Vb database connectivity
How can i connect oracle database with a vb progran using adodb.
i have problem in working with recordsets
  • 85 Answers
Use odbc tool located in controll pannel and make a database file for use from visual basic6.0
Posted on Mar 22, 2008
How to connect MS access in the visual basic?
This following code to connect vb 6 with access
place this code in module :
vb Syntax
  1. Global Conn As ADODB.Connection
  2. Global rs As ADODB.Recordset
  3. Sub Access_Connector()
  4. Set Conn = New ADODB.Connection
  5. Conn.Provider = "microsoft.jet.oledb.4.0"
  6. Conn.CursorLocation = adUseClient
  7. Conn.Open App.Path & "\SIS.mdb"
  8. End Sub
Below link might help you... http://www.functionx.com/vbaccess/Lesson01.htm
Please rate or vote me , if you like solution..
Thanks
sandeep
Mar 15, 2011 | Computers & Internet
Saving the info that i entered in my visual basic in microsoft access.. how to code the save???
check this out
Rst.Open "users", strConnect, , , adCmdTable With Rst .AddNew .Fields("username") = txtname.Text .Fields("User_Password") = txtpws.Text .Fields("Access_Type") = cmbUserTypes.Text .Fields("Date_Created") = Now .Update End With Rst.Close
'#### connection to databas
Public connConnection As New ADODB.Connection Public rsRecordSet As New ADODB.Recordset Public rsRecordSet1 As New ADODB.Recordset Public Rst As New ADODB.Recordset Public Rst1 As New ADODB.Recordset Public Rst2 As New ADODB.Recordset Public Rst3 As New ADODB.Recordset Public strConnect As String Public ConnectionOk As Boolean
Public Sub ConnectionMOd() Dim strProvider As String Dim strDataSource As String Dim strDataBaseName As String Dim i As Integer On Error GoTo ErrorTimer strProvider = "provider=Microsoft.Jet.OLEDB.4.0;" strDataSource = App.path ' strDataBaseName = "Z:\database.mdb" ' strDataSource = App.Path strDataBaseName = "\database.mdb" strDataSource = "Data Source= " & strDataSource & strDataBaseName strConnect = strProvider & strDataSource
Set connConnection = New ADODB.Connection connConnection.CursorLocation = adUseClient connConnection.Open strConnect
Set Rst = New ADODB.Recordset Rst.CursorType = adOpenStatic Rst.CursorLocation = adUseClient Rst.LockType = adLockOptimistic ' adLockOptimistic
Set Rst1 = New ADODB.Recordset Rst1.CursorType = adOpenStatic Rst1.CursorLocation = adUseClient Rst1.LockType = adLockOptimistic
Set Rst2 = New ADODB.Recordset Rst2.CursorType = adOpenStatic Rst2.CursorLocation = adUseClient Rst2.LockType = adLockOptimistic Set Rst3 = New ADODB.Recordset Rst3.CursorType = adOpenStatic Rst3.CursorLocation = adUseClient Rst3.LockType = adLockOptimistic ConnectionOk = True Exit Sub ErrorTimer: MsgBox "Error Connecting To DataBase Please Check Network path", vbCritical, "Connection Error" End End Sub
Jan 08, 2010 | Microsoft Visual Basic Enterprise Edition...
Example sorurce code for database
Hello my friend try this code: This code is design for Visual Basic 6.0
Function for Connection and recordset string.  '========Connection String====== Public Sub connection(ByRef dConnection As ADODB.connection, ByVal dLocation As String)     dConnection.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & dLocation & ";Persist Security Info=False;" End Sub '======End of Connection String======
'=======Recordset String=========== Public Sub recordset(ByRef sRecordset As ADODB.recordset, ByRef sConnection As ADODB.connection, ByVal sSQl As String) With sRecordset .CursorLocation = adUseClient .Open sSQl, sConnection, adOpenKeyset, adLockOptimistic End With End Sub '======End Recordset String========
How to apply the above function? Application:
'====== Command Save Button======== Private Sub cmdsave_Click() Dim cn3 As New ADODB.connection Dim rs3 As New ADODB.recordset
Call connection(cn3, App.Path & "\CASGC.mdb") Call recordset(rs3, cn3, "Select * from Debtor_Creditor_Account") Set dtglobal.DataSource = rs3.DataSource
With rs3   .AddNew   .Fields("Code") = txtCode.Text   .Fields("Description") = txtDescription.Text   .Fields("Tag") = cbotag.Text   .Update   .Requery    End With   MsgBox "New Account has been Added", vbInformation   Set cn3 = Nothing Set rs3 = Nothing
End Sub '=======end of Command Save button=====
The advantage of using this code is setting your database connection is you have a reliable connection towards your database where ever you place your database you can you don't to remount you databse connection control. Also you are no longer need to use a ADO control or DAO control just copy the function and paste it in your coding area and call the function and you have now a working database and recordset connection string.
