Question about AutoFlo 250 Humidifier
Water flow regulation
Good morning,
I have a Autoflo Humidifier model 250 on my 20 year old furnace. For years I have had two problems: The water flow comes out so fast it overflows onto the floor - I have tried to regulate this over the years with the saddle valve (I read in a installation manual that this is not appropriate). Second, when the selenoid valve closes, it makes a loud CLUNK that resonates through the house. Probably due to the high water volume going through and what seems to be a quick shut off by the selenoid.
Can you help me? The manual instructions say the valve has a metering orifice in the valve - would I see this if I took it apart? Do they make a selenoid valve that you can adjust the water flow or put in a smaller orifice? For the loud knock, do they make a valve that closes slowly instead of rapidly? (Although I'm thinking if I can lower the water flow the knock may go away) .
Rich
5 Suggested Answers
SOURCE: Water supply to selenoid is OK, but no water from selenoid to uni
Try to clear the small pinhole in the fitting leading into the selenoid. Sometimes this gets blocked with dirt or sand.
Posted on Dec 26, 2008
  • 232 Answers
SOURCE: in furnace auto flo humidifier
turn off the water to your house and replace the saddle valve. you should be able to ge from any hardware store
Posted on Sep 13, 2009
  • 415 Answers
SOURCE: What is the saddle valve?
Your humidifier will have either a copper or plastic tubing attached to it. This tubing is the water tubing. If you follow that line to where it "taps" into a water line (near the water heater or a water line under your house), there should be a water shut-off valve. The water shut-off valve could be any type of valve but is normally a saddle valve. You could skip the step of shutting off this valve; however, it is good practice to shut the valve off for two reasons: 1. in the event of a water leak, you will be able to easily locate the valve to shut off the water. 2. if the valve is not "excercised" from time to time, the seals will dry rot and the valve will not be capable of doing it's job when the need arises.
Here is a video showing you how to trace your water line to your saddle valve. There is additional information on the video that you might find helpful as well.
Posted on May 07, 2010
  • 1033 Answers
SOURCE: My furnace is leaking when the air is on and the
Hello, the motor itself wont cause the unit to leak water, the float valve on the unit is what adjusts how much water is coming into the humidifier. If the float valve is not adjusted properly or broken it will cause to much water to enter the humidifierand therefrore overflow. Replace the motor and chexk the float valve to enure it is adjusted properly and if it is stuck or broken replace.
Posted on Jun 15, 2011
Water leaking / running from top of humidifier
humidifiers have a drain and if there is water going in it will be coming out the drain. check drain to see if it is clear, check hoses going into top of humidifier for cracks, check filter in humidifier.
Feb 05, 2014 | AutoFlo 250 Humidifier
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
Nov 06, 2013 | Aprilaire 700 Humidifier
My furnace is leaking when the air is on and the motor in the autoflo 800 humidifier is bad. Could this be the problem?
Jun 15, 2011 | AutoFlo 800BP Humidifier
The AutoFlo 2000P unit ( 12 years old ) on my furnace is leakng water from the drain spout, which it had never done before. It also is emitting sounds like a low clicking or grinding sound. Where is the...
Tim, they're are generally not hard wired. At least, by today's standards. They're usually plugged into a receptacle. If that's not the case with yours. Open the lid and lift the float valve and tie it some way that can't lower. That will stop water from entering the humidifier tank and it should stop working. Also, look for the water line shutoff valve and turn it OFF. That way, you can be double sure it will stop running.
Hope this helped you to turn it off.
Apr 30, 2011 | AutoFlo 200P Humidifier
Just moved into home with a250 mumidifier. water not getting to unit. It's turned on.
Is the water supply on? If you have a voltmeter, check for voltage across the solenoid valve leads when the furnace is heating. If you have voltage, but don't hear a click when the furnace turns on, suspect faulty solenoid.
Dec 09, 2009 | AutoFlo 250 Humidifier
We just bought a home with this humidifier installed on the furnace. There's no activity when the furnace is running. The water is connected but does not flow. Could this be a transformer problem? We guess...
Could be a couple of things. Transformer can be bad. Try connecting the two wires (usually wired red and white) from the transformer to terminal W and C on the circut board. Your bypassing the transformer and if installed a current sensing relay. The furnace transformer will/should handle the extra load. Turn on the furnace, if still not working, loosen the water supply line at the water solenoid on the humidifier, if water flows out then your supply valve isn't clogged, if no water then try screwing in the needle on the supply valve all the way in then back out. If still no water then the valve is clogged. If all is good then it looks like the water solenoid is bad or wiring to valve/humidifier control. Don't find the controls bad that often. Have fun!
Nov 28, 2009 | Honeywell HE260A1010 Whole House...
No water going to furnace humidifier
The furnace should be equipped with a #50 relay to turn the Humidifier on and off when only when the furnace blower is on. You should have a test mode on your humidistat. Do you have water coming up to the solenoid valve? Make sure that the saddle valve is turned on to supply the water to the humidifier. Is your humidistat set high enough to turn the humidifier on? Is it plugged in?
Good luch
HVAC Teacher
Mar 04, 2009 | AutoFlo 400BP Humidifier
Water keeps running to Honewell 360A Whole House Humidifier
You may need to replace the valve that is wired to the furnace that controls the water flow
Feb 01, 2009 | Honeywell HE360A1027 Whole House...
Cleaning a furnace humidifier steel filter?
Most water panels are generally replaced once a year on flow through humidifiers.
Dec 20, 2008 | Honeywell Power Humidifier: Furnace...
Aprilaire 600 Humidifier
J-
I had this problem several years ago. In order for the water to flow, the outside temperature sending unit must indicate to the controller that it is less than 60F. If not, the unit will not operate outside of test mode. Check the temp outside where your sending unit is (could the sun be heating that side of the house?) and ensure that the circuit to the sending unit is working. I had a bad wire splice inside a wire nut stopping the circuit. Took me a long while to figure it out.
If the outside temp and your sending unit circuit is ok, I wish you luck on your troubleshooting.
adx_98
Nov 10, 2008 | Aprilaire 600 Humidifier
AutoFlo 250 Humidifier Logo
66 people viewed this question
Top AutoFlo Humidifiers Experts
Paul Carew
Dennis
Are you an AutoFlo Humidifier Expert? Answer questions, earn points and help others
