Question about Karcher 2500 PSI Pressure Washer
Car I have a 1994 Toyota Carolla 160iGL .When my car is cold,it wont longer than 6 seconds.I had numerous mechanics look at the car,with no satisfaction gained.Please help
  • 33 Answers
You may have a plugged choke bypass port on the upper side of the carb opening. there is a little sensor that plugs into the side of the port and that is what shuts the engine down because there is no flow of air. i drilled a small hole in the choke butterfly bypassing that port. worked fine.
Posted on Apr 21, 2009
My 1994 carolla was startin ruff now wont start
ever to a 60k mile tuneup this decade?
cranks but dont start,? yes (which engine is it, (options)
got spark to all cylinders?
Jan 19, 2014 | Toyota Cars & Trucks
My car wont start but the radio and everything works, its a 2000 toyota carolla
you try to clean and tighten the battery terminals. if it don't start then, hit the starter, they stick sometimes
gm tech2
Jul 27, 2012 | 2000 Toyota Corolla
1994 corolla doesnt stay idled while driving and cuts off
I had the exact same problem with my 1994 Carolla. It was the MAP sensor needing to be replaced, cost me about two-hundred. The car has been running fine ever since. (That was over 2K miles ago).
Mar 19, 2012 | 1994 Toyota Corolla
1994 toyota carolla with big dent on driverside back quarter panel, is it one big piece or is it a quater panel?
Quarter panel , it's quite a job. Ask the body guy to show you your car when he's in the middle of the job.. You will have a better understanding ..
Jan 03, 2010 | 1994 Toyota Corolla
Need the torque settings for a toyota carolla
1st stage 25Nm or 18.5Ft-Lb. 2nd stage 50Nm or 37Ft-Lb. 3rd stage 65Nm or 48 Ft-Lb Torqueing sequence: <-- Front 8 6 1 3 9 10 4 2 5 7
Jun 13, 2009 | 1983 Toyota Corolla Deluxe
Prerunner wont pass smog due to engine service light
Not positive on this so consider only. The o2 sensor is what actually tells everything else what is going on with emmission and everything else adjusts to what info it relays. The o2 is also subjected to extreme temps and cooling cycles. So, instead of spending money on no answer diagnostism give replacement of o3 sensor so consideratio. If you choose to replace, wd40 and let exhaust cool down. Good Luck.
May 07, 2009 | 2000 Toyota Tacoma PreRunner
Try this:-
Theres a vaccum pipe tht fits on the brakes booster just under the mastercylinder probabely it may have popped out or the sensor could be faulty ....worth a try ;)
May 07, 2009 | 1991 Toyota Pickup
Valve clearances Toyota carolla
the valves clearnces are: Inlet- 0.20 cold & Exaust- 0.25 cold.
Apr 20, 2009 | Toyota Corolla Cars & Trucks
Carolla stereo wont turn on..
Have you checked the fuse? Looks like ther is no power coming to the radio so best bet it's the fuse.
Nov 09, 2008 | 2004 Toyota Corolla
Toyota Carolla 1992
Hi there, there are numerous possibilities on what it could be so i have listed below in order to change first cheapest to the most expensive. 1. Change Sparkplugs and leads 2. Get an auto electrition to check your altinator it may need changing 3. If your car is EFI (Electronic Fuel Injected) change the coil pack, if not EFI change or recondition your distributor 4. Could be a sensor or a solinoide problem 5. If its EFI it could also be the ECU/ECM which means your computer for the car.
Oct 01, 2008 | 1994 Jeep Grand Cherokee
Karcher 2500 PSI Pressure Washer Logo
62 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
