Question about Toshiba 32DF46 32" TV
New DVD Player won't work on Toshiba 32DF46
When I hooked up the new DVD player which is also a Toshiba, Model SD4100, only the Audio works but video doesn't. DVD works great on another TV, so it's not the DVD player the trouble. Everything else is working on the TV, as well. I think it is in the programming of the TV, is there anything I can do to make them compatable? Thank you!
  • Anonymous May 11, 2010
    How do you have your dvd player hooked up? Are you using a hdmi cable or progressive scan cables?
I am using the same cables that came included with the DVD player.
Posted on Apr 03, 2008
  • Anonymous Apr 03, 2008
    (Sorry, I couldn't find the category "Request Information" to post a reply to your question.)
SOURCE:
Cannot get new DVD player to work on Denon AVR-2307CI Receiver
TRY TO FIND DVD PLAYER RESOLUTION SAME TO THE RECEIVER....MAY BE IT WORKING..
Dec 28, 2013 | Denon AVR-2307Ci Receiver
My toshiba sdk990ku dvd player stopping playing the audio. Have connected via HDMI to LCD HD tv and worked for months! One day audio stopped, but picture is fine. Tried different HDMI cables, dvds with no...
Tries unplug,replug it back like an hour later.Letting the DVD player resetting itself back to the factory setting.Tries it than,see if it work than.Not,than tries hook it up with the RCA component cable Y,R,W.If still have the same problems,the PCB in the DVD player is bad.Not worth repairing.Trash it.DVD players are very cheap these days.U can get a brand new one like for $40 dollars.
Nov 18, 2010 | Toshiba SDK990 Player
Need to know how to hook up a Toshiba DVD player to a TV
To hook up a toshiba DVD player to a television, you need to get the prongs, that you will use to hook them up.
You have a prong with red and white tip, locate the audio out on the DVD and plug in one of the prong in it then locate the audio in on the television, then you plug the other prong in the video out of the DVD player also you plug it in the video in of the television.
That is all you need to do, then you ensure you have your television on the AV mode to enjoy the DVD player on it.
Take care and good luck
Oct 22, 2010 | Toshiba SD-2109 DVD Player
Hooking up dvd player to Toshiba DPL 52" HDTV
Send the viseo to the Tv using composite or component input and send the audio ( red and white RCA audio ) to the BOSE.
May 13, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Only getting sound but no picture!
Well, i had a look at the back of that Toshiba TV - make sure that the red, white, and yellow cables are hooked into the Video-1 slot of the Toshiba and that the Toshiba channel is changed to Video 1.
Then check your nameless DVD player and make sure the red, white, and yello cables are all hooked to OUTPUT slots that are in the same column or row - if I had you DVD manufacturer and model #, I could suggest some additional steps to check. Also, make sure your dvd player is in dvd playback mode.
-Tha Mp3 Doctor
Dec 31, 2008 | Toshiba 42HL167 42 in. LCD Television
DVD Player not working
Go to menu. Select inputs. Assign input 1(or whatever input you connectedthe dvd to) as DVD. Then exit menu. Press the input key, scroll over to DVD. I reccomend using a component cable with a digital audio cable, if you do not have a DVD player that has an HDMI connection. You will find that a blu-ray player will be much more satisfying for the television you have. Basically by hooking up that old dvd player to that tv, is the same as hooking an 8-track to a $2,000.00 stereo. It will work, but the quality is going to suffer! Good luck, and believe me. It is worth the extra money to get a blu-ray player. It will play all your old dvd's and blu-rays. That way you are getting the full potential of your set.
Dec 22, 2008 | Mitsubishi WD-60735 Projection Television
Display on but no sound from any input
I have a similar problem. I connected a Toshiba HD-a2 dvd player and cannot get digital audio from any of the hd movies. Regular dvd's play just fine. Toshiba told me the receiver is to old and can't process the new format. I was wondering if there is an upgrade for the receiver or any other way I can get 5.1 out of this receiver with out having to get a new one..
Dec 29, 2007 | Denon AVR-1700 Receiver
Connections
Hi If I'm understanding what you have written, the new DVD should hook up exactly the same way your old one did. You connect the red and white cable from the "Audio out" connectors on your new DVD to the "Audio In" connectors on the RF modulator, then connect the Svideo out on the DVD to the Svideo connector on the RF modulator. Then put your TV on channel 3 or 4 depending on what the switch on the modulator is set to, and all should work fine. I would advise you hook your old one back up, then if it works, simply unplug the cables from you old DVD and plug them into the proper jacks on the new one. This eliminates bad cables. If you then get sound, but no picture, the DVD may be set to progressive scan (check manual for procedure take it out of that mode),If you get nothing, then I suspect there is a problem with the new DVD player. The TV/VIDEO switch they mention, would be a switch on the TV or TV remote if you had a newer TV with RCA inputs.....You don't, so disregard that, it does not apply to your TV. You would not need the RF modulator if your TV had that switch. Good Luck!...These things can be a pain, I hope this helps!
Nov 28, 2006 | Daewoo DVG-9200N DVD Player
My Toshiba SD-3960 sound does not work.
First thing before a landfill is to go into the units menu and see if something in the audio got turned off if not then inspect the connectors on the back for breakage. Good Luck
Apr 02, 2006 | Toshiba SD-3960 DVD Player
Toshiba 32DF46 32" TV Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
