Question about Samsung Digimax L730 Digital Camera
Digimax Master Dear guys I have installed trhe Digimax Master software on my Vista laptop but have not been able to run it. It works perfectly on an older XP version laptop Please Can you help
  • 1 more comment
  • Anonymous Jul 20, 2008
    same problem, my digimax software worked perfectly on my xp laptop but wont work on the vista although it was successfully installed
  • Uppalz Dec 12, 2008
    I have the same problem. I have updated my windows vista but still same thing keeps happening.
  • Anonymous Mar 29, 2009
    I also have that problem. My Digimax software worked perfectly well on my XP laptop but not on Vista!
    Mugsy
  • 27 Answers
Vista has some bugs in it ....it is in the rectifying stage .......not only that it wont support many......it will be proper when microsoft releases a new service pack
Posted on Mar 22, 2008
6ya staff
SOURCE:
My Art Explosion Greeting Card Deluxe Factory 2 software will not work on my Toshiba Satellite A200 laptop. I am using Windows Vista. Please can you advise?
Unfortunately the Windows OS has changed significantly since that software was released. Nova Developement now has the Greeting Card Factory Deluxe version 8 for XP/Vista/7.
If you have the 64-bit Vista, you may not be able to get the old software to work and need the upgrade or a virtual computer with an older Windows OS (see below). To check your OS version, click Start > Control Panel > System and Security > System .
You can try running the program in the compatibility mode - this will work best with software for XP not Win95-NT. Right click on the installer and select Properties. Go to the Compatibility tab and choose Run this program as compatible with (an older version of Windows). Click on the check box and use the drop-down menu to select the older OS. Save the change by clicking apply then close the window. Right click again on the installer and choose Run as Administrator.
If the program installs, do the same compatibility steps for the program's exe file itself. (You don't need to run as administrator though.)
Alternatively, you can run a dual boot or virtual computer with an older Windows OS. (Programs like Virtual PC, Parallels and VMWare let you run a virtual computer inside the Vista system with a computer that can handle virtualization.) Unfortunately, you usually need a licensed version of Windows to do this. (Win7 Pro and Ultimate let you do this free with Virtual PC and XP mode.) Then install the software normally in the virtual computer or when booted into the older version of Windows. File transfer can be tricky with the virtual computer - you need to save files to external media (flash drive or optical disc). Printers can't be installed on both the real and virtual computer at the same time.
I hope this helps.
Dec 28, 2010 | Nova Development Art Explosion Greeting...
I have lost my software for Epson Perfection 1260 Scanner. I need to install in my new computer with windows 7. How?
go onto epsons website and download the driver or the installation file/ folder then process with any insruction enjoy
Dec 18, 2010 | Computers & Internet
Hello guys....i have Vista basic installed on my compaq C 740 TU laptop.....i wish to install windows Service Pack 3 on my machine.....but whenever i insert the XP cd and boot from it.....it fails to...
From what you're saying I get that you want to install Windows XP with Service Pack 3 on your computer. Are you wanting to replace Vista, or do you want a dual boot system? Do you have a Vista CD as well if you want a dual boot system? Did you receive any other disc's with the computer that may have a driver set on it?
Jun 10, 2009 | Compaq Presario 700 470024-192 Notebook
Windows XP
use a vertualization software "vmware workstation" and you would be able to work on xp without installing it physically. this software is used to run several operating systems at one time.
link is http://www.vmware.com/products/ws/
you can use the trail version for 30 days
Jan 21, 2009 | HP Compaq 6720s PC Notebook
Need software for olympus fe-190 for vista
To learn about the new and free version of Olympus Master 2 software go to: http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp Click on 'Free Download' to register your email address to receive an email containing a link to download either the Windows or Mac version. This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x and is Vista compatible.
Dec 25, 2008 | Olympus FE-190 Digital Camera
Hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
try to download belarc advisor software. Run this in your vista OS and send it to me so I can check your hardware specs. This is the only way to avoid problems in the future or before you start the formatting.
Dec 01, 2008 | HP Pavilion dv6000z Notebook
I am trying to install my software on my new computer, ia the Windows Vista
Read the system requirements of the software...if it is software made for another operating system ..... Most programs written for Windows XP also work in this version of Windows, but some older programs might run poorly or not at all. If an older program doesn't run correctly, use the Program Compatibility Wizard to simulate the behavior of earlier versions of Windows.
• Open the Program Compatibility Wizard by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
NoteTo find out if your programs (or programs you plan to buy) are compatible with Windows Vista, go online to the Windows Vista Compatibility Center. This website contains a comprehensive list of programs, computers, and devices that have been tested to work with Windows Vista.
Oct 23, 2008 | Computers & Internet
Downloading bernina
Hi, Unfortunately any of Bernina's software that is older than Version 5 , will not work with Vista. There are some software patches available on the berninausa.com web site, but there is nothing out there that will help you if you have any Version 4 software or older. Microsoft really through out a curveball to everyone with VISTA as there is a lot of software out there that will not work in that operating system.
Actually the lowest cost solution would be to get a nice used computer that runs Windows XP. You do not need a super fast, state of the art computer to run embroidery programs.
I bought a nice used computer at a yard sale for $10.00 and it even came with the XP install disk. I replaced the hard drive just because they do wear out after a few years, installed XP in it ann that computer is now in my wife's sewing room and it is only used for her embroidery work.
You might have a computer repair shop in your area where you can buy an older XP computer that has been reconditioned. The few dollars you would spend to get an older computer would cost you far less than buying new Bernina Version 5 software. Good luck...bushvideo
Sep 16, 2008 | Bernina Artista 180
Sftware
Hi, Unfortunately any of Bernina's software that is older than Version 5 , will not work with Vista. There are some software patches available on the berninausa.com web site, but there is nothing out there that will help you if you have any Version 4 software or older. Microsoft really through out a curve ball to everyone with VISTA as there is a lot of software out there that will not work in that operating system.
I bought a nice used computer at a yard sale for $10.00 and it even came with the XP install disk. I replaced the hard drive just because they do wear out after a few years, installed XP in it and that computer is now in my wife's sewing room and it is only used for her embroidery work.
You might have a computer repair shop in your area where you can buy an older XP computer that has been reconditioned. The few dollars you would spend to get an older computer would cost you far less than buying new Bernina Version 5 software. It is EXPENSIVE! Good luck...bushvideo
Sep 11, 2008 | Bernina Artista 180
I have just brought a bernina 180 embroidery machine with v2 softare but am unable to open it on my laptop which is run by vista home basic. Was wondering if there is a patch to download, i have been into...
Hi, Unfortunately any of Bernina's software that is older than Version 5 , will not work with Vista. There are some software patches available on the berninausa.com web site, but there is nothing out there that will help you if you have any Version 4 software or older. Version 2 was made back in the Windows 98 days but it should install in a XP computer but you are out of luck with Vista. Microsoft really through out a curve ball to everyone with VISTA as there is a lot of software out there that will not work in that operating system.
Aug 25, 2008 | Bernina Artista 180
Samsung Digimax L730 Digital Camera Logo
364 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
