Question about HP iPAQ HX2490 Pocket PC
SD Card not reading
My iPAQ Hx2490 does not seem to be able to red SD cards anymore. HAs been working fine for at least 6 months (longer). CF cardreads fine. SD cards will read on other devices. ANy ideas?
  • Law_unick Dec 22, 2008
    it seems to have same problem... i don`t know what to do.. i have been checked pins, but it seems to be no problem.. i think the driver is making this problem:(..
I had this problem once and found after tedious looking that one of the pins was bent inside my HP 3715 PDA. I used a very small needle nose and a safety pin and pushed it back in location. Has been working ever since.
Posted on Mar 23, 2008
My hp ipaq hx 2790 don't read the memory cards
Are the memory cards of similar size to what you have used before? Some large capacity ones cannot be used. Have you used a memory card before in this device so you know it was working?
Jan 08, 2009 | HP iPAQ HX2790 Pocket PC
Just bought 4GB SD card that hx4700 does not recognise - help pse
Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
http://en.wikipedia.org/wiki/Secure_Digital_card
Dec 10, 2008 | HP iPAQ HX4700 Pocket PC
HP 2490B SD CARD
check if your SD is SD HC because it cant read HC
Nov 04, 2008 | HP iPAQ HX2490 Pocket PC
Media Player won't read storage card library
I gave up and bought ($23) Conduit's Pocket Player which has no problem seeing and reading my MMC card which I sync to from Media Player on my PC through the PC's card reader. Job done!
Liz
May 24, 2008 | HP iPAQ HX2490 Pocket PC
I recently purchased 2nd hand a HP ipaq hx2000 pocket PC. It all appears to function ok apart from it will not recognise any compact flash card when I insert it into the slot. I have tried several CF...
Have you tried using an SD card? The hx2000 is supposed to support SD cards and CompactFlash Type II memory cards. If it doesn't respond, it's possible that your second-hand device simply has a faulty card slot.
May 10, 2008 | Computers & Internet
Ipaq 2400 series will not recognize Compact Flash card
Hello :-) I have a HP Ipaq 4350 and something similar like this happened to me. Except when I tried to take out the SD and put it in again the screen would go different colors and I would have to reset. But sometimes the SD will not get read because of the way you in and outsert  it. Do you push down on the SD card and it will pop automatically or do you pull out the SD card. Because if you pull it out that might be your problem because if you DO pull it out it can damage the metals that read the SD card. Now If you do pull it out  I'd recommend for you to insert the card and then pop it out and reset your device. If you do not pull it out you should go into the finder app on your Ipaq and see if that finder finds you SD card. If it does that means that your program is the problem and that its not fully compatible with your ppc or your specific SD card. Im sorry if this doesn't resolve your problem.
Dec 31, 2007 | HP iPAQ H2210 Pocket PC
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
SD card slot stopped working
Really maybe you don't know a lot of fixya in the philippines. Try to send your device here in Dipolog City.
Nov 20, 2007 | HP iPAQ H2215 Pocket PC
PDA sound doesn't work anymore after loading tomtom 6
just to let you know i'm having same problem so it's just not you! if all files are loaded to sd card you don't get the error message but the volume is still reduced to zero still checking the internet for solution al
Jun 21, 2007 | HP iPAQ HX2490 Pocket PC
IPAQ Backup on SD
Sounds like a potential problem with the SD card -- I'd try reformating the SD card and do another backup... If you still have the error, try another card...
Sep 11, 2005 | HP iPAQ HX2415 Pocket PC
HP iPAQ HX2490 Pocket PC Logo
250 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
