I have a canon pixmamp160 prin ter. It seems to be grabbing the paper from the side and feeds in crookedly, then gives me an error signal. I am using top quality reflex paper and have tried all the trouble shooting ideas,without success. Sometimes one page will come throug ( crookedlu) but it will not print the second page. I hae checked my instructions and have as far as I know got everything on the right settings. Please help!
Non funsiona lo scanner
Posted on Mar 24, 2008
Crooked feeder paper
Sounds like the rubber rollers that grab the paper are dirty, and one is not grabbing well. Clean them, and your paper will probably feed correctly.
Dec 07, 2013 | Canon PIXMA MX410 Wireless All-In-One...
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Canon ip2600 keeps grabbing the paper wrong, only grabs it on the right side so it feeds in crooked and jams.
you need to see the left roller and determine if broken or needs cleaned. to clean use an eraser,thats the best way. if broken i suggest new printer. have a great day and please rate bama46, thanks.
Aug 18, 2009 | Canon PIXMA iP2000 InkJet Printer
Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Jun 21, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Paper feeds crooked, then stops. I can't find the users manual. Do I need to clean the rollers?
you may need to replace the rollers. if its feeding crooked it sounds like one of the rollers isnt grabbing which means its either worn or possibly a tension setting.
May 18, 2009 | Canon PIXMA MX310 All-In-One Printer
My MP460 printer wont grab paper and feed through
It sounds like the pickup rollers are worn or damaged and would need to be replaced
Feb 11, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper feeds through straight at first then scans crooked at the end
This could be because of unclean rollers. The scanner picks paper neat, but images is crooked. This is because paper is stuck on one side and the other side is contnuing on the other, giving it the skew. There may be something sticky on the roller, possibily a left over cellophane tape. Remove it and clean with Isoporpyl alcohol. Dont use solvents.
S. Mohan, Chennai, India
Oct 15, 2008 | Canon DR-2580C Path-Through Scanner
Canon ip6000D
hi,
use good quality paper for printing. clean the feed roller or get the printer serviced from the authorized dealer.
thanks
Aug 09, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper Feed Error
Your saying the printer grabs the paper on the one side more than the other?
Nov 13, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Computers & Internet Logo
David Payne
David Payne
