Question about Logitech diNovo Edge 9676850403 Keyboard
Connection disappeared as i hold it in my hands (before even log in to my computer) i did press by mistake the "connect" button in the back side. Right after that nothing did work. As if the connection dropped out. I switched off and on. Nothing. I pressed again the connect button. Nothing. I can even log in to my computer. What should i do???
  • danian May 09, 2008
    works when in the base, however no connection out of the base.
  • Anonymous Jun 07, 2008
    same problem
My solution to this has been to unregister the keyboard with my computer, and then re-register it. It happens on both my Windows machine and m macintosh. So I suspect that somehow the keyboard just gets confused at some point.
Posted on Jul 17, 2008
SOURCE:
System battery is low
Dear Anonymous,
BEST PRACTICE: Buy an anti-static wristband before going "under-the-bonnet! Many people will advise that it is ok to delve around the insides of a computer without one, but that can be an expensive mistake...when they only cost a couple of bucks & can save you the trouble & expense of zapping ex$pensive hardware. Your computer box contains extremely sensitive chips & the human body can store up to 50,000 volts of static electricity...
TURN POWER OFF AT WALL SOCKET! [But leave plug in wall socket - this will extend power-system earth to the box.] Then press & hold power-on button on front of box case. (This will "earth" the system.)
Open computer box: Most Dell tower/mini tower boxes have a slider on the back panel: hold slider open & slide side of case backwards.
Find a non-painted - (bare) - metal connection point for wristband alligator clip inside box. Attach clip. {N.B.: if you do this procedure WITHOUT an anti-static wristband, be sure that you "earth" your body, by holding on to the bare metal connection point for a few seconds!} Locate the cmos - (or "BIOS") - battery. It will be a button-shaped battery. Check "Polarity" - (which way up) - of old battery. 'Eject old battery from holder. Check battery TYPE - (make sure that new battery is identical/equivalent. Push new battery into holder. Remove wrist clip. Replace side-cover. Power on. Reboot computer. N.B.: If asked during bootup - restore BIOS settings to "default". That's it! I hope that this solves your problem. Kind regards - 'b'ye - Bruce.
Jul 31, 2014 | Dell OptiPlex Computers & Internet
Where is the wps button
https://www.manualslib.com/manual/382487/D-Link-Dcs-932l.html?page=13
Apr 08, 2017 | Motorola Computers & Internet
Wireless network connection ,says that no wireless network were found in range
Look on your function keys there could be a radio tower symbol. If you have one press and hold the FN button ( left side on the bottom of keyboard ) and then press the button with the tower on it that should turn on / off your wireless. you may also have a switch on the sides or front which maybe turned off also check for that.
Apr 25, 2012 | HP Compaq nc6000 Notebook
Internet connection disappears.
You may either need to do a firmware update, or reset it back to factory default, you can download the firmware from the netgear site, or you can log onto the router and do a reset of the router.
Hope this helps,
Daid
Mar 15, 2009 | NetGear WGR614 Wireless Router
My sansa mp3 says connecting. It's not connected to anything and
Try the following:
1. Make sure the Sansa is turned on.
2. Engage the hold switch, located on the left-hand side of the player.
3. Press and hold the LEFT BUTTON ( << )
4. Connect to the computer while pressing and holding the LEFT BUTTON ( << )
5. The Sansa should appear as a "Removable Disk" on your computer (My Computer)
Jan 07, 2009 | SanDisk Sansa MP3 Player
Dir-615 router not resetting
Hi there, and welcome to FixYa,
You have either set some kind of security on the computer or the router.
Best reset the router by pressing and hold the small inside boten on the back for 30 sec. first,
then if still no connection,
If its winXP, Start -> Settings -> Control panel, and find internet connection
open wireless connection, right click, go down to the bottom one (dont know it in English).
Chose Wireless network, delete you wireless connection, press the boten show wireless network, find yours and connect if it hasn't already done so itself.
Now you have a very open wireless router, do start to set a admin password, and what ever you do from here ON the router, you must do on the computer also.
DO NOT ATTEMPT to do this on a wireless connection, use a cable.
/Teis the Wiz
if this help you, please vote "FixYa"
Dec 05, 2008 | D-Link (DI-711) Router
Missing network connections
Press control panel.
Select network connections.
Select setup a home or small office connection.
Follow the instructions on the screen.
Aug 21, 2008 | Microsoft Windows XP Home Edition
Rene
hi Rene,
Seems like there is a problem with your router because as you mentioned the wireless light disappeared with no apparent for reason. Try to do a reset on the router.
1. Power off the router then by using a paper clip or a pen press the reset button then put the power back in while holding the reset button.
2. Continue pressing the reset button for 15 seconds, release the reset button and wait for the router to restart.
3. Access the setup page of the router using internet explorer(type: 192.168.2.1 on the address bar), user name is "admin" and leave the password black
4. On the router setup page, click on the connection type on the left hand column and under WAN internet heading, make sure that it is set to "Dynamic".
5. Click "submit" and go to Home tab and check if the connection say's "connected"on the internet status.
Hope this will help you solve your connection problem.
Regards,
Aug 06, 2008 | Belkin (F5D5231-4) Router
Logitech diNovo Edge 9676850403 Keyboard Logo
278 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
