Question about Nikon D70s Digital Camera
3 black tiny spots on picture shot with nikon d70s
It's not a fungal on the lens coz the problem occured with different lens.
    Problem Solver:
  • 7 Answers
Shoot a white wall - this is the best way to identify and localize dust.
Check here for special brushes to clean the sensor
http://www.visibledust.com/products.php
if you are uncomfortable doing this, have it done - pro photo shops offer this service.
It is tempting to touch, blow, use compressed air - DON'T if you like your camera.
Posted on Apr 03, 2008
    Novelist:
  • 155 Answers
You probably have some dust on the cameras sensor.
There are a couple of sample images of what this looks like here and here.
Dust spots typically have a softish edge to them and affect more than 1 pixel. (if it is just the 1 pixel affected, with a very sharp edge, this could be a defective sensor).
Follow the instructions in the manual for cleaning the sensor. Avoid touching the sensor (unless it is with a specialist sensor cleaning brush) and avoid cans of compressed air; use a hand-blower brush instead.
Matt
Posted on Mar 22, 2008
What is r7 on the Nikon D70s?
The number after the "r" tells you how many more pictures you can shoot in the current burst before the buffer fills up and the camera has to slow down. If you're only taking single shots or short bursts then it shouldn't affect your shooting at all.
Oct 30, 2011 | Nikon D70S Digital Camera with AF 28-80mm...
I have a D70 with 26,000 shutter releases. Just recently it stopped composing pictures. In other words, I can take a pic just fine, but the playback is black, it saves to the CF card, and if I look at on...
Remove the lens and fire off a few shots while looking inside. Check to see if the mirror flips up out of the way and that the shutter opens exposing the sensor.
Oct 09, 2011 | Nikon D70s Digital Camera
My D70s is not taking sharp, clear pictures anymore - everything is a little unfocused. I even changed lenses and the problem is still there.
Hi Sarah,
When you compose a shot, and depress the shutter button 1/2 way - you should hear the focus motor run to find the best focus. You should also see the image eventually become sharper in the veiwfinder, during this time. Focus can only occur when there is sufficient contrast. If the area is dimly lit, the D70's focus assist lamp should come on (unless disabled in the menu) to help bring out enough contrast for focusing. It has limitations however.. it too dark, distant or still lacks contrast, the camera will not be able to focus. This is usually a problem for night time shots or poorly lit indoor shots with slower lenes. You shouldn't run into this problem on bright, sunny days or with a fast, prime lens.
The D70 and many Nikon lenses for that matter, have the ability to switch between AF and M focus modes. An image of the switches is below:
It is important that BOTH switches not be in the M position. Different lenses have different designations for Auto Focus. The one pictured on the lens allows for manual override when the lens is in the M/A position. This simply means you can twist the focus ring on the lens without first needing to change the position of the switch to M. It is a nice, handy feature. Other lenses without the M/A position would require that the switch be moved first, an additional step that could be the difference in getting the shot - or not.
Make sure you're not trying to hand-hold the camera when the shutter "1 / 1.5 x Focal length". That is, if you're shoot at 100mm, you should use a tripod if the shutter speed is 1/150 sec. If at 300mm it would be 1/450 (or 1/500) of a second. At 50mm you should be 1/60 - 1/100 of a second. That's just a guide.. some people can hold it steadier than others and the new vibration control built in to lenses can lower that shutter speed too. If you're running into that as a problem, bump your ISO up one and try again.
THose are a couple of things to check out. Hopefully, one will solve your problem. Good luck! please rate my reply - thanks!
Aug 01, 2011 | Nikon D70s Digital Camera
I have a Nikon D90 with 18-105mm lens. I lived in Bangladesh. FUNGAL spot apears on my lens. Humidity here in Bangladesh is very high. May be that was the reason of Fungal attach. How can I clean the...
If it's inbetween the lens elements, there's no way you can get at it. It would have to be taken apart by a service facility recommended by the manufacturer.
Sep 24, 2010 | Nikon D90 Digital Camera with 18-105mm...
Pictures taken all come out black
CCD FAILURE!
Call NIKON for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
May 22, 2009 | Nikon D70s Digital Camera
PICTURE WITH BLACK SPOT
CCD sensor has some dirt/dust on it . Set camera to B ( in manual mode scroll until 'bulb' is displayed in the top display ) . Take lens off and release the shutter and keep the button pressed down so that the sensor is exposed : use blower to remove dust/dirt but NB do not touch sensor surface as you will make it even dirtier. Take some shots to see if the spot has gone and repeat if it has not disapear.
Jan 22, 2008 | Nikon D70 Body Only Digital Camera
My lens has marks on it will this affect the picture?
The cobweb marks are either
1. adhesive between elements failing
or
2. Fungal growth inside the lens barrel.
As to usability-
It is surprising what one can away with glass damage - scratches and the like
All you can do is to try it and see
Dec 08, 2007 | Nikon D70s Digital Camera
Spot on every shot
Your sensor may have gotten dust on it to confirm this, set camera to a small aperture eg. f22 and take a picture of a white page then set camera to a large aperture eg f3.3 ant take the same picture. If it is dust you will see the spot on the shot taken at f22 and not the one taken at f3.3. This can be solved by having the sensor cleaned. If the gray spot is on both images you most likely have a damaged sensor
Oral Davis
Trinidad West Indies
Nov 24, 2007 | Nikon D80 Digital Camera with 18-135mm...
My nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Aug 05, 2007 | Nikon D70s Digital Camera
D70s
If this is a small spot it can be a dust on the censor. To confirm take a snap of the plain clear wall. If there are spots on the picture then it can be from the dust on the censor. There is a procedure of cleaning dust from the censor in the user manual. Be extra carefull since the scratch or stain on the censor will ruine you camera
Jan 29, 2007 | Nikon D70s Digital Camera
Nikon D70s Digital Camera Logo
73 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
