Question about Amana SXD524VW Side by Side Refrigerator
Ice maker isn't working...
I've got Amana SXD524VW Side by Side.
Our ice maker fills water, freeze them to cubs but doesn’t spill them to the ice box. By the way the indicator (small tube with string) is down (so its need to fill up).
What could be the problem?
If you suspect that the ice maker engine are gone – where could I find spare parts?
Thank you,
    President:
  • Amana Master
  • 2,651 Answers
Looked up a part number using your supplied model, its listed as anicemaker assy (220v) complete assy 67006665
Posted on Mar 22, 2008
SOURCE:
Ice maker has stopped filling with water
sounds like the water valve has failed . ck it / in hte back where the water line is hooked .. it will be a dual valve one side for the foutain and the other for ice . do not cross the wires . mar them when you remove. and reinstall them the same .,mm
Jul 29, 2010 | Amana SXD524VW Side by Side Refrigerator
Looking for wiring diagram for amana bottom freezer model # BG20T2L MFG# p1316303wL serial # 9807110676 THE ICE MAKER QUIT MAKING ICE
First thing to check is the fill tube and make sure it is not frozen with ice.some ice makers can be manually advanced in order to refill with water some have a reset button to do this if these two things do no good and the fill tube is not blocked with ice then repalce the water fill valve on the bottom rear of the unit
Jul 10, 2010 | Amana SXD524VW Side by Side Refrigerator
Ice tray filler tube freezes up and clogs up so no water goes into tray
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
May 22, 2010 | Amana SXD524VW Side by Side Refrigerator
Ice maker quit making ice
I noticed your model number calls for a 220 volt and 50 cycle service. Are you in the UK or an area that uses this voltage? Anyway fill ice maker with tap water and let freeze. If the ice dumps after freezing that wil be the water control valve part number Click Here=> D7827204 and id it is the thermostat inside the ice maker the part number Click Here=> D7846305 neither page has photo. Here is you refrigerators Service Manual=> SXD524VW go to page 66 and the manual has very detailed test procedures for the ice maker. You can also go through my site=> GE Artica Profile Technical Information and click on Repair
Clinic.com Banner at top of page. The just enter the part numbers in his search feature. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Mar 18, 2010 | Amana SXD524VW Side by Side Refrigerator
ICE MAKER NOT GET WATER
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...the temperature(it needs to be 0-4 degree F for the ice maker to start) may be defrost problem send me a note if you need info on that
Aug 24, 2009 | Amana SXD524VW Side by Side Refrigerator
No water to ice maker or despencer
Since you said it was "used" you should check the water filter if so equipped. It could be plugged. Also, and obviously, be sure the water to the unit is turned on.
I'd look for a plugged water filter first. Check the manual for the location (usually near the bottom front of the appliance) first.
Try these steps first.
Apr 04, 2009 | Amana SXD524VW Side by Side Refrigerator
Ice maker isnt working...
just clearing this post from hte questions not answered list!
Mar 22, 2008 | Amana SXD524VW Side by Side Refrigerator
Water runs out of the water in the door when the ice maker fills
It is possible that your icemaker tray is overfilling and the excess water is running out of the ice chute. There is an adjustment screw on the icemaker head beneath the large white cover which can be adjusted to compensate for this. If not then the icemaker head may need to be changed to correct this.
Mar 09, 2007 | Amana SXD524VW Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
131 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
