How do i create a password to secure my wireless signal?
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Testimonial: "I truly appreciate the assistance given to my problem. The computer language in the manuel is confusing for a layman. Thank you very much! "
Click Here for step by step
instructions
SOURCE: I want to create a secure network password for my wireless router
The steps I'm about to teach you is to create a WPA Personal Network Key to prevent random users from accessing and altering your network.
Windows XP:
Go to Start > Run. Type in cmd and press enter. A black box will appear with some text in it. Type in ipconfig and press enter. Some more text will appear. Look for the words Default Gateway. Next to them will be an IP Address. Type this IP address into your browser.
A diolouge box will appear, asking you for a username or password. If you have not configured this already, leave the username field blank and type in the password field admin. THe Linksys router configuration page will display.
Click the tab taht says Wireless. Click the subtab that says Wireless Security. In the drop down box that says security mode, select WPA Personal. Make sure where it says WPA Algorithms, TKIP is selected. In the WPA Shared Key box, type in a password that you are sure you will remember, or write it down. When finished, selected the button that says Save Settings.
Your network is now secure with the key you have made. The default SSID (or network username) is called linksys.
A
wireless network is comprised of a wireless router, a computer (or
other wireless-enabled devices), a high-speed modem, and a subscription
to an Internet Service Provider (ISP). Netgear is a popular
manufacturer of wireless networking hardware that allows users to set
up a secured wireless network. In order to prevent unauthorized users
from logging onto your wireless network to gain access the Internet,
and in order to protect the data you transmit and receive online, you
should change your wireless router's security settings to create a
1 Install the router. To install a Netgear wireless router, use an Ethernet cable to connect the router to the cable/DSL modem and use another Ethernet cable to connect the router to your computer. Make sure all of these devices are powered off as you connect them. Once connected, turn on the cable/DSL modem, the router, then the computer, in that order. Allow at least two minutes to pass after turning on each device to give the devices time to recognize one another
2 Log in to the router. Open a web browser and type in the router's address to load the router's settings page. The router's address can be found in the user guide or setup CD that came with your router, or you can download a user guide from Netgear's technical support page (see Resources). Most Netgear routers use one of the following addresses: http://192.168.1.1; http://www.routerlogin.net; or http://www.routerlogin.com. Press "Enter" or click "Go" in your web browser after you have entered the address.
3 Enter the router's username and password. A prompt will appear on the screen when you enter your router's address, requiring you to enter a username and password before you can access the router's settings page. The default username for Netgear routers is "username" and the password is "password." Because the textboxes are case-sensitive, you must enter both of these using all lowercase letters. Press "Enter" to log in to the router and begin changing its security settings.
4 Open the security settings menu. The router's home page has multiple links for changing settings. Find and click the "Security Settings" link to change the router's security settings.
5 Change the SSID, choose an encryption setting and create a password. The default name (or "SSID") of your wireless network will be "NETGEAR." Enter a new, memorable name for your wireless network to help detract would-be hackers from trying to access your router, as most novice computer users with unsecure networks do not know how to change the default network name or institute any other security features. Newer Netgear routers offer WPA or WPA-PSK encryption to secure your network, both of which provide high levels of security. Select either of these. encryption types and create a unique password. This will require all users to enter the password before they can log in to your wireless network. It is important that you create a complex password that has several characters, including numbers. Once you have created a password, click "Confirm Password" to save it. To exit the security settings menu and log off of the router, click "Save" or "Apply" to save the changes you made, then click "Logout" to exit the route
Things You'll Need
* Netgear wireless router
* High-speed Internet service provider (e.g., Comcast, AT&T, Insight)
* Cable/DSL modem
* 2 Ethernet cables
* Computer
* Web browser
* Router address
* Router's username and password
Good Luck : ) ....
Access the router's default configuration address through your Web browser by entering this address: http://192.168.1.1 (see Resources). Do not enter a user name. Enter "admin" for the password. That process works for all new Linksys routers. If you have changed the user name or password in the past, use the user name and password that you created.
When the configuration screen opens, click on the "Wireless" tab and select "Wireless Security" to view the router's current security password. The "Security Mode" field will say "Disabled" if you do not have a password to secure your network.
Select the appropriate encryption type from the "Security Mode" drop-down menu. Linksys routers offer WEP and WPA encryption. WPA encryption allows you to use a single password to access the network. WEP encryption creates 10- or 26-character keys that act as your password. Some of your wireless devices may only utilize a certain type of encryption. Determine which protocol is best for your network.
Enter a password that will be required to access the network. For WPA encryption, you can write your own password. For WEP encryption, click the "Generate" button to create passwords that can be used to access the network. Write down your passwords and keep them in a secure location.
Click "Save Settings" to confirm your changes. Your network will now be secured and will require a password for access.
Click the "Administration" tab to create a password to access the router configuration page itself. Be sure to change the password from the default "admin." Reenter the password for confirmation in the next field. Click "Save Settings" to confirm your new password.
