Question about Asrock P4I45GV R5 Motherboard
Please help me
1. when clear cmos by jumper setting no display show on monitor or no any beep but when remove momery they give beep
2. when i open cmd open only system32/cmd.exe and when i open msconfig nothing show.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 156 Answers
Hi
Check ASROCK P4i45GV R5.0 User Manual Page 17 - http://download.asrock.com/manual/P4i45GV%20R5.0.pdf
Note: Check Page 11 for the CLRCMOS0 location on the motherboard. From the picture CLRCMOS0 is number 18. You can locate CLRCMOS0 just below the CMOS Cell Battery.
Turn off the computer and unplug the power cord, then use a jumper cap to short the pins on CLRCMOS0 for 3 seconds. Please remember to remove the jumper cap after clearing the CMOS. If you need to clear the CMOS when you just finish updating the BIOS, you must boot up the system first, and then shut it down before you do the clear-CMOS action.
Regards
Mike
Posted on Mar 22, 2008
SOURCE:
I'm faced with a black monitor, no boot beep, with an operating fan and green light on. XP OS with an ASUS P5P800S motherboard, Thanks Jose
Remove all components from your mb and bios battery. Place jumper to clear cmos and make short to battery cmos. Leave 1min and after place cpu and one ram in mb. Replace jumper from clear cmos in normal position and verify. If not display, change ram.
Sep 26, 2014 | Computers & Internet
No video out
If you get a beep when you turn on the computer that means its working, multiple beeps indicate an error, no beeps at all mean that the processor is not initiliazing..
TRY
turn off computer and unplug it
1.) locate the jumper called or labled jp1
2.) its a 2 pin jumper and is currently set to 1 and 2
3) set it to 3 and 4
4.) set it back to 1 and 2
5.) try turning on the system
if you cant locate the jumper or yours is different what we are trying to achieve here is clearing the cmos. this can be done using the jumper or
1.) unplug your system
2.) remove the memory
3.) remove the battery
4.) press the power button 5 times to discharge the capicators
5.) replace batter
6.) replace memory
Try booting it now
if the above fails
try taking out your processor and putting it back in
if your mainboard has a clockspeed setting ensure it is set according to your porcessor clock speed (look at manual for details)
ensure you got all the necessary power cables connected
If you had the problem before you changed our processor then it night have been your mainboard that needs changing.
If you have a video card,ensure that the monitor is plugged into your videocard and not the onboard video the mainboard comes with.
Try your processor on another system to ensure its working, just cause it new doesnt mean it is good.
You can try clearing the cmos multiple times with the memory pluged in or without the memory to see if that helps
if all else fails then ensure you check the processor , only if the processor is good replace your main board..
Jan 06, 2008 | HP (5064-6630) Motherboard
Changed cpu on packard bell imedia d3318, still getting no signal on monitor and no beeps. When I remove the cpu and power on, there are no beeps
Have you check with different RAM, Did you try to reset BIOS by removing the CMOS battery and shorting CMOS jumper? Your Processor may be ok but you are plying with it. When there use to be no display then first thing you should doubt with the CMOS battery and the RAM and Motherboard, rather then CPU, CPU hardly gives problem.
Aug 14, 2012 | HEWLETT-PACKARD Computers & Internet
I am facing a problem to install my XFX Radeon HD 4350 1GB graphics card. My PC has a intel DG31PR with core 2 duo and 3 gb ddr2 RAM. the CPU starts but there is no visual on my ACER monitor. I have...
It sounds like you need to change a BIOS setting. I don't have this MoBo, but on others there is a toggle to make the integrated graphics primary or secondary. You would need to change it to secondary. On this card this should happen automatically - so check BIOS settings and that your new card is properly seated in the slot.
From http://www.intel.com/support/motherboards/desktop/sb/cs-022225.htm
Installing External Graphics Cards
If you want to install a 3rd party external graphics card instead of using the onboard graphics, follow these steps:
  1. Install the 3rd party external graphics card, following the installation instructions that come with the card.
  2. Integrated graphics is automatically turned off.
Jan 10, 2011 | Intel DG31PR Motherboard
Tenho uma placa mae ibm 49p1599 mas nao esta entrando o windows xp erro na inicializacao
If power to your computer is interrupted while BIOS is being updated, your computer might not restart correctly. The Clear CMOS/Recovery jumper enables you to restart the system and recover the BIOS. To perform a Flash/BIOS recovery using the Clear CMOS/Recovery jumper, use the following procedure: Before proceding, be sure to review the safety information.
