Question about Compaq Presario Notebook
Acer 5720Z removing rear cover to access RAM
Hi, I've just bought an acer 5720Z, which is in desperate needed of additional RAM. I can't remove the rear cover - the smaller cover is over the hard drive, which i can remove, but the larger one - after removing it's four screws - still won't budge. Is there a trick here that anyone knows about for removing this cover? I've replaced RAM in my previous three computers and never had this problem - covers usually come off easily.
  • Anonymous May 29, 2008
    i got the same problem with acer aspire 5310
    Problem Solver:
  • 4 Answers
Just did this one myself and the cover is a real pain and theres a good risk of breaking it. the secret is to get bit of a curve going across the panel so that the clips around the side pull away from the case
thanx for heads up guys
Posted on Aug 15, 2008
I've jusr replaced some RAM in an ACER Aspire 5720Z.
The large cover (held down with four screws) has clips that clip in all the way around. On edge of the panel that is close to laptop's edge has 4 notches that slide in.
Please note, that these clips were VERY tight.
Start on the side of the panel where there is a spot to lift it (close to the middle). Gently pry it up with a flat screw driver. Work your way towards the laptop's outer edge on both sides, and then slide the panel off.
-Magnon
Posted on Jun 03, 2008
    Genius:
  • 3,587 Answers
Sure..be real careful with removing that..you may need to GENTLY pry that up, under the slot, that is on one side...make sure all screws are removed, or loosened..this may mean that your memory was NOT installed correctly in the first place(causing the door to jam)..
Or, you may have the magnetic memory(just kidding)
Posted on Mar 22, 2008
Install ram in acer travelmate 5360
Yes, the large panel from the Base Enclosure.
This is a view of the Base Enclosure,
http://www.amazon.com/Acer-Extensa-TravelMate-Lower-Bottom/dp/B004PYZY7Q
The Base Panel is the large L-shaped Panel. (Not in photo, just Base Enclosure)
Regards,
joecoolvette
Sep 03, 2012 | Acer Computers & Internet
How do I fit extra memory in my acer aspire z series
If there is no Random Access Memory (RAM) compartment cover on the rear or underside of this computer, then, as is common with All-In-One (AIO) computers, a degree of disassembly is required in order to access the RAM Module slots internally.
If so, unless you are experienced at the disassembly and internal repair or mopdification of AIOs, Liquid Crystal Display (LCD) or Light Emitting Diode (LED) Personal Computer (PC) Monitors and LCD or LED Televisions (TVs), my advice would be to take this computer in to have the RAM upgrade performed by an authorized Acer Service Center.
The internal areas of AIOs, LCD, LED PC Monitors and LCD or LED TVs are u highly unsafe and inexperienced user-unfriendly working environments because such devices contain Electrolytic Capacitors (e-caps) that are storage devices capable of storing dangerous and even lethal charges, even when the device is completely disconnected from the mains electricity. Some capacitors can store charges as high as several tens of thousands of volts.
The aim would be to remove the back panel.
Often (but not always) with AIOs, LCD, LED PC Monitors and LCD or LED TVs, the key to removing the back cover lies in first unscrewing and removing the stand.
Look out for hidden screws, particularly deep-set screws, some of which might even be completely obscured by a warranty sticker or other label, meaning that upgrading the RAM in this computer within its warranty period might invalidate the warranty unless the upgrade is performed by an authorized Acer Service Center.
When the rear cover is removed (some additional internal panels might need to also be unscrewed/unclipped and removed), you should have access to the four RAM Module slots. Two slots should be free and the remaining two occupied, each containing a single (2048 Megabytes) otherwise referred to as 2 Gigabyte (Gb) RAM Module, because the standard RAM specification of this computer is 4Gb. The maximum specified RAM for this computer is 8Gb, meaning that either one or two 2Gb Modules can be added during a RAM upgrade.
The specifications of the RAM Modules for this computer are:
240 Pin 1.8v DDR3 PC3-1066 Non-ECC Dimm (240 contact elements, 1.8 volt, 1066 GigaHertz Oscillation Cycle Clock Speed, 3rd Generation Double Data Rate, Non Error Checking and Correction, Dual Inline Memory Module).
Nov 30, 2011 | Acer Computers & Internet
How do i get access to the RAM slots on an Acer Travelmate 420???
The memory is located under a small cover plate on the bottom of the unit. Remove the battery, and then take out the two screws of this cover plate, you will find your Ram located under this plate. Here is the user manual for your model notebook:
http://support.acer.com/acerpanam/manuals/acer/0000/userguides/tm420ug.pdf
Sep 16, 2009 | Acer TravelMate 4200 Notebook
Acer won't boot up
when any computer posts/boots up.
it goes through a sequence of initialising things before booting.
i,ve been repairing computers for around 12-15 years.
1st i,d try removing the ram ( memory ) usually underneath the laptop, behind a screw cover. Or ocassionally under the keyboard.
if 2 sticks of ram are installed, remove the battery. and 1 stick of Ram. put battery on and try to boot. if no joy with that try the other stick of ram. and replace battery-Re-boot.
If this works you have 1 stick of faulty ram or faulty ram slot on motherboard. Failing this. I suspect that the CPU has overheated, and therefore a replacement Processor should solve the problem.
Thankyou for using fixya.
Mike @ compurepair.
Apr 20, 2009 | Acer Aspire 5315 Notebook
Acer Aspire RAM
There are 4 screws holding the cover on the bottom of the computer that allows access to the RAM modules. (This is the same cover that also covers the fan. The same cover with the ventilation slots.)
Simply remove the screws and lift the cover by the indent to the right of the battery lock.
Nov 22, 2008 | Acer Aspire 5720-4230 Notebook
VGA
in some models laptop they dont allow to change the occupied memory for vga. so u cant changing. this is shared from your main memory (ram).
Oct 21, 2008 | Acer TravelMate 4150LCi Notebook
Removing cover on Acer 5720z to access RAM
Download Aspire 5720 User Guide. Extract the .zip file and open the User Guide Acrobat File.
You can finr info on Installing memory on page 75
ftp://ftp.work.acer-euro.com/notebook/aspire_5720/manual/EN.ZIP
Follow these steps to install memory:
1 Turn off the computer, unplug the AC adapter (if connected) and remove
the battery pack. Then turn the computer over to access its base.
2 Remove the screws from the memory cover; then lift up and remove the
memory cover.
3 (a) Insert the memory module diagonally into the slot, then (b) gently press
it down until it clicks into place.
4 Replace the memory cover and secure it with the screw.
5 Reinstall the battery pack, and reconnect the AC adapter.
6 Turn on the computer.
The computer automatically detects and reconfigures the total memory size
Regards
Mike
Mar 22, 2008 | Acer Aspire 5610 Notebook
MEMORY UPGRADE ON ACER TRAVELMATE 5720G
Acer's support isn't the best. IMHO But go to their support site anyway and look up your laptops manual (there should be instructions on upgrading your RAM there). I did find that your machine will accept up to 4GB of RAM 2 X 2GB sticks. There should be a door or port (for easy user RAM upgrading) that is being overlooked, but again it is an Acer.
Good luck.
Feb 23, 2008 | Acer TravelMate 2300 Notebook
Acer aspire 5720 notebook with operating system XP was vista
Hi all, I must say, I now have an operating XP install on the Acer Aspire 5720Z thanks to this blog. Thank you all, and can confirm that this is a great solution.
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=4394128&CFTOKEN=56207662
Cheers
Rfscann
Nov 20, 2007 | Acer Aspire 5500 5570-2609 Laptop
Compaq Presario Notebook Logo
436 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
