Question about Umax Astra 610P Flatbed Scanner
Download problem i have windows xp on my computer i got this message when i try to download my Umax astra610p scanner (Vistascan has a known compatibility issue with this version of Windows and might not run as expected. The Udnt.sys driver included with the Umax scanner software is incompatible with this version of Windows. For more information, contact Umax.)
  • Anonymous Mar 30, 2008
    I have a UMAX 610 P hooked to a XP system. The scanner works fine with the XP software. Clicking on the scanner under "my computer" works. The Vista Scan software does not recognize the scanner. Even the test program does not work. It cannot find the scanner at all.
  • 807 Answers
Have a look here, you're not alone, but it may be helpful.
http://www.softwaretipsandtricks.com/forum/drivers/4380-umax-astra-610p-scanner-driver.html
Posted on Mar 22, 2008
Umax astra 4400 driver for Windows 7 (64-bit) Help seash driver
To install driver for Umax Astra 4400/4450 on Windows 7 you need to do the following.
1. Install VueScan from http://www.hamrick.com/ - It is only need it for C:\VueScan\scanner.inf with list of drivers
2. Manually install driver from Umax Astra 3400 - You can follow these instructions to install driver manuallyhttp://pcsupport.about.com/od/fixt [...] dows-7.htm
3. Install Umax Astra 4400/4450 software (VistaScan) for Windows XP - Can be found at http://www.umax.com/download/index.jsp
4. Reboot
5. Now you can scan using VistaScan (C:\VistaScan\Vista32.exe), but only the with flatbed option.
This solution is from Russian forum: http://forum.ixbt.com/topic.cgi?id=13:42660#7.
Oct 23, 2010 | Umax PowerLook III Flatbed Scanner
Driver for windows7
Maybe, It doesn't work because the driver you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D
Aug 07, 2010 | Umax Astra 4400 Flatbed Scanner
I just bought a umax Astra 2000 but no download disk what do I do
What OS are you using?
I'll use XP for this,it might work for Vista also.
Go to this link and in the "Notes"section download the Windows XP patch to your computer.
Then go to this link
http://www.driverskit.com/freedownload/Scanner/Umax/Astra_2100U_VistaScan_3_55_USB/14858.html
The 2nd section starts with
You can download driver for Umax Astra 2100U VistaScan 3.55 USB here"
Click on "here" and you'll download Vistascan 3.55.That will extract folders,the setup file should be in folder #1.
Aug 06, 2010 | Umax Astra 2000U Flatbed Scanner
Problem installing umax astra 3400 on xp professional
Make sure you have the drivers for xp. If your unsure you can google them and be able to pull them up. try that and that should take care of the issue.Thank you for using Fixya.com
John C
Feb 16, 2009 | Umax Astra 3400 Flatbed Scanner
My Umax 3400 astra driver is not working in Windows Xp.
dowload vistascan vs375u (11,674KB) and open it you will receive 6 disks+1 disk german and 1 disk english. open the disk 1 and double click VSSETUP you will see a lot of DOS commands and at the end you will have VISTASCAN in the Programs Files ( Start--All Programs--VistaScan--enter) .
If Scanner test works O.K.
if not
- go to MyComputer right click,
- click hardware,
-click device manager,
-right click the UMAX Astra
-click update driver
-click "install from a specific location" Next "Don't search I will chose the driver to install"-- Next -- choose USB scanner (Not UMAX Astra 3400) --Next--
- you will receive a warning " continue anyway" finish
- Reboot.
open VISTASCAN Test it will pass now
good luck
jacques
Nov 29, 2008 | Umax Astra 3400 Flatbed Scanner
Driver Problem
hi sir
i think i must try it in windows xp.
Sep 02, 2008 | Umax Astra 4450 Flatbed Scanner
Download problem
Windows XP supports Astra 610p with its own WIA driver. So to install the WIA driver open the Windows XP controll panel “Scanners and Cameras.
Select the command “Add” and as Manufacturer select “Umax Data Systems”.
Follow onscreen step-by-step instructions to complete the installation for Astra 610P scanner.
May 14, 2008 | Umax Astra 610P Flatbed Scanner
Astrsa 2100U scanner with UMAX Version 3.52U
First, go to the link below and download the Vistascan 3.55 and install. http://www.opendrivers.com/driver/211488/umax-scanner-astra-2100u-vistascan-3.55-usb-free-download.html Next, download and install the Patch for XP from UMAX (link shown below) and you should then be able to see and use your scanner. http://www.umax.com/download/index.jsp Note: the software on the original disk can still be used.
Apr 28, 2008 | Umax Astra 2100U Flatbed Scanner
Umax Astra 610P Flatbed Scanner Logo
236 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