For more details regarding how to apply this code just email me at this address: geo_jonas@yahoo.com to get more codes. thanks.. Please rate this Solution.
Jul 08, 2009 | Microsoft Visual Basic 6.0 for PC
Printing syntax
'declare the variables
Dim Connection
Dim ConnString
Dim Recordset
Dim SQL
'define the connection string, specify database driver
ConnString="DRIVER={SQL Server};SERVER=yourServername;UID=yourUsername;" & _
"PWD=yourPassword;DATABASE=yourDatabasename"
'declare the SQL statement that will query the database
SQL = "SELECT * FROM TABLE_NAME"
'create an instance of the ADO connection and recordset objects
Set Connection = Server.CreateObject("ADODB.Connection")
Set Recordset = Server.CreateObject("ADODB.Recordset")
'Open the connection to the database
Connection.Open ConnString
'Open the recordset object executing the SQL statement and return records
Recordset.Open SQL,Connection
'first of all determine whether there are any records
If Recordset.EOF Then
Response.Write("No records returned.")
Else
'if there are records then loop through the fields
Do While NOT Recordset.Eof
Response.write Recordset("FIRST_FIELD_NAME")
Response.write Recordset("SECOND_FIELD_NAME")
Response.write Recordset("THIRD_FIELD_NAME")
Response.write "<br>"
Recordset.MoveNext
Loop
End If
'close the connection and recordset objects to free up resources
Recordset.Close
Set Recordset=nothing
Connection.Close
Set Connection=nothing
May 16, 2009 | Microsoft Windows Vista Ultimate Edition
I can't add data in the database using vb
The database can be any like oracle.
Two type of connection u can make.
One of such connection is ADODB
The code is like
Dim ors As ADODB.Recordset
Dim oconn As Connection
Dim Qry as String
dim Qry1 as string
Set ors = New ADODB.Recordset
Set oconn = New ADODB.Connection
Chk_selectall.Visible = False
oconn.Open "Provider=MSDAORA.1;" & "user id = " & Username & _
";password = " & Password & ";data source = " & Conn_string _
& ";Persist Security Info=True"
Qry = "insert into table1 values (100,'we')"
oconn.execute "Qry"
If u select any data then u ve to use
Qry1 = "select * from table1"
ors.open "Qry1",oconn
do until ors.EOF
msgbox ors(0) & "," & ors(1)
ors.movenext;
loop
Mar 17, 2009 | Microsoft Visual Basic 6.0 for PC
How to connect vb with ms access
se Adodc OR Even better.. ADODB. for this you need to get MDAC fromMicrosoft free download.(check under project_References- Microsoft DataActiveX objects.. the current no is 2.8. if it is not there download invb directory.
next, you can learn about creating a DSN from control panel, ODBC. onceyou learn this, connection becomes a piece of cake. get some free vbtutoriasl from WWW.
then
you need to use DAO or ADO to connect to the database. better study both but since ADO is current, i am showing that code.
under Menu Project_References, put a check mark on Microsoft ActiveXData Objects latest version (though it works for all, currently 2.8with sp pack 1 ).
