The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
the display resolution must have changed after playing a game or using some software so that's why the LED is blinking. Boot the PC in Safe mode & lower the resolution of your display
This is most likely because your computer is trying to display a screen resolution higher then tht monitor can support. Turn your PC on, and press F8 until you see a black and white menu. Select safe mode. Run safe mode and when windows loads, goto your control panel. Select Display and navigate to the resolution / settings tab. The screen resolution should be set to 1440 x 900 for this monitor to display video correctly. If you need more detailed information on where to find the display resolution settings in windows I will need the name of the OS you are running... XP, Vista, Win 7 etc.. Regards,Chris
That sounds like a display/resolution setting problem on your PC. I doubt there is anything actually wrong with the PC or the monitor, since both work with different combinations, so its most likely just a setting.
Some monitors don't display anything when they get a signal/resolution that is not compatible with their displays. I would try changing the display settings on your computer with your old monitor, then switch monitors and see if your newer monitor works.
Here's how to adjust the display resolution: If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust/lower the resolution. If in Vista/Win7 right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Sounds like the monitor is being made to show a resolution it does not support. Check the available resolutions the monitor supports and then check what resolution the video card is giving, if it not compatable, you get the black and blue screens.
For the video card, right click on the desktop in a an empty area and choose properties > settings > your resolution from the card will be there. Now from there click on advanced > click on monitor and look at the monitor settings. Make sure the box is checked to hide modes the monitor cannot display. Now click on the adapter tab and click below on all modes. This is the list of all modes that both the monitor and the video card argree on. Make sure the settings in your game match one of these and you should be good to go.
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
Change the screen resolution. The video card or video display may not be compatible to the supported video setting of the monitor. Try changing the video resolution to a lower setting such as 1024x768 and bit depth to 32 bit.
Normally, blinking indicator lights and no display on the monitor indicating a wrong resolution or refresh rate frequency, that the monitor can not display it.
To fix, enter safe mode, and configure the display to the lowest resolution. After restart, you should be able to have the display.
