Question about Saeco Royal Professional Espresso Machine
Too much water in coffee
Our machine seems to be adding more water to the coffee than it has in the past, it is also inconsistent in the amount of water it adds from one cup to the next.
    Sergeant:
  • Saeco Expert
  • 223 Answers
It sounds like your machine has an internal leak which is changing how much water enters the cup. You should get your machine serviced.
For Saeco parts and cleaning supplies visit www.cerinicoffee.com
Posted on May 29, 2008
SOURCE:
Red exclamation point light flashing
For Saeco Odea Go Team De-Brewerz.com says:
1. Your coffee maker might suffer from Steam, Coffee Bolier clogging due to scale. Due to clogging you are unable to product perfect steam, temperature drop in coffee, inconsistent steam flow, inconsistent water flow etc. We strongly advise you to do regular Descaling to your coffee maker (every 200-300 cups or 2 months)
2. If your coffee maker in working condition but still light is keep on blinking means required "Descaling". Please use the food graded Delonghi or equivalent brand descaler.
3. Remove the brew unit from the machine. Check the mechanism and refit the same into the machine.
You can order to us @ www.De-Brewerz.com or buy online in India @ www.fabkaart.com
Still issue not resolved claim the warranty if recently purchased. If you are in India then contact us @www.De-Brewerz.com
Nov 03, 2014 | Saeco Odea Go
!0 Cup home Bunn. Does not brew the number of cups of water coffee (water) in craft. 8 cups of water 6cups of coffee.
If you don't brew often enough you will loose a small amount of water in the tank due to evaporation while the tank heater comes on and goes off to maintain the proper brewing temperature, so if it has been a while since you last brewed, without coffee in brew basket put a carafe of water thru the brewer, you will get less than a full carafe out because it fills the evaporated space in the tank first then uses the rest to brew. Once your tank heater shuts off usually 5 minutes on less you will get out all the volume you put in.
Oct 11, 2014 | Bunn 10 Cup Home Coffee Brewer
How do you adjust the water level
After the first brew the machine should brew excactly the amount of water added to the water reservoir. Since the reservoir always keep half full then you should add the maximum amount you need in two steps.
Apr 07, 2012 | Grindmaster B-SAP Coffee Maker
How do you clean this product using vinegar?
Put a small amount of vinegar in the coffee pot, fill with water "12 cups" add contents to main unit and turn on, when finished! empty pot in sink and refill coffee pot with water only and cycle it through three to four times to make sure the vinegar is flushed out of the lines, adding fresh water each cycle.
May 19, 2011 | Mr. Coffee 12-Cup Programmable Coffeemaker
Faema due smart two group espresso machine, I am having inconsistant shots. this is an automatic machine and I have reprogrammed the shots however it is still being inconsistant as far as flow through the...
when you open the hot water valve all the way does the pump come one? You might have a newer version that has a mix valve. This allows a controlled amount of cold water to be mixed in with the boiling water from the boiler. If so you would find an adjustment (usually just a black knob) that is next to that valve. If the final amount of water for the espresso is fluctuating then you have a problem with your flow meters (dirty impellors or bad field sensors). If you notice a different in the amount of water flowing from one group to the next then something is clogging up the jets or group heads. It could also be a sign of your dispersion screens going bad or other stuff. Have you had it maintenance within the last six months. I have the manual for that machine if you need a copy.
Good Luck, [email protected]
Oct 22, 2010 | Bunn CDBCF 15 APS Coffee Maker
How does the pot make strong or reg. coffee by pressing a botton not adding coffee amount ?
By pressing the button for "stronger" coffee, it slows down the rate at which the water enters the grounds. This allows the water to set in the grounds longer and therefore can make the coffee a bit stronger. This is why on some pots when there is a 4 cup setting used, it takes longer for the coffee to be made. With such a small amount of coffee, it should go thru more slowly to get the same result.
Mar 04, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Saeco Talea Ring Plus: often, water flows out of of water steam
The valve parts need to be replaced, if it is only happening when brewing coffee then there is so much pressure on the pump that it is forcing the valve open. First try adjusting the amount of coffee be added to the chamber for brewing.
Aug 23, 2009 | Coffee Makers & Espresso Machines
I put in 6 cups of water and only 5 cups brew. It
The amount of water you put in the carafe isn't the same amount you'll get out of the coffee maker, as some of the water is normally lost as steam vapor during the brewing process.
I would also look at the water level gauge inside the reservoir or on the sight gauge to make sure I have added the right amount to make the amount of brewed coffee I want.
As to the filter pre-soaking issue, it shouldn't matter since you likely made several pots since then and the filter has likely expelled any residue already. I would run a full pot of just water with a filter in the basket, just to see if you're getting a full carafe after brewing, making sure you have a full reservour to begin with.
As to the grind of the coffee, I find that a medium coarse is best for all but expresso coffee. However, you might want to experiment with your grind settings until you find the setting that makes the coffee to your likeing and taste. Coffee is all about what you like to drink, so take some time to find what you enjoy.
I use a high-end filter for all my drinking and coffee brewing water to get the best possible taste as it does make a difference.
My nieighbors have the same coffee machine and use the same coffee brand, etc., but don't filter their water. They've noticed the difference and always comment that they need to get a filter for their water.
When I run white vinegar thru my machine, I always run at least two (2) full pots of plain water thru the unit before I start making coffee again, to rid the reservoir of any vinegar residue.
Hope you find this helpful and best regards!
Aug 06, 2009 | Cuisinart DCC-1200 Coffee Maker
Red water light is flashing
Check your water flowmeter. Check the turbine is not scaled or clogged.
Apr 24, 2009 | Saeco Magic De Luxe Espresso Machine
Water flow problem
Check the coffee chute to see if its clogged. It is easier to use a small amount of white rice to clean your grinder, about a teaspoon.
Feb 22, 2009 | Solis Master 5000 Espresso Machine
Saeco Royal Professional Espresso Machine Logo
149 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
