Can I power my laptop through th usb port
The dc power socket on my laptop top is loose, so power cuts off ever so often. My battery needs replacing. Is the any other way I could power my laptop either through the usb port or a additional battery that can be charged independent of the laptop. Would appreciate your comments.
  • 3 more comments
  • Anonymous Dec 05, 2008
    I was wondering this too.
  • Anonymous Dec 21, 2008
    same problem
  • Anonymous Jan 21, 2009
    my toshiba laptop has power problem battery is out of order new one is very costly so i want another way to power my laptop
  • bertandernie Mar 18, 2009
    same problem...... there must be a way to do this??????
  • Anonymous Apr 28, 2009
    Looking for a USB to power my Toshiba Satellite (17") laptop.
  • 26 Answers
I know you've either fixed your problem, or thrown the laptop out(still a "fix") but for posterity, and for anyone with a similar problem...
There are two answers, depending on your laptop.
First, NO, there is currently no way to charge your laptop battery by putting power into the usb port.
There ARE commercial external batteries. sadly, they will connect to your failing power-socket.(see http://www.laptop-battery.org/Power/External-Batteries/ENB003L.html)
If your laptop has a external battery charging dock, for spare batteries.... you could go that route.
you'd probably still want to follow the last suggestion.
GET IT FIXED!
Seriously... anyone with fairly good soldering skills can probably fix that powerjack. It probably pulled/pushed the traces off the main board and will require superglue, solder, and maybe a bit of fine wire, to fix. The biggest obstacle will be the dissassembly, and proper reassembly of the laptop case. It'll take a while, but once fixed, should return your laptop to 100% functionality.
I have saved 3-4 laptops with this technique. One, I even swapped the power jack to a more common size. This was to allow the use of a non-proprietary power brick(the original had fried itself).
Posted on Jun 18, 2009
  • ironsmiter Aug 21, 2014
    I will have to recommend AGAINST even TRYING this. even if you DID somehow circumvent the diodes in the USB circuit(the little electronic critters that only allow electricity to flow one way), and the design engineers were batty...you would STILL ony be able to input 500mAh at 5 volt DC before the usb control chip lets out it's magic smoke, and now you no longer have power OR usb.
    sorry, that reply was in response to spookysr and their attempt to force a male-male usb cable to charge. Now, there IS an upate, so my answer has changed. USB 3.0 SuperSpeed has changed the game when it comes to usb charging. USB 3 SS is able to handle significantly more power, and THERE IS A PROVISION in the protocol for dual-role usb ports. meaning if you have a USB3ss port on your computer(or powered hub) AND your laptop has a USB3 dual purpose port then you CAN now charge over the usb port, but this will be clearly stated in your laptop's manual. Other "normal" usb3SS ports STILL will not charge your battery, only the one dual purpose port specified by the manufacturer. In a less practical application, a person COULD take a USB 3.0 Standard-A receptacle, swap it out for a standard usb port, but wire it only to the charging circuitry as long as the normal power supply is 12 volt(60 watt) or 20 volt(100watt). and if you REALLY don't care about your electronics, or are really good(in which case, you already know this), you technically could wire a usb3.1 port as a power input AND usb2 port. Since the charging power comes from the usb3.1 extra 4 pins, theremaining 4 usb2 pins could be CAREFULLY wired back into the stock control hub. Really good electrical isolation for the power wires will be required, and by this point, you are probably better off just repairing the power jack anyway. But it CAN be done. Refer to the Universal Serial Bus Power Delivery Specification pdf for relevant information on getting it done. Also note, you will have to get a proper USBType-C1.0 passive cable to force the charge rate from usb3.1 host controller. And at this point, I bet you wish you had just paid that nice computer shop the $50 to repair your power jack :-)
    Problem Solver:
  • 7 Answers
I don't recommed doing this but technically you can power SOME laptops via their USB port. However, you can NOT charge the battery this way. You will need the ENDURANCE car battery booster box with USB function. You will need a MALE to MALE Type A USB cable - only available on Internet - RadioShack et al does NOT sell them. I do NOT know what will happen. Not even sure the power switch will control it either. May come on as soon as you plug it in I don't know. I think this method bypass the internal power conditioning circuitry so It has to be a battery which is more stable than power mains..Some manufacturers say don't do it but I think it will work as the USB power circuit is connected to main power bus of laptop. Your internal digital cicruitry, display, and drives actually only require 5VDC not 12-19V which is stepped down internally to 5V. The ENDURANCE box has enough current to handle the laptop's current requirements. I ordered my USB cable today and will try this on two busted laptops I have. Good luck!
