Question about Whirlpool GU2400XTP Built-in Dishwasher
Clean ligh is blinking
The clean light is blinking and dishwasher won't operate. this is simply a reset that can be done by pushing the buttons in a certain sequence. got any idea what that sequence is???
  • Anonymous Mar 28, 2014
    The "clean" light keeps blinking and the washer will not operate; I understand there is a "push this bottom, push that button" sequence that will turn the light off. What is the sequence?
    President:
  • Whirlpool Master
  • 2,651 Answers
Youll need to remove the bottom acess panel of d/w there should be an extensive trouble shooting guide tapedto back of panel in a sleeve, lotsa good stuff in there. depending on buttons its going to repuire pushing a sequence. "
sani-rinse---heated dry--sani rinse--heated dry.
it will enter a diag mode "all lights will light up" wait a few secs and then cancel cycle .. if happens a again or with frequency, then call a servicer, you have a problem, first time chaulk up to a fluke
Posted on Mar 22, 2008
How to off on kenmore 665 dishwasher mode or reset the panel
Check user manual or call manufacturer. The unit is not timing out.
Mar 08, 2015 | Kenmore Dishwashers
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
The clean light keeps blinking and the dishwasher will not turn on. have tried to push cancel which makes the clean light blink faster.
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
Kevin
Apr 16, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The clean light is blinking and the dishwasher does not run???
Close the dishwasher door. Push the "normal wash" button, then push the "heated dry" button. Push the "normal wash" button again, and push the "heated dry" button again.Try out his and see what happens.It must reset the memory and your dishwasher must work.
Jul 06, 2010 | Kenmore 24 in. 16352 / 16354 / 16359...
Flashing lights on dishwasher
If it is the clean light only flashing then take a look at the link below, it will have instructions on how to reset the control and what caused the blinking.
If it is other lights blinking then the user interface (console keypad) needs replaced.
Let me know if this helps
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 13, 2010 | Kenmore 16072 - Multiple Color Built-in...
Whirkpool quiet partner 3 dishwasher status stuck on clean. If I press cancel it goes into a 2 minute drain cycle, but there is no water in it. It will no reset or start....just blinks clean.
if you have a heated dry option and normal wash option push those buttons back and forth three times all the lights will come on reseting the board..
push cans. and your done
if this happens again that means you have a bad heater or bad board
Aug 21, 2009 | Whirlpool Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Green clean light keeps blinking
HI, Same thing happened to me today and Sears more than willing to charge me 200.00 for a 1 year service agreement. I found the answer on askmehelpdesk.com and the answer is: To reset a Kenmore Ultra Wash elite series dishwasher (stuck on clean) simply push heated/dry then normal wash and do the same thing again. Panel will reset itself and it hopefully will run normally again. Mine did and I am rejoicing! Julie
Aug 24, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
222 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
