Question about ASUS A8N-SLI Motherboard
Asus a8n sli deluxe not powering up
Recently my pc won't turn on when I hit the button. After messing with it over the past couple days here is what I've determined is working... ram is fine and in the right slot cpu is fine vid card is fine psu is working properly switch on the case works and pins it connects to are fine I can even manually jump the computer to get it to startup and everything runs fine. But, when I press the switch on the pc there is some step in between the connection being sent from the switch to the board that stops it from powering up. Any and all help is appreciated! Ps. I've already tried resetting the cmos, didn't work. after windows has shut down the mobos lighs and fans keep going, then when i pull the plug it takes 3 or 4 trys to get windows going again, it keeps crashing on the windows xp logo at start up.
  • 93 Answers
Do you have 2 sticks of ram in the pc?
if so try it with one in and do this with both
as in boot it with a single ram stick and try to determine if its a faulty ram stick
also if you can try another power sup unit
please let me know how you get on
Posted on Mar 22, 2008
  • Ty Rose Dec 17, 2012
    I am not the original poster but I tried the suggestion and my PC is now working. Thanks for posting.
I've run across the same problem with this motherboard. It was the fan going bad on the chip cooler for the motherboard.. (the one labelled Asus on it). The fans are known problem . replace it a non Asus fan. It work fine after that..
Posted on Apr 26, 2008
SOURCE:
sandrew
  • 2961 Answers
SOURCE: asus a8n sli deluxe not powering up
Just try switching your power on connection plug to the motherboard the other way round, and check the other connections are the correct way around.
Posted on Nov 12, 2006
  • 138 Answers
SOURCE: ASUS A8N-SLI Deluxe
Try resetting the CMOS, to get the procedures on how it's done on your PC's motherboard, please refer to the image below.
Please reply if this has helped you. Thanks.
Posted on Oct 24, 2009
  • 788 Answers
SOURCE: does ASUS A8N-SLI DELUXE support fan speed
You can research *********** board and drivers at ASUS.com.
You may find a new BIOS update which controls the fan speeds and temp.
If not, you can find plenty of frreware which will handle *********** board.
Posted on Nov 08, 2009
big-dog420
  • 124 Answers
SOURCE: boot usb cdrom a8n sli deluxe
Press Deleate key at boot enter bios goto boot settings set 1st boot devise as usb press F10 and enter to save changes
Posted on Nov 14, 2009
map9966
  • 2351 Answers
SOURCE: Odd PC Build Bootup Problem::
Instead of connecting you're fans to a single 4-pin molex on the power supply why not use the motherboards 3-pin molex fan connectors coming off the motherboard. See page 2.2.4 in your manual. Though I agree you should still be able to run 4-pin molex connectors to all fans off of you're PS. Allow the mother board to supply the 12v current to you're extra fans.
CHA_FAN1
CHA_FAN2
CHA_FAN3
CHA_FAN4
You're motherboard will supply the needed power. Less wiring will also allow better air flow through out the system and less strain to the fan controllers.
4-pin molex to 3-pin female; http://www.avadirect.com/product_details_parts.asp?PRID=11410
OR
http://www.microbarn.com/details.aspx?rid=101317&source=froogle
Happy New Year!
Mike
Posted on Dec 29, 2009
Testimonial: "Very informative and just what I needed to hear, thanks!"
Asus a8n sli deluxe motherboard diagram manual?
Download page.
http://www.asus.com/Motherboards/AMD_Socket_939/A8NSLI_Deluxe/#download
You must choose an OS like XP. Required, but indifferent. Click on Manual and choose Global link.
Oct 14, 2012 | ASUS A8N-SLI Deluxe Motherboard
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
Does ASUS A8N-SLI DELUXE support fan speed changing?
Nov 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI Deluxe Its sudenly shut down and not coming back again only fan is working
Oct 24, 2009 | ASUS A8N-SLI Deluxe Motherboard
Coolmaster cm690 asus a8n-sli deluxe
the boards today have real fine typeset near the connection pins but they are there
Jul 31, 2009 | ASUS A8N-SLI Deluxe Motherboard
Motherboard problem..
It sounds like the front panel wire has either come loose from the motherboard or is plugged into the wrong spot. Recheck the motherboard to see if the wires are in the right place & not loose. Hope this helps.
Dec 27, 2008 | ASUS A8N-SLI Deluxe Motherboard
Ram problems
Your memory should be in slots A-1 & B-1
You Asus board uses the Award bios. The link posted below will tell you what your beeps are saying.
http://www.bioscentral.com/beepcodes/awardbeep.htm
In your case do as I suggested above. I have two working
A8N-SLI Deluxe boards & the memory works fine in A-1 & B-1 slots.
Good luck & best wishes!
please vote.............................
Mar 14, 2008 | ASUS A8N-SLI Deluxe Motherboard
Asus
Download ASUS Update V7.06.02 Install Program for XP before trying to flash your bios.
Download here.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=A8N-SLI%20Deluxe&type=map&mapindex=1
Jan 05, 2008 | ASUS A8N32-SLI Deluxe Motherboard
Describe your ASUS A8N-SLI Deluxe nVidia video card
Yes, you do. Your board was built with the idea to use 2 graphic boards to get great video
NVIDIA® SLI™technology revolutionizes PC performance by combining multiple PCI Express GPUs in a single and scalable system! Gamers and hardcore enthusiasts know that dual GPUs mean increased, supercharged 3D graphics and performance
Dec 09, 2007 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
ASUS A8N-SLI Motherboard Logo
170 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