Posted on Sep 07, 2009
  • 55 Answers
I can suggest to try to put out old power socket and buy a new one
if you can do it pay attention to respect the polarity of older socket
that will be + to +  and - to - - i think it is not difficult- delfo
Posted on Mar 22, 2008
    New Friend:
Best and cheapest solution I have found which doesn't cost all that much was just to buy a replacement power adapter off Amazon. If you can stomach the 3-5 day wait, in the long run you won't ruin your laptop, you won't over amp your circuit board--which is a death sentence and i got mine for $19.95 US Dollars. It works great and notice no difference between that and the original that came with the laptop that they want $99 at Radio Shack or $119 at Toshiba...so there you go!
Posted on Jan 10, 2010
"Fhfghhfhgfufgfljhgjfhfhgjgjhjjhguyghjgjhgkjhjhgghhgffkgjhjhjjf
hgfgfgkjfgfjhfkjgfuytfftuggygjhjhgjhgjggjjhgghghjfhgfjjjgjhjgjhgj
ghghkfgfhgjgfggfhffghfgfgffghhgghfhgfhgfggfgghfhgfhgfttfghfgfftgfghfthgfytghfyt
ccvbcbvcbvcbvfbvcbvcbvcbvcbvcbvcbvcbvcbvcvbccvbcbvcbvcbvc
asggfdghfjkhgjhgjgjlgkgjhgjhybgfhfgfgfjfgkjghjghjghjghjjgjhghgjkj
ghfhgfgfhgrshygyugjhgyugigmiyirtwwwghhjjhhmbtgtrdegrh6hhhh
jgjkhghjghjghjghjgtuytuyeqwcbvcvnbnmbmnb,mbnmnbmbnmb,m
gjfhfhgf"
is just as good of an answer as any other answer here in regards to the question that was asked. the person didn't ask how to replace the charging socket, or where to buy any OE replacement part. they simply asked if you can turn on and then keep the laptop powered through the usb port (which would be nice if someone has a solution considering we have "always on" usb ports now and the old excuse was that there wasn't voltage to usb when it was off...") OR is there an adapter to charge a laptop battery independently from the laptop (which there are but usually expensive, mostly found only in the corporate world, and are made to charge a "battery" of batteries at once, lol) you could maybe find your batteries pinout schematic and make a cable for the battery itself, but i'm sure that's way more complicated compared to just plugging a usb cable and power cord in.
Posted on Oct 30, 2013
gjfhfhgf
Posted on Sep 09, 2008
SOURCE:
Charging port
When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
May 17, 2013 | Gateway Computers & Internet
Loose dc connector Sony VAIO
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 28, 2013 | Sony VAIO Computers & Internet
Lose charging port
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first. http://www.fixya.com/support/r4799950-laptop_battery_power_supply_problems
Dec 11, 2012 | ASUS 15.6in A54C-TS91 Intel Pentium...
Cf51 wITH MOTHERBOARD dl3up1448aaa. When connected to the power supply smoke was seen coming form the power socket on the laptop. Disassembled the laptop and found just behind the socket on the motherboard...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 14, 2011 | Panasonic Toughbook CF-51 Notebook
I have aan Acer Aspire 5315 which is 2 and a half years old. The battery died so I plugged in the cable in the usual way and nothing happened no lights came on. I assumed the powercable needed replacing...
The power ports are generally the problem. If you wiggle the wire and get contact that is almost sure that is it. The Internet has folks that will fix this problem.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/ shows how to repair it yourself.
Aug 03, 2010 | Acer Aspire 5315 Notebook
My laptop lenovo 3000 N100 battery has a problem.. therefore i purchased a new battery but the problem with this battery is that when i use the battery it runs the laptop for 10 -15 mins and then with a...
