Question about Appian Graphics Phoenix Radeon 9000 QD, (128 MB) Graphic Card
Display driver missing
I am unable to install my Appian grpahics display driver from the original cd i have received with the grpahic card
pls advise what can be done to install the card?
  • justincase99 May 11, 2010
    Hello thanks for the idea. Unfortunately, that doesn't tell me what I need as it is all "generic" info there. Manufacturer; chip type; DAC type; approximate memory, and monitor are all N/A Only thing it shows is 1024 X 768 resolution. On the section for DRIVERS it simply shows a main driver: vga.dll version: 5.01.2600.0000 (english) date: 8/23/2001 WHQL logo'd: Yes mini VDD: vga.sys VDD: N/A DDI Version: unknown eventually, I just took the ard out of the computer and found it is labeled Appian Phoenix 4 port. Googling that, I find a Phoenix Radeon card, but it is set up slightly different with the fan configuration and some other small points (mine does NOT say radeon on it anywhere). The radeon card has an associated number on some sites of 799-00400. On my card I find 251-00400. Googling my number brings up two results, neither of which lead anywhere and I can't find reference to it anywhere else. I googled for over an hour trying to find the exact card I have and thats as close as it gets, so maybe I just have a slightly modified version or variation of the radeon 9000. Ok, so now I just go and download those drivers right? Wrong! I can't find the radeon 9000 drivers anywhere. Seems every place I find that supposedly has them for download is a scam for selling Driver Detective or some such program that tells you what drivers your system needs to update. The scan is free, to get the product always costs (whatever). So even if I buy that program, I still don't know if they will have the drivers I need for download in their database. Reading through the info/description of the Radeon 9000, it appears there is some connection to ATI. (see:http://www.dreamerswanted.com/portfolio/... and hit CTRL+F to search for Appian and the info comes up near the bottom of the page. Also found this blurb elsewhere - "Appian has released the Phoenix Radeon QD, a 4-monitor low-profile PCI video card with two ATI Mobility Radeon 9000 chipsets, 128 MB RAM, and support for VGA and DVI" ). Anyway, Appian graphics appears to be out of business. Phone numbers, fax and email all lead nowhere. What do you suggest I try from here?
    President:
  • 778 Answers
If your OS is XP SP2, you can un install the Graphics card via device manager and on re boot let Windows new found hardware wizard pick it up and it should set up your Card itself, as the CD's drivers are probably not the latest XP SP2 compatible driver.
You could also go to the Graphics card's Manufacturer's Support site and download the latest XP compatible driver, or whatever OS's driver you require.
You can look here also: http://www.fixya.com/support/appian_graphics
Good luck.
Posted on Mar 22, 2008
Hello, My winXP cannot recognize monitor Asus VH232T - windows suggests 4:3 resolutions only. Can you please advise where can I download the monitor driver? Video card is ATI RADEON XPRESS 200 Thank...
Hi
Monitors do not generally require drivers. The .inf drivers to run almost all monitors are already in Windows.
The problem here is in the settings of the graphics card.
Many users aim for Maximum resolution, when what they should aim for is Optimum resolution, balancing the RAM, CPU, GPU, GRAM and Monitor''s resources in the most efficient and effective way.
Keeping the relevant software updated also has an impact on graphics performance (grpahics Card Drivers, Java, Flash, DirectX, Video Codecs, etc.)
If the video resolution is set too high (or too low), beyond the graphics capabilities of the monitor, on reboot, the monitor will be unable to resolve the image.
The simplest solution would be to use a different monitor to adjust the video resolution, shut down then test the preferred monitor again.
Right Click on desktop>Properties>Settings then use the slider scale to adjust resolution, then Apply, Yes on the optimum setting, them OK.
Find the optimum setting in XP with your graphics card for this monitor and you should be fine.
Hope this helps.
Aug 02, 2011 | ASUS VH232H 23" Monitor
I have problem with 3D cocpit view. Cant see throught the windshield. Like its made out of non clear glass
Is all your drivers up to date like your grpahics card? Have you re installed your game to see if theres any curupt files?.
May 28, 2011 | Microsoft Flight Simulator X for Windows
I want to drive 5 displays from one pc. can i install a matrox 9148 and use the onboard grpahics card shipped with my pc for the fifth screen. it is an NVIDEA GEforce card.
No, you cannot do that, they are different brands, are using different video drivers and Windows cannot run more than a single video driver at a time.
Mar 22, 2011 | Matrox M9148 PCI Express Video Card
Connect VA1912w Monitor with DELL Laptop
I don't think it is a problem with the monitor or its driver.Please adjust the monitor settings on Windows by Right click-Properties-settings-Screen Resolution-1440*900.Now check whether you are getting the native resolution.
Feb 04, 2010 | ViewSonic VA1912w 19" LCD Monitor
Video displays vertical lines then goes blank
There could be 3 possible reasons for a vertical lines
1. Driver for graphics card needs to be updated
2. Grpahics card faulty
3. LCD problem
try connecting an external monitor and see if the display is also vertical on the monitor, if yes the problem is graphics card, if no, the problem is the LCD. Hope this helps
Dec 11, 2009 | Acer Aspire 5100 Notebook
Can NBA2k10 (PC) work for Nvidia 8200M G (128mb) (integrated)?
It can play it, but for a good rendering you should put the game at the lowest settings and at low resolution. Save a few bucks more and buy a separate video card.
Nov 30, 2009 | Gigabyte GA-M78SM-S2H nVidia GeForce 8200...
Cant find the driver for d33008 foxconn grpahic card
Yet another 10 second search...
http://support.gateway.com/support/drivers/getFile.asp?id=20180&dscr=ATI%20Radeon%20Video%20D riverVersion:%206.14.10.6497&uid=174581233
Aug 08, 2009 | Foxconn Computers & Internet
I have a Silicon Image 164 ADD DVI card added to my HP desktop DVI-D access card in an effort to get a dual monitor configuration. I get an exact clone in the second monitor. I have an HP compaq desktop...
If the Intel graphic card is part of the motherboard, you need to disable this in the BIOS. You need to install the Silicon grpahic driver, then you will be able to configure the screen resolution etc for each monitor.
Jun 10, 2009 | HP Compaq d530 CMT PC Desktop
I NEED software for gf mx 4000 128mb ddrtv
Click on this link http://www.nvidia.com/Download/index.aspx?lang=en-us
then choose your version of grahics card and operating system (windows), then download the driver software
Dec 08, 2008 | MSI G4MX4000-T128 GeForce MX4000 128MB DDR...
Appian Graphics Phoenix Radeon 9000 QD, (128 MB) Graphic Card Logo
279 people viewed this question
Top Appian Graphics Computers & Internet Experts
David Payne
David Payne
Are you an Appian Graphics Computer and Internet Expert? Answer questions, earn points and help others
