I have a Frigidaire PLHS67EEB4. I can't see how to disassemble the ice and water housing to replace lever. There are no visible screws or fasteners.
SOURCE: frigidaire frs26zsh ice dispenser problem
It should hook in on the front side of the dispenser towards the door first and then at the back as you would slide the tray in. Check to see if the grooves line up in the back where the motor sis to turn the wormgear. good luck
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
SOURCE: FRIGIDAIRE SIDE BY SIDE ICE DISPENSER
I have this issue too. Its in the dispenser bin. The auger in the back moves fine, but its not turning up front and spitting out the cubes. Gonna pull it apart and see what is up.
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Hey friend, thank you for your inquiry!
From my understanding you were replacing the water dispenser on your Frigidaire refrigerator and the ribbon cable disconnected. I would suggest a generic search online for any additional information regarding the ribbon cable. I was unable to locate that information for you. Additionally, if you continue to have problems I would consult with a professional technician for proper attachment of the cable. Best of luck! -Matt
Hi -I understand that your unit is still not producing any ice or dispensing water. Some of the following steps you have already confirmed. I suggest confirmed the steps below and see if any is helpful :
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
