Question about Compaq Presario X1000 Notebook
Presario X1000 hello, my presario X1000 seems to have a problem. Whenever i try to on it the power turns on but the screen is left blank. The sounds sometimes comes on but the screen doesn't. Please Help Me ASAP..
    Scholar:
  • 94 Answers
Unplug AC
Remove Battery
  • Remove the keyboard, tilt towards you disconnect it.
  • unscrew the screws holding the video card in place.
  • remove video card.
  • clean both rows of contacts on the card. Alcohol & Q-tip
  • get some Contact Enhancer cleaner/lubricant & apply on contacts (on video card)
  • reseat the video card
  • press firmly down on the video card where indicated.
  • put kb back on.
Put battery back in
Attach AC
Fire it up and test
Another TEST
Thump the lid switch- sometimes it gets stuck down.
if that is the case. Apply 1 drop (and only 1 drop) of WD40 on the barrel of the lid switch. It will run down into the switch itself and lubricate the plunger.
Hope that helps
Posted on Mar 31, 2008
    Sergeant:
  • 349 Answers
If the laptop posts
(power on self test) and you see stuff on the screen, no matter how short , do the following: (this checks for a software problem)
  • when booting up press F8 and when you get to the menu, boot up into safe mode,
  • then restore the pc back to a date before you had the problem,
  • and/or remove any program you installed prior to you having the problem, if that don't work
  • Try a bootable anti virus disc use it to check for any viruses , if not try a recovery disc, or operating system disc ,
  • both disc's will try to access the hard drive.
  • if they do not work, (nothing has changed) nothing comes on the screen.
laptop does not post:
(then it is a hardware problem)
  • it may be that the screen has a problem and needs specialist's attention (cannot be done via text) but try the following first.
  • check battery is seated correctly and that the power pack is functioning,
  • if the battery has gone flat and the power pack is not working ,the laptop will not start.
  • Remove any hardware you may have installed prior to you having the problem.
  • remove the screw(s) holding the cover plate on the back of the laptop where the ram lives remove the memory sticks,
  • clean the gold edges both sides, with rubbing alcohol or a pencil eraser, and re-insert them, (not an ink eraser as it will do damage)
  • swap them around if you have more than one, try one at a time.
  • if you only have one, borrow one from a friend or try the ram in your friends laptop ,if that's possible,
  • or take the ram to your local pc shop and ask them to check it for you (they may do that for you)
  • if you can establish that the ram and power pack is ok,
  • and anti virus and recovery /system disc's do not work,
  • it may be that the motherboard has failed or as mentioned earlier the screen has failed
  • but in the case of the screen failing you should be able to hear noises from the hard drive when booting up.
  • Generally a dead hard drive would not stop the laptop from posting.
good luck with that and let me know how you get on.
Terry
When i switch ON the lights come up but the monitor doen't
It seems your monitor's connectors are somehow severed. When you apply pressure it connects again. You must bring it to a service for repair.
Oct 28, 2009 | Compaq Hewlett Packard LCD Display for...
I can´t turn on mu computer
hy this can be a fan problem over heating with a lot of dust hair and all sorts clogging the fan to run sufficiently advice if your techs strip it down and clean mother board with an antistatic cleaner all compaq &hp are all the same way 2 strip down and rebuild can be a bit of a pain if you not very technoly minded
Oct 04, 2008 | Compaq Presario X1000 Notebook
Blank Screen problem!
perhaps you toggled off the moniter... look on your keyboard for a monitor icon.... it happens alot
Robert
Aug 28, 2008 | Compaq Presario X1000 Notebook
Blank Screen
Your RAM maybe bad, or too low or just don't have any. Had the same problem with a IBM ThinkPad R31 and all I did was added a 512MB RAM Chip in it and screen came on and loaded to bios.
Jul 08, 2008 | Compaq Presario X1000 Notebook
Broken power button
They Have one for sale On ebay if you need..
Look here for your compaq presario X1000 power button bezel
http://cgi.ebay.com/APCL312M000-compaq-presario-X1000-power-button-bezel_W0QQitemZ230260679776QQihZ013QQcategoryZ60265QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hope it helps.....
http://www.wnycomputerpro.com
Jun 11, 2008 | Compaq Presario X1000 Notebook
Blank screen on Compaq Presario X1000
Since u said that ur screen flashed and also u said that when u connected an external VGA nothing would display so from these two i can tell you that it is a hardware problem and that too with the VGA card/display card.
Thankyou
Feb 10, 2008 | Compaq Presario X1000 Notebook
BSoD, Garbled Screen, Boot Failure.
If you are getting garbage on the screen before windows tries to load the laptop probably has a bad motherboard.
It's possibly only the video output is going bad on it, try hooking it to an external monitor and see if you get the same weird stuff on that screen.
Good luck, let me know how it goes
Nov 15, 2007 | Compaq Presario X1000 Notebook
Compaq Presario X1000 Notebook Logo
141 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