  1. Turn off the computer and any attached devices, such as printers, monitors, and external drives.
  2. Unplug all power cords from electrical outlets, and remove the cover.
  3. Locate the Clear CMOS/Recovery jumper on the system board.
  4. If necessary, remove any adapters that impede access to the Clear CMOS/Recovery jumper.
  5. Move the jumper from the standard position (pins 1 and 2) to pins 2 and 3.
  6. Replace any adapters that were removed.
  7. Replace the cover.
  8. Reconnect the power cords for the computer and monitor to electrical outlets.
  9. Insert the POST/BIOS update (flash) diskette into drive A, and turn on the computer and the monitor. The system will begin to beep.
  10. After the update session is completed, there will be no video and the series of beeps will end. Remove the diskette from the diskette drive, and turn off the computer and monitor.
  11. Unplug the power cords from electrical outlets.
  12. Remove the cover.
  13. If necessary, remove any adapters that impede access to the Clear CMOS/Recovery jumper.
  14. Return the Clear CMOS/Recovery jumper to its original position.
  15. Replace any adapters that were removed.
  16. Replace the cover and reconnect any cables that were disconnected.
  17. Turn on the computer to restart the operating system.
  18. You may now want to update the BIOS normally. Refer to the readme.txt file that came with your flash BIOS update.
Nov 30, 2010 | IBM NetVista PC Desktop
When power up all i get is the beeps and blank monitor and no lights on the key board. The lights remain green after the beeps stop
King of beeps is important. Most probably a faulty video card or RAM memory. Could be just a bad connection due to dust in the slot. While checking, be careful not to cause additional damage by static electricity, i. e. turn PC off but leave the power cord in to keep chassis grounded, also touch something connected to ground to discharge your hands, touch the components only on the edges.
Nov 11, 2009 | Dell Dimension 4700 PC Desktop
Ge pro-ht it beeps three times long
Or reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defualts.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Nov 11, 2009 | Asrock GE Pro-HT R3 Socket 478 Motherboard...
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
I recently upraded my computer with an Asrock Penryn1600SLI-110dB motherboard with an Intel CORE 2 DUO E4600 processor. The symptoms are: When I tried to boot for the first time the cpu and case...
If you have recently upgraded your motherboard and when you turn it on, there is no display. You could check the jumper setting of your motherboard.
http://download.asrock.com/manual/PENRYN1600SLI-110DB.pdf
Check this site for jumper settings. Download the manual. Go first to page 11 and find clear CMOS jumper. That will be number 17. Then go to page 24 for the correct jumper settings. Jumper should be on the pins 1 and 2. That's the default settings.
If the jumper is set already to 1 and 2. Clear the CMOS by putting the jumper on 2 and 3. It should be off when you are going to set the jumper. This is to make sure that the settings for your motherboard is set to its original settings.
If you are going to clear the CMOS settings, you will have turn the computer on after clearing it and then turn it off again. Put the jumper back to pins 1 and 2. Now make sure that computer is totally off. Uplugged the computer just to make sure when you are doing this.
Note:
To test also the motherboard if it is working, do not connect the other pheriperals such as network card, sound card, and other cards that is not buit-in. Also drives such as Hard Drive and CDROM drives.
Check for beep codes. Short beeps tells you that the Video card is not inserted properly. Long beeps tells you that the memory card is not in place correctly.
Just remove the Video card or Memory card and then place it back again.
Computer should be off as well when doing this.
Sep 09, 2008 | Computers & Internet
No beep,No Display on my monitor,only CPU heatsink fan is moving
try to clean your video card and ram using the eraser.
Mar 17, 2008 | ASUS P4VP-MX Motherboard
Asrock P4I45GV R5 Motherboard Logo
284 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