at the general declarations:
dim conn as adodb.connection, rec as adodb.recordset, esql as string,esql1 as string
Private Function connect()
Set rec = New ADODB.Recordset
Set conn = New ADODB.Connection
esql = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & "D:VBDesigndhana2.mdb" & ";Persist Security Info=False"
'here you put the correct path of your mdb file. and check if you have jet 4.0
conn.Open (esql), , , 0
End Function
private sub form_Load()
connect
end sub
and for adding records:
say let us say you have 3 fields. then have 3 textboxes and 1 command button on the form.
private command1_click()
esql1="select * from Yourtablename"
rec.open(esql1),conn,, adOpenDynamic, adLockOptimistic
rec.AddNew
rec.Fields(0) = text1.Text
rec.Fields(1) = Text2.text
rec.Fields(2) = text3.text
' you need to check if in your access table design you have Allowed Zero length .. set it to Yes for all text fields.
rec.update
if not rec.eof then rec.movenext
rec.close
conn.close
set conn to nothing
end sub
this will add new records to access table from VB.
' for picture store the full path of the path and the picture file nameint the text field. and in the picturebox of VB form for viewingrecords again you need ADO or ADODC and here you code:picture1.picture=Loadpicture(rec.fields(3) ' depending on where thepicture field is located. you need to make a few trials.
End Function
connect
end sub
and for accessing records:
esql1="select * from Yourtablename where id =" & val(text1) ' for integers
esql1="select * from Yourtablename where name=" & "'" & text1 & "'" ' for string
rec.open(esql1),conn, adOpenstatic, adLockreadonly
label1.caption =rec.Fields(0)
label2.caption= rec.Fields(1)
label3.caption= rec.Fields(2)
rec.close
conn.close
set conn to nothing
end sub
' similarly there are routines to ADD, Delete, Edit, View etc.
Feb 26, 2009 | Computers & Internet
Book mark property of recordset (ado)
The bookmark property of a recordset lets you store and retrieve the location of a record in a variable so that you can move directly to it in your recordset without having to use a query to extract that record. Like you can just move forward a record and back a record, or move to the first or last records without a quesry statement, you can move to the bookmarked record directly in code.
Here's a good VB example that compares the bookmakr property to the movefirst and movelast properties. This should answer your question, and please rate my answer.
'BeginBOFVB 'To integrate this code 'replace the data source and initial catalog values 'in the connection string Public Sub Main() On Error GoTo ErrorHandler 'recordset and connection variables Dim Cnxn As ADODB.Connection Dim rstPublishers As ADODB.Recordset Dim strCnxn As String Dim strSQLPubs As String 'record variables Dim strMessage As String Dim intCommand As Integer Dim varBookmark As Variant ' open connection Set Cnxn = New ADODB.Connection strCnxn = "Provider='sqloledb';Data Source='MySqlServer';" & _ "Initial Catalog='Pubs';Integrated Security='SSPI';" Cnxn.Open strCnxn ' Open recordset and use client cursor ' to enable AbsolutePosition property Set rstPublishers = New ADODB.Recordset strSQLPubs = "SELECT pub_id, pub_name FROM publishers ORDER BY pub_name" rstPublishers.Open strSQLPubs, strCnxn, adUseClient, adOpenStatic, adCmdText rstPublishers.MoveFirst Do Until rstPublishers.EOF ' Display information about current record ' and get user input strMessage = "Publisher: " & rstPublishers!pub_name & _ vbCr & "(record " & rstPublishers.AbsolutePosition & _ " of " & rstPublishers.RecordCount & ")" & vbCr & vbCr & _ "Enter command:" & vbCr & _ "[1 - next / 2 - previous /" & vbCr & _ "3 - set bookmark / 4 - go to bookmark]" intCommand = Val(InputBox(strMessage)) ' Check user input Select Case intCommand Case 1 ' Move forward trapping for EOF rstPublishers.MoveNext If rstPublishers.EOF Then MsgBox "Moving past the last record." & _ vbCr & "Try again." rstPublishers.MoveLast End If Case 2 ' Move backward trapping for BOF rstPublishers.MovePrevious If rstPublishers.BOF Then MsgBox "Moving past the first record." & _ vbCr & "Try again." rstPublishers.MoveFirst End If Case 3 ' Store the bookmark of the current record varBookmark = rstPublishers.Bookmark Case 4 ' Go to the record indicated by the stored bookmark If IsEmpty(varBookmark) Then MsgBox "No Bookmark set!" Else rstPublishers.Bookmark = varBookmark End If Case Else Exit Do End Select Loop ' clean up rstPublishers.Close Cnxn.Close Set rstPublishers = Nothing Set Cnxn = Nothing Exit Sub ErrorHandler: ' clean up If Not rstPublishers Is Nothing Then If rstPublishers.State = adStateOpen Then rstPublishers.Close End If Set rstPublishers = Nothing If Not Cnxn Is Nothing Then If Cnxn.State = adStateOpen Then Cnxn.Close End If Set Cnxn = Nothing If Err <> 0 Then MsgBox Err.Source & "-->" & Err.Description, , "Error" End If End Sub 'EndBOFVB
Jan 07, 2009 | Microsoft Visual Basic 6.0 for PC
Vb 6.0 ado connection without ado control moving next record
I see 2 problems with your code.
