Question about Sony PlayStation 2 (PS2) Console
Won't spin i put a game in but it does not spin at all and when i put dvd in it is the same can u help???
  • unitbob Mar 24, 2008
    disc won't spin
My playstation wont play any games the disk wont spin and i have cleaned the lasar and check to see if ribon is damaged ribon seems to be fine.
Posted on Mar 26, 2008
  • 149 Answers
Hi, is it a slimline one cos sometimes the switch that tells the console that the doors shut breaks. U could try pushing it down gently too see if it activates but i cant be responsible for breakages or possible blindness if you look into the laser. LOL
Posted on Mar 23, 2008
SOURCE:
My philps Dvd player won't work correctly
From the description the pladder motor is bad, " disc spins on" or it is missing the 5 volts that drives the motor. The laser pickup that pops up and down appears to be working fine.
Apr 13, 2012 | Philips PET741 Portable DVD Player
Disney d-style karaoke won't read disk or spin disk
The problem is in the laser pickup assembly, the pladder motor is not working that spins the disk, and unfortuneately the only way to correct this is to replace the entire assembly which probably won't be cost effective.
Mar 06, 2012 | Televison & Video
When I insert a DVD I get a noise when loading then after a while it stops and the DVD get stuck in the drives and won't play. It's as if the drive can't read the disk??
Sounds like there is a problem with the holders on the top of the dvd drive that is supposed to keep the discs in place so it prevents the noises from happening. They wear out after lots of gameplay. Easiest thing to do is to replace the dvd drive because to open it up and replace the holders could cause more damage to the drive.
May 25, 2011 | Video Game Consoles & Games
How to install company of hero to my pc
To install this game follow these steps.
1. Put the CD/DVD in your computer (If you have a DVD version of the game and no DVD drive it won't work.) 2. The disk should be read and you can click on the autoplay/install option. If this doesn't happen go to my computer and double click the cd drive with the game icon on it. 3. Click install and follow the on screen instructions. You will need a CD key which is provided in the game case and it is usually located on the back of the instruction manual.
Hope this helps. Robert
May 05, 2011 | Computers & Internet
Loud grinding, spinning noise with game in console.
Even if it is still playing dvds it might be the dvd-rom drive, usally it spins a game faster than a dvd. Or it could be the harddrive if it was trying to save something. try to download a demo or something to check the hard drive.
Mar 17, 2008 | Microsoft Xbox 360 Console
Disk wont spin?
If its still under warranty, and the seal hasn't been cracked, contact Microsoft.
Try what hijackthis1 suggested, if that doesn't fix it, try this.
Since you have the 360 apart, and the top cover off of the dvd drive, here we go...
There's a circular cut-out that's glued to the top cover that you removed from the dvd drive, right below the sticker with all of the drive information. I was able to pop out the cut-out. After that you now have (3) pieces in your hand, the cover, cut-out, and a plastic piece.
Connected the dvd drive back in the 360 with the top cover off.
Put a game or movie in the drive, don't hit the eject botton, just put the disc in the tray.
Now with the disc in the tray, put the plastic piece in the center of the disc. Its magnetic, so it should kind of lock in to place.
Connect the power/av cords in the 360 and turn her on.
You should see the disc try to spin. (It may spin once or a couple times around, but it will stop). When you see the disc start to spin, GENTLE, spin/turn the disc in the direction in wants to go. It should load the game or dvd with no problems.
Reassemble the cover and put back on the dvd drive.
Now use the eject botton, and try games and dvds.
If disc fails to spin, do process over again.
I've done this with one of my 360's with no problems.
The drive I used was an Hitachi 0059DJ.
Dec 24, 2007 | Microsoft Xbox 360 Console
Xbox 360 problems
If its still under warranty, and the seal hasn't been cracked, contact Microsoft1.gif.
Since you have the 360 apart, and the top cover off of the dvd4.gif drive, here we go...
Now use the eject botton, and try games and dvds4.gif.
Sony PlayStation 2 (PS2) Console Logo
60 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
