Guest
Rank: Apprentice
Rating: 0%, 0 votes
If you want to connect it on a secured connection then do this....
open internet explorer...put in the address bar as :
192.168.1.254 press enter then it will take you to the
thomson page on thomson page on left side click on the last tab
home network....then on the right side under home network click on
wlan it will take you to the new screen on that click on the tab at the top right corner configure on the new page chek that the first option interface enabled is checked...
then 3 options under that you'll find an option of network name ssid clear that box and put in a new name for wireless network it could be anything but not any previous name that you have already used for your wireless network...
three options under that there is another one that is channel selection that is to be on automatic and 2 options under that channel should on 6 if not go back to channel selection and change it to manual then change channel to 6...
2 options under that there is an option of security under that select third one use wpa psk encryption 2 options under that it ask you to put wpa psk key put in a key anything more than 8 characters and apply it...
then open control panel on your comp there you will find an option of network connections or network and sharing center
then double click wireless net connections select your net and get connected...
if any issues revert back...