1) Each time you call cmdnext_Click, you're reopening the database. Each time you do that, you start at the beginning of the file. You need to have the database opened once, somewhere else in your program. Be sure that the record set is visible from this sub.
2) In order to use the "Next" function, you need a loop like this
'test for no records
IF REC.BOF and REC.EOF then
msgbox "No Records Found"
exit sub
end if
IF NOT REC.EOF then
REC.MoveNext
(display your fields)
END IF
Again, this will only work if your database is opened outside of the cmdNext_Click routine.
Jul 08, 2008 | Microsoft Computers & Internet
Export data in excel sheet and in specific column
I did not write this but look towards the end of the code and it will give you an idea on how to do it
Sub ExportToExcel(strOutputFile As String, Optional boolSuppressMessages As Boolean = False)
Dim strTemplateFile As String
Dim fso As Scripting.FileSystemObject
Dim cnn As ADODB.Connection
Dim rstTarget As ADODB.Recordset
Dim rstCustomers As ADODB.Recordset
Dim rstServiceReps As ADODB.Recordset
On Error GoTo ErrorHandler: On Error GoTo 0
Set fso = New Scripting.FileSystemObject
' Get template file path
strTemplateFile = CurrentProject.path & "\CompaniesEmployeesList.xlt"
' Copy template to the target
fso.CopyFile strTemplateFile, strOutputFile, False
' Open a connection to the workbook
Set cnn = New ADODB.Connection
cnn.Provider = "Microsoft.Jet.OLEDB.4.0"
cnn.ConnectionString = "Data Source=" & strOutputFile & ";" & _
"Extended Properties=""Excel 8.0"""
cnn.Mode = adModeReadWrite
cnn.Open
' Open the target recordset (the Excel sheet)
Set rstTarget = New ADODB.Recordset
rstTarget.Open "SELECT [ID], [Name], [City] " & _
"FROM [Sheet1$]", cnn, adOpenDynamic, adLockOptimistic
' Open Customer data recodset
Set rstCustomers = New ADODB.Recordset
rstCustomers.Open "SELECT CompanyID, CompanyName, City " & _
"FROM Customers " & _
"WHERE City = 'Madrid' " & _
"ORDER BY CompanyName", CurrentProject.Connection
' Open Service Rep data recodset
Set rstServiceReps = New ADODB.Recordset
rstServiceReps.Open "SELECT EmployeeID, [LastName] & "", "" & [FirstName] AS Name, City " & _
"FROM Employees " & _
"ORDER BY [LastName]", CurrentProject.Connection
' Loop through Customers result set and copy to target
Do While Not rstCustomers.EOF
rstTarget.AddNew
rstTarget![ID] = rstCustomers!CompanyID
rstTarget![Name] = rstCustomers!CompanyName
rstTarget![City] = rstCustomers!City
rstCustomers.MoveNext
Loop
' Insert blank line between result sets.
