Question about Car Audio & Video
RELAY SWITCH FOR OPEL ASTRA FUEL AND FAN RELAYS
PART NUMBER V23134 B55 X342
90 494 959
WHERE CAN I BUY HERE IN THE PHILIPPINES?
  • 88 Answers
Hi Opel is a trade mark from GM so you have to find a GM provider or dealer and they'll can order any piece of replacement to your car ;)
Posted on Mar 31, 2008
6ya staff
SOURCE:
Im driving an opel astra j essentia 1.6 2011 model,recently it started jerking or cutting petrol supply, i bought a new petrol pump the problem still persists please assist.
Jerking or cutting fuel supply? How did you determine that? This is most likely a sensor in the engine. Could be a fuel pump relay but it most likely is a crank shaft sensor.
Jan 27, 2017 | Opel Cars & Trucks
Where is the fuel pump relay on 2005 astra 1.6 ?
most cars, (we dont have opels here, thank gosh)
but all cars, this is covered in the FSM , buy one.?
most cars it's located in 1 or the 2 fuse boxes.
most cars it even labeled. or is next to the Fuel pump fuse ,
better yet, why not post symptoms? and not guess the relay is bad.
in fact, if the pump has 12vdc across its pins, cranking, the relay is OK.
one test , in 1 minute with any voltmeter ever made and bingo.
a test done and parts , eliminated for suspicion..
this process is called diagnosis.
no guessing need,
we use simple tools to do simple tests and find true causes of all problems.
May 20, 2014 | 2005 Opel Astra 1.4
Where is the fuel pump on a Astra 2000 CDE
need proper tools to remove filter. ( line pump plyers ) pump is in the fuel tank. would check the relay in the engine bay fuse box first purple top relay should be 2 of them one for the pump and one for the injectors.
Apr 23, 2013 | 2000 Opel Astra
Opel astra twinport 1.6 2006 Z16XE TURNS OVER BUT WONT START
Hi, Have a diagnostic scan done and also a mechanical error trace ,
the solution to the problem could be the CKP crankshaft position sensor or a wiring related issue, it could also be the fuel pump , the pump relay , engine management actuator . In order for your engine to start it requires the following:
Compression
Fuel pressure and volume
A proper spark
Correct valve timing and ignition timing
A decent battery vitally important as all engine management relies on it.
Hope this helps a bit
Regards Higgins.
Sep 14, 2012 | 2006 Opel Astra 1.6
Fan belt diagram 1993 Opel astra
if you go to google it should tell you what it is.. you would have to type in the year model and type of vehical and also the type of motor
Jun 18, 2012 | Opel Astra Cars & Trucks
Hard to start and fuel relay problem
if your burning out relays then renew the fuel pump ,its drawing too much power or the wires are shorting out in the sender unit inside the tank ,these relays are standard thing and the same as a opel astra or a vauxhall ,BUT REMOVE THE SENDER UNIT ASAP ,or i have a funny feeling the car could catch alight ,i have had this problem before with dawoos and the wires to the pump melting the insulation .CHECK IT OUT NOW
Mar 08, 2010 | 2001 Daewoo Lanos
Opel Astra 1600 16v jerking at low rpms when car
i got opel astra 160i 95 model. it jerks when the engine is hot/warm when excellerating.
Jun 09, 2009 | 1999 Chevrolet K1500
Car Audio & Video Logo
1,654 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
