket camera like the Nikon S60. Hand-held non-flash photos in low light with this camera are going to have the flaws you have noticed - especially in the darker areas of the image. This is digital noise caused by amplifying the signal from the sensor as the camera processes the image with the high ISO setting.
You said you are sure that you are using the highest picture quality settings. The next thing is to change the ISO - this camera's "high ISO" does not produce images with good quality. The camera automatically uses a high ISO setting in low light, you need to tell it to not use high ISO by setting a lower ISO value. When shooting with a low ISO setting in low light, you need to use a tripod, and your subject can not be moving.
If you need to take hand-held photos, or your subject is moving, then you need to use flash with this camera, or else use your 7D.
Dec 29, 2008 | Nikon COOLPIX S60 Digital Camera
WD52327
What do you mean too high and too low?
Mar 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Grainy photos
just switch to regular mode but the pictures already taken will unfortunately be like this sorry
Mar 18, 2008 | Fuji FinePix F10 Digital Camera
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
