Question about Canon CanoScan N670U Flatbed Scanner
Canon N670U scanner
Hi, this scanner getting lines on images when it scans, how can i solve it?
  • Anonymous Jul 19, 2008
  • Anonymous Aug 25, 2008
    Yes, my scanner has the same problem, - lines on the scanned images.
Where i can find the twain drive
Posted on May 24, 2008
I need help to connect my flatbed scanner canon n670u.
Same problem as everybody. Cant connect Twain source
Posted on Nov 24, 2008
SOURCE:
I have kodak i2600 scanner, when i was scanned document its getting black lines on the document how to solve this problem please help me
Black lines on most any scanner will be caused by dirt in the scanning system, or by a damaged/defective scanner sensor. You can clean the window.
Jul 15, 2015 | Kodak i2600 - Document scanner - 8.5 in x...
Hi a vertical line is in image scanned please tell me how to solve this problem thanks
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the scanner top (by pullung it near the area where you feed the paper to scan). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning!
Good Luck!
Hope this helps! Dont forget to appreciate the solution!!
CreativeTECH
Feb 14, 2011 | Fujitsu fi-5120C
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    Black line on image
    It's possible that the black lines you're experiencing are an internal image adjustment issue with the scanner itself. If the scanner glass is otherwise clean, try going to the Canon DR2050/2080 utilities installed as part of the set up of your scanner and running the Adjustment Tool - it asks you to place the "adjustment paper" in the scanner. The term, "adjustment paper," appears to mean anything which has an image or text on it. Be sure you clean the scanner first before running this utility. It will have you put the "adjustment paper" through twice, and that in turn should remove the black lines in your scans, as long as there is no dust on the scanner glass. Office Depot sells cleaner sheets for laser and inkjet printers which also work on faxes and scanners and which will clean the glass for you.
    Nov 08, 2009 | Canon DR-2050C Path-Through Scanner
    Lines across scan
    It appears to be a freak problem. The best way is to bring it to original condition. Try uninstalling the scanner, run Scandisk on the Comp, Switch off and reinstall the driver. this may work.
    S. Mohan
    Feb 12, 2009 | Microtek ScanMaker 9800XL Flatbed Scanner
    Yellow band in scanned image
    I solved bit by shaking the scanner like crazy
    Aug 26, 2008 | HP ScanJet 2400 Flatbed Scanner
    Won't scan my image
    Dear Sir,
    I want a HP Scanjet 4370 Softwear Download my Computer. And pls confirm where is place of Delhi (India) & How Much the Price of HP Scanjet 4370 Adaptor?
    Thanks
    SAM
    May 01, 2008 | HP Scanjet 4370
    The image has patchy lines
    The scan image you have above could be caused by a few different issues but the number one is a power issue. Make sure that the printer is plugged in directly to the wall and not into a surge protector or a power strip. The printer does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all. Try another wall outlet and see if you can get it to power on and do a copy. Does the image look any better?
    If this does not solve the issue then it may be that your scanner bulb is going and therefore not illuminating the image properly. Call hp and see if they have any upgrade units available - usually refurbished but they come with a 1 yr warranty and are significantly cheaper than buying a new unit from the store. They will also take your unit and pay to have it returned to go to an environmental recycling facility.
    Feb 16, 2008 | HP ScanJet 2400 Flatbed Scanner
    Lines on scanned images
    if the lense has dust on it how do i clean
    Oct 29, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
    Canon CanoScan N670U Flatbed Scanner Logo
    433 people viewed this question
    Clive
    Clive
    old marine
    old marine
    Ekse
