Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Bosch dishwasher The diswasher wont turn its self off it will continue to wash and will not move on to dry the dishes.
  • 4 more comments
  • diane1970 Mar 22, 2008
    I have the same problem it does not stop, i have noticed that the water is cold too.
  • friarlicious Apr 27, 2008
    I have the Bosch SHU4002 dishwasher, and it has also stopped advancing. It seems to stall during wash and during rinse, so we manually advance the knob one click. But this may happen several times during a cycle.
    I took apart the door, and removed what I now know as the 161 degree thermostat (Bosch part 169444). When I disconnected it there was no continuity through it (tested with my multimeter: it read infinite resistance). In reading online various place it seems that thermostats should read normally closed (at room temp), i.e., should have negligible resistance, not normally open. BUT, some thermostats for various devices/appliances are normally open. Does anyone know whether this thermostat should be normally open or normally closed?
  • Anonymous Feb 04, 2009
    Suffering from similar problem. Unit will run through the cycle and not stop. Indicator shows 1 minute, but washer continues wash, will not drain and dry.
  • thoefer1 Feb 18, 2009
    I have the same problem with a SHU4002. I have to manually advance the knob through two spots in the cycle. My dishwasher is also not as hot at used to be, as if the heating element isn't working. Anybody find a solution yet?
  • Anonymous Apr 11, 2009
  • friarlicious May 11, 2010
    To Guest: How can we know whether the problem is in the heating element or the thermostat. I'm not even sure of the wiring of the unit... so I don't know what leads to check. Job security by obscurity for the appliance repair guys, I guess!
Almost certainly your element is faulty. waret does not heat up allowing timer to proceed
Posted on Mar 27, 2008
SOURCE:
Runs through cycle, but dishes and glasses do not dry, they are soaking wet.
10 Tips to Help the Dishwasher Run Better - Cleaning Tips ...
www.thekitchn.com/10-tips-to-make-yo...
Apartment Therapy's The KitchnFeb 24, 2014 - Well, we're here to help, with 10 tips for making your dishwasher run its best. ... loading up to help reduce particles stuck on dishes once the cycle is over. ...water to flash dry and not roll off your dishes, taking the ends of the dirty bits with it..... but can lead to damage, particularly of any glasses you put in the ...
[PDF]Dishwashers - Frequently Asked Questions ... - Bosch
www.bosch-home.com/Files/Bosch/In/in/Document/Bosch.pdf
this cycle the dishwasher dries the dishes. 3. ... dishes. During this time, you do notneed to be around the dishwasher as it ... Does it also dry the dishes after the wash?... You can put utensils that are made out of steel, ceramic, glass, plastic which is ...No, the dishwasher runs the whole washing programme automatically.
Why is My Dishwasher Not Drying the Dishes? ' Dr ...
Dec 03, 2015 | Dishwashers
How do I turn up the heat to remove most condensation after washing?
As part of the current ecological, energy-saving, environmentalist-wacko movement, dishwasher makers have cut back on the heating used to dry dishes. In fact in many dishwasher designs, they have eliminated the drying vent altogether, and instead use a condensate or condensation-drying system. In this system, the last rinse cycle is heated to a high temperature, to heat the dishes. The water is then pumped out, and the dishwasher shuts down. The theory is that water will evaporate off the hot dishes, condense on the sides of the dishwasher, and run back down into the sump area. Bosch was one of the first diswashers to do this, and it works fairly well for them. Other manufacturers have tried this, with varying results. Here's what you can do to improve drying:
1. It is imperative that you use rinse-aid (Jet-Dry). This allows more water to flow off the dishes and what flows off does not need to evaporate.
2. If the dishwasher has the options, turn on high-temperature wash and sani-rinse. This gets the dishes hotter for better evaporation.
It is possible that the heater may not be working at all, and that will cause poor washing performance and no drying. This is very rare in dishwashers less than 3 years old. Most likely, poor drying in a new dishwasher is caused because you are not using rinse-aid.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 21, 2014 | Whirlpool Dishwashers
My diswasher won't dry my dishes. It leaves them
if no rinse agent is present it doesnt matter how hot the water gets they will still not dry check unit make sure it is full. rinse agent is only to aid the drying process the machine will wash happily without it but not dry.
Feb 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SMU7052UC gets stuck in wash cycle. Pressing alot of buttons, on/off, I can move it to rinse where it sticks again. No drying either. Any suggestions?
I have a 10 year old Bosch SMU 7000 and the drying function has ceased. Dishes are wet after all cycles. From what Ive read this isn't worth fixing because Bosch are so difficult to get into.
Jan 23, 2010 | Bosch 24 in. SMU70 Built-in Dishwasher
Bosch SHE43MO2UC/48 - Dishes do not dry properly
rinse aid is required to aid the drying process either it is underdosing or the wash programme is too short temps over 55 degrees are needed for satisfactory drying result.
Nov 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch dishwasher SGS55M2 leaves dishes wet
Are you using drying agent?If not you have to use it in bosch dishwashers.When the cycle is completed is it hot,steam rolls out.if not you have a heater problem or thermostat problem.
If you need more info please ask
Feb 05, 2009 | Audiovox Bosch 718 World Cellular Phone
My bosch dishwasher will not dry the dishes
this dw to save energy works this way- the final rinse will reach a temp of 161 F . the dishes have to absorb this heat. when the cycle is complete the dishes become a heater in themselves radiating the heat they absorbed during the final 161 F heat. If you have any tupperware or plastic dishes in the unit they will not absorb heat therefore not radiate the 161 f temp need to dry all the dishes. try to avoid plastic items and they must always have jet dry. this is the european way of conserving energy. on the old ge or whirlpool they had electric element in the bottom that would bake the dishes dry ....not these..but they do save alot of energy.. it helps right after a cycle to crack the door open release all the steam from the unit
Dec 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher she45m
Just bought a Bosch dishwasher and we were told that they have no heating mechanism to dry the dishes, which is why they are more energy efficient.  You are supposed to leave the door closed for at least one hour after the cycle is complete.  The heat that has built up inside during the wash cycle will dry the dishes.  It is also recommended to always use JetDry. If you follow this advice, the dishes will come out fine.
Mar 20, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
435 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