rstTarget.AddNew
rstTarget![ID] = ""
rstTarget![Name] = ""
rstTarget![City] = ""
rstTarget.Update
' Loop through Service Reps result set and copy to target
Do While Not rstServiceReps.EOF
rstTarget.AddNew
rstTarget![ID] = rstServiceReps!EmployeeID
rstTarget![Name] = rstServiceReps!Name
rstTarget![City] = rstServiceReps!City
rstTarget.Update
rstServiceReps.MoveNext
Loop
rstTarget.Close
rstCustomers.Close
rstServiceReps.Close
cnn.Close
If Not boolSuppressMessages Then
MsgBox "Workbook Created", vbInformation + vbOKOnly, "ExcelExport"
End If
ExitHere:
On Error Resume Next
Set rstTarget = Nothing
Set cnn = Nothing
Set rstCustomers = Nothing
Set rstServiceReps = Nothing
Exit Sub
ErrorHandler:
Eval "MsgBox(""Error " & Err.Number & "@" & Err.Description & "@"")"
If Not cnn Is Nothing Then
cnn.Close
End If
Resume ExitHere
End Sub
Jan 03, 2008 | Computers & Internet
Export data in excel shld yoeet through VB
When i first figured out how to pull data from SQL and put the results in an excel file i referenced these two articles....
Reading and writing excel file using VB.NET (http://www.codeproject.com/KB/vb/Work_with_Excel__VBNET_.aspx)
Get the Values From DataBase and Stored into excell Sheet (http://www.codeproject.com/KB/vb/Getvaluesfromdatabase.aspx)
This is the code i ended up using.... (check out those links to see how you need to import the ms office excel reference file with visual basic)
Const stcon As String = "Provider=SQLNCLI;server=xxxxx;database=xxxxx;uid=xxxxx;pwd=xxxxx;DataTypeCompatibility=80"
Dim stSQL As String = "select * from scs_rate_class_money where irate_book = 124 and snew_used = 'U' and sclass = '2' and splan = 'T4' and sopt_code = 'F1'"
Dim cnt As New ADODB.Connection
Dim rst As New ADODB.Recordset
Dim fld As ADODB.Field
'Open the connection.
cnt.Open(stcon)
'Open the recordset.
With rst
.CursorLocation = ADODB.CursorLocationEnum.adUseClient
.Open(stSQL, cnt, ADODB.CursorTypeEnum.adOpenForwardOnly, _
ADODB.LockTypeEnum.adLockReadOnly , _
ADODB.CommandTypeEnum.adCmdText)
.ActiveConnection = Nothing 'Disconnect the Recordset.
End With
'Close the connection
cnt.Close ()
Dim exp As Export = New Export()
Dim xlApp As New Microsoft.Office.Interop.Excel.Application
Dim xlWBook As Microsoft.Office.Interop.Excel.Workbook = xlApp.Workbooks.Add(Microsoft.Office.Interop.Excel.XlWBATemplate.xlWBATWorksheet )
Dim xlWSheet As Microsoft.Office.Interop.Excel.Worksheet = CType(xlWBook.Worksheets(1), Microsoft.Office.Interop.Excel.Worksheet)
Dim xlRange As Microsoft.Office.Interop.Excel.Range = CType(xlWSheet, Microsoft.Office.Interop.Excel.Worksheet).Range("A2")
Dim xlCalc As Microsoft.Office.Interop.Excel.XlCalculation
Dim i As Short
'Turn off Excel's calculation.
With xlApp
xlCalc = .Calculation
.Calculation = Microsoft.Office.Interop.Excel.XlCalculation.xlCalculationManual
End With
'Write the fieldnames.
For Each fld In rst.Fields
xlRange.Offset(0, i).Value = fld.Name
i = i + 1
Next
'Populate the range.
xlRange.Offset(1, 0).CopyFromRecordset(rst)
'Close the recordset.
rst.Close()
'Make Excel available to the user.
With xlApp
.Visible = True
.UserControl = True
'Restore the calculation mode.
.Calculation = xlCalc
End With
'Release variables from memory.
fld = Nothing
rst = Nothing
cnt = Nothing
xlRange = Nothing
xlWSheet = Nothing
xlWBook = Nothing
xlApp = Nothing
Computers & Internet Logo
124 people viewed this question
David Payne
David Payne
