Question about Hotpoint Ultima WF865 Front Load Washer
Hotpoint wf865 problem
Washing programs will not run. Display is showing TEST - the running the spin cycle - no water is being pumped into the machine. Nothing is flashing on the display.
  • 1 more comment
  • Rach1 Apr 26, 2008
    I have the same problem and ive tried to switch it on and off but I cant do anything???
  • Anonymous May 19, 2008
    i have same problem, any suggestions welcome
  • donnalou68 May 03, 2009
    'TEST' IS DISPLAYED AND WASHER DOES NOT WORK AT ALL
    President:
  • Hotpoint Master
  • 662 Answers
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Pl rate me nice if this solution helped!
Posted on Jun 08, 2010
Cotton program stuck on wash cycle with 1 minute left
Control board needs to be replaced. Many times the control boards go bad because of a spike in the electrical grid cause by a brown out, lightening strike or even a surge in the power. After the control board is replaced... I suggest using a surge protector on all of your electronic devices including the washing machine.
Feb 06, 2014 | Hotpoint Ultima WF865 Front Load Washer
The machine runs but won't spin.
Does water remain in the machine at the end of the wash cycle? Does the water pump run when it is supposed to? If not, the pump may be jammed with debris or the motor is defective. Can you drain the water by lowering the drain hose to floor level and into a bucket or pan? Does this allow the spin cycle to proceed? It is normal for the machine to test for spin balance (it will agitate further if it is not balanced). Hope some of this helps!
Apr 09, 2010 | Hotpoint WMA32 Front Load Washer
Hotpoint washing machine - WF865 showing F-08 fault
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Jan 23, 2010 | Hotpoint Ultima WF865 Front Load Washer
Washing machine stuck in test mode hotpoint wf865
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work. hope this helps.
Nov 22, 2009 | Hotpoint Ultima WF865 Front Load Washer
Test mode
press start once
then press start again now hold on/off and cancel together for a few secs should no say d/off or something should work now
Aug 22, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint WF645 error message: test
press start once then press again then hold on/off and cancel for a few seconds should now turn test off should be ok now
Jul 15, 2009 | Washing Machines
Display problem
this is joyce
you may need to call a technician if you have a board out. if you need assistance in finding someone in your area please let me know,
thanks,
joyce
Feb 06, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint wf865 washing machine
to take out of test mode you must turn it on while pressing the start/cancel and on buttons at the same time until dOFF appears.
Jan 18, 2009 | Hotpoint Ultima WF865 Front Load Washer
Error code on display panel
F-12 is a drain problem.
Check if the drain hose is free, if cycle stops and gives you f12 without draining the water, there is a problem with the drain system.
The Hotpoint should have a removable paner at the back on the lower side. The panel gives access to the pump. If cleaning the drain hose does not solve the problem, the pump must be removed and cleaned or replaced.The repair should be done by a technician.
Dec 14, 2008 | Hotpoint Ultima WF865 Front Load Washer
Ultima WF 840
try unplugging from wall hold down start button for a few seconds leave unplugged for 10-15 mins reconnect and ckif problem still there may be control bd problem ..first call the sales person you bought if from ..some washer have a demo mode for floor display use may be a way to back out of it
May 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF865 Front Load Washer Logo
306 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
