Just bought a second hand Archos 700tv. Everything works fine, except that I can't get any reception on the tv at all. used both the supplied aerial and home mainone, still reads red in the signal strength readout. Is there something I need to set up else where on the system? The chap i bought it from assures me(!) everything worked fine! In the tv programs saved list it still shows all the channels that he could recieve. The only thing I've done since getting it is pdate the firm ware, can'tsee how this would effect it though!!??
  • 185 Answers
Hi Dorr
Did you buy your Archos from someone living in a different part of the country? If so, it is quite likely that you will have to retune your receiver to the local channels which may be on different frequencies in your area.
The Archos should have a scan function to look for active channels. I'm not sure how to access this but take a look in the manual, it should be an easy task.
The saved list you refer to, just shows the tags and does not mean that the signals is actually being received.
Hope this helps.............
Posted on Mar 22, 2008
Can not get DAB radio too work on my Vita audio but FM radio works fine
This may be because you live in an area where DAB reception is currently poor, but to check this, please use our postcode checker (see 'check your DAB coverage' panel on the right) to see which DAB stations you should be able to receive. If reception for your area appears to be good, then it may be down to local conditions or building materials. Buildings constructed from steel and reflective glass are not good for radios with internal aerials as they reflect and greatly reduce the strength of signal. In such a case an external aerial will greatly improve reception, but most importantly, if you are using the supplied telescopic aerial, you should ensure that it is properly fitted and fully extended upright.
Secondly, when our products are first powered up from new, they automatically scan the DAB network to see which services are available. During this process it is important that the radio is not touched and that the aerial has been correctly fitted and extended as instructed. If this has not been done then it is likely that not all stations will be detected and only the strong ones displayed. To correct this a new AutoScan/AutoTune or System Reset should be performed as instructed elsewhere in our Q&A's.
questions answers
Sep 04, 2014 | Audio Players & Recorders
Sky problem
Freeview has nothing to do with satellite. FreeSAT is the one that uses a satellite dish for reception. FreeVIEW is received through the aerial.
Also, don't fall for the "digital aerial" scam. I install aerials as part of my business. I've been to homes with aerials 20 years old, covered in soot from the chimney and they still pick up Freeview perfectly well. Equally, I've been to homes where the owner has bought some gold plated multi-finned "digital high gain" monstrosity that has awful reception characteristics.
If your TV aerial is okay, then just plug it in to your Freeview receiving TV and do the tuning.
If you do want Freesat then you will need a satellite dish along with a Freesat receiver.
Sep 04, 2014 | Televison & Video
I just installed a new Sony XT-100HD HD Radio Tuner for my truck. I wanted it so i could pick up more stations and have them all sound clear. After I hooked everything up to see if it worked all I could...
It is always worth checking the aerial in any case of poor reception.
In the case of a standard mast-type aerial it is necessary for the mast to have very good continuity to the centre of the aerial plug, that the outer part of the aerial plug has good continuity to the aerial ground and thus to the vehicle bodywork and the two parts are electrically isolated from each other. A good independent radio ground connection also helps.
In the case of miniature aerials or those within a windscreen, a rear screen or rear quarter glass, the amount of signal available will be small and so an aerial preamplifier will be provided to boost the signal. The preamp might be part of the aerial or a separate unit fitted anywhere convenient. I once found one fixed to the front firewall behind the dashboard.
The preamp needs a good 12 volt supply and a ground as well as good connections to the aerial coaxial leads. The supply is usually obtained from the radio set so it is operative only when the radio is switched on. Sometimes a radio has a dedicated output but mostly the electric (automatic) aerial output must be used. If the preamp isn't working reception will typically be limited to a few powerful stations.
I hope this helps.
Oct 21, 2017 | Sony XT-100HD HD Radio Tuner
Problems on the freeview 21inch Tv Teknica from Tesco was working when we bought it 2 years ago cannot get all the channels and poor reception re installed channels many many times but does not maintain...
you may want to try changing the coaxial aerial cable that feeds the tv, these can go faulty. also if you are running a series of tvs off one aerial, you should be using an aerial booster, other wise you will get a signal drop (as displayed on your tv).
If these small things don't cure it, the set requires replaceing as the tuning card is knackered
Jan 16, 2011 | Audio Players & Recorders
Brought new tv for bedroom freeview inc..set up
If you have got a good aerial, the high gain type- see image, it should run all the TV's you say. Make certain you have decent cable coming off the aerial (the stuff they use for satalite dishes). Then buy some high quality splitters, to feed the TV's. Don't split the cable outdoors!
Jan 25, 2010 | Televison & Video
We bought an LG flatscreen TV and a digital...
it's the aerial, tv has nothing to do with channels. it's the signal that carries the channels. i'm pretty sure if you had it hooked up to a cable box, you'll get all the channels, so i'm sure your tv is fine. i would double check on the aerial and positioning the attenna has some factor into it.
Oct 17, 2009 | Televison & Video
Alighn ariel for digital tv
The best type of aerial for digital reception is to use a wideband aerial this will give you a better spectrum to receive the signal. To locate the aerial position, if you know in which direction your local transmitter is situated, then point the aerial in that direction. The best way to find out which way to point is to simply look around at any of your neighbours aerials & then aligned yours in the same direction. If you are using a spectrum analyser as your sattelitte finder then you can use this to find other frequencies in the signal range.
Sep 06, 2009 | Televison & Video
Manual for bush dfta5a not supplied at purchase.
I have the Bush DFTA1A set top box and plugged the aerial into the back of it, then connected the 3 cables red,white & yellow also into the back of it and the other end of those cables into my DVD/TV. then follow onscreen prompts to install it. works fine.
Aug 25, 2009 | Bush DVD2038 DVD Player
Poor tv reception on my new lcd screen
Hi, sounds like the antenna. Maybe get an Aerial company to check it out for you as you might not be picking up a strong enough signal.
Dec 27, 2007 | Televison & Video
Snowy picture, no reception?
Hi, Your question "Do bigger TV's need an aerial booster or something?" - No, normally it should work straight out. Boosters are used for fringe location not bigger TV. Pls a questions and some ideas: 1. "TV worked fine the night before" was it hooked up to Cable or aerial? 2. If cable, it is necessary that you change the settings of the TV from cable to STD or Air or something like that. Normally this can be done via the remote, menu, setting, set-up; 3. If aerial, you would probably need the assistance of a qualified service personnel. Apparently something got loose inside the Philips TV, not a big problem because you can still receive (BBC 1) but not the other channels, possibly a loose wiring, a disconnected connector. 4. If you feel comfortable working on it yourself, unplug the tv and the aerial, open the back and poke around. Trace from the aerial jack, the lead wires used, the connector to the main circuitry. Wiggle the wires a bit for any loose connection. 5. If #4 is not to your liking or if you do not find anything or no significant improvement after closing it up and running it again, guess you're back to #3. Hope this gives you some idea. Lots of luck and kind regards from the Philippines.
Jul 31, 2007 | Philips 32PT9005D TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
