Question about AEG B2100-4 Electric Single Oven
AEG Oven Hi Had a power spike last night, reset house fuse trip - the display on the oven works - and I can turn the dial to select grill, oven etc and that light comes on - but there is no life from the temperature button. Any ideas (Built in oven)
    Problem Solver:
  • 10 Answers
Try setting the clock, it may be automatic
Posted on Mar 22, 2008
Oven cuts out
I think one of the elements has failed. When hot it shorts to earth, tripping everything out. Examine each in turn
Aug 24, 2013 | Ovens
MAIN HOUSE FUSES TRIPPED, RESET, OVEN AND GRILL WILL NOT HEAT UP
It would appear that the tripping of the switch has caused some kind of short within the cooker. I would look for the continuity of the heating element.
Most likely the wires leading to the heating element have burnt and will need replacement. If you are comfortable with attempting a DIY, well and good. You will have to open the back panel to access the said wires. It should be easy enough to identify..it will be the wire leadingto the heating coil.
If , however, you are not familiar with these kind of things, I would recommend getting a repair guy to do it for you.
Cheers and good luck with the repair!
IrishDruid.
May 26, 2008 | Belling XOU252 Electric Single Oven
My AEG oven does not heat up, nor does the grill work. The oven light and fan comes on when selected but the light located with the temperature control dial does not illuminate. This light normally...
DearDavidgale730,
I am supposing this oven/grille is electric, and is plugged in to a power source.
From your description, I'd say you have a serious problem and should no longer consider turning on the oven or the grille.
Having made that decision, take an electric meter and test the socket or wires that connect the stove/oven to the wall.
See if the current is flowing in both legs of the plug.
(Remember, two are "Hot", one or two are grounded.)
If not, correct the problem with the fuses or circuit breakers that are feeling the appliance.
If so, open the appliance up and test all circuits with that electric meter to determine the problem.
Often the problem may be a bad socket for the oven heater element, a bad element itself, or a burnt wire going to the element socket.
God bless your efforts.
Jul 04, 2017 | AEG B8139-4-M Electric Single Oven
Oven not heating
blue waffle is nice and i like to pop fish up my **** go to google and type in lol fish and then click im feeling lucky and do the same with blue waffle xx good look it could help your oven.
Mar 31, 2010 | Neff B1421 Electric Single Oven
My oven won't warm up. I was cooking some oven chips last night when the electrics tripped in my house. I reset the electrics, however my oven lost its heat and started to cool down. I turned it off and...
The problem will be the oven ele3ent has failed, a very common event.
It is located at the rear of the oven behind a removeable cover.
Make sure you have the power off.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Whirlpool Ovens
Oven not heating, and tripping .Aeg Electrolux
check your heating ellement
Mar 24, 2009 | Ovens
Lights grill and fan work but oven isnt heating up
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
Good luck.
Jan 04, 2009 | Neff U1721 Double circotherm Electric Oven
AEG U7101-4 Top Oven tripping the fuse after a few minutes
It is more than likely the oven element, as it gets
hotter the insulation in the element is breaking down and causing the trip to operate..
Remove the panel at the rear of the oven and you will see the element there, undo the screws and pull the element towards you, carefully, detach the 2 wires and remove the element.
Be careful not to lose the 2 wires behind the oven rear.
Replace with new element.
Cannot give you a part number, you will have to go to aeg web site.
Dec 12, 2008 | AEG U7101-4 Electric Double Oven
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Grill not working fully Oven model 660W
That is due to expansion of the element making the terminal touch the chassis, taking the earth leakage trip out.
Get your oven repaired by a competent electrician.
Sep 16, 2017 | Zanussi ZBF660 Electric Single Oven
AEG B2100-4 Electric Single Oven Logo
606 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