My Dell laptop has a power problem.
d600a.jpg?w=300&h=258
The Dell Precision M20 Battery stops charging when I move the power cord on the DC adapter. When I start moving the cord left to right, the power LED light on the front goes on and off and the battery charge LED goes on and off too.
dell-precision-m20.jpg?w=300&h=225
I removed the precision m20 battery and tested the laptop again. The laptop starts fine from the DC adapter when the battery is removed, but as soon as I start moving the power cord the laptop shuts off. It looks like the laptop looses power immediately.
If you have a problem like that, most likely it’s related either to the power adapter or the DC-IN power jack.
First of all, I tested the laptop power ac adapter with a multimeter. The power didn’t cut off no matter how badly I moved the cord. The power adapter output voltage was 15.45VDC all the time. That means there is nothing wrong with the power adapter and most likely there is a problem with with the power socket inside the laptop.
Now I’m going to test the power socket inside the laptop.
In order to access the power socket I had to disassemble the laptop and remove the top cover assembly with the display.
You can find disassembly instructions for many HP, Dell, IBM, Lenovo, Sony and Toshiba laptops in these service manuals and guides.
In the laptop I was fixing (Tecra M2) the power jack is attached to a DC-IN harness and this harness can be unplugged from the motherboard.
As you see, I removed the DC-IN harness from the motherboard, plugged in the power adapter and tested continuity with my multimeter as it shown on the picture.
When the power cord is still, the voltage output is 15.45VDC, the same as on the plug.
But as soon as I start wiggling the plug inside the jack, the power cuts off and voltage goes to 0. It means, the power harness is bad.
The problem was fixed after I replaced the defective DC-IN harness with a new one.
In some laptops the power socket (DC jack) is soldered to the motherboard.
If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack is broken or loose.
You cannot simply unplug the jack and replace it with another one. You’ll have to unsolder the old jack and solder a new one back on the motherboard as I described in this post.
If the power jack is not broken but loose (not making good contact with the motherboard) you can resolder the old jack without replacing it with a new one.
If you want to buy a new one,you can see more information from http://www.udtek.com
Feb 18, 2010 | Lenovo 3000 N100 Notebook
Power socket is loose
dc jack socket for Sony VAIO VGN-FW is very easy to loose, I think you can replace the cabled dc jack, no solder work, plug in and work, see this reference page: http://www.lapdiy.com/sony-vaio-vgnfw-series-power-jack-port-connector-dc-in-cable-p-2647.html
the above item is with ground cable, it is known that sony FW uses both harnesses with or without ground cable, you can cut the ground cable directly if your laptop does not use it, or order from this page for the one without ground cable: http://www.lapdiy.com/sony-vaio-07300012492a-power-jack-port-connector-dc-in-cable-p-2782.html
hope this can help you
Feb 04, 2010 | Sony VAIO FW Series VGNFW275JH
Dell Inspiron 1505; Battery does not charge; DC jack is loose..
You have either a faulty connector plug on the power adapter which connects into the laptop or the loose power input socket on the laptop is faulty. This is because you need to press the connector upwards to make electrical contact.
Test the connectot plug on the power adapter with a multi-meter, wriggle the connector to see if your get the voltage to fluctuate, if it does not then the connector is OK anf the fault is in the laptop power input socket.
If the fault is in the power adapter plug or the laptop's power input socket, this can be repaired, a techo would have no trouble in repairing these faults.
May 22, 2009 | Dell Inspiron E1505 Notebook
Power problem
Check the port on the laptop where you plug in the adapter. Try to wiggle and see if you have a loose AC/DC input jack.
If yes, you need to have it repaired, unfortunately. If not, remove the battery then plug the adapter and see if you can see a light or if you can boot up the laptop.
You may try plugging it in on a different wall outlet.
Hope this helps.
Sep 17, 2008 | Computers & Internet
VAIO VGN-S460
check adapter output also may be problem with dc socket on laptop loose or somthing.
Apr 11, 2007 | Sony VAIO VGN-S460 Notebook
Open Questions:
Computers & Internet Logo
11,299 people viewed this question
Ekse
Alun Cox
