Question about PQI Intelligent Stick (267027) Hard Drive
PQI Intelligent Stick -- interrupted file transfer, removed unsafely... rescue data?
I had my USB drive plugged into a Linux computer and was transferring files to it, when an error said a file could not be transferred. I hit cancel, the drive window shut, the drive disappeared off the desktop, and was not found under /media. I unplugged the drive and tried several other computers, linux, Windows XP, Vista -- drive appears as new hardware, shows up in My Computer with generic name, but I can do nothing with it because it won't open -- "no disk in the drive, please insert disk to drive."
I've tried every (free) recovery software I can find -- they either don't see the drive or see it but say it is empty. Properties says it's full. Disk manager doesn't see it. Hardware manager says it's functioning properly and already has the proper driver installed. Rebooting with drive in doesn't help.
Anything else I can try to recover the data on the disk?
    Novelist:
  • 163 Answers
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 26, 2008
SOURCE:
I cant delete files from my usb-stick. i thinks a virus is stopping me from deleting the files.can anyone please tell me what i can do?
insert drive in your computer but dont open any files. close out the screen that comes up for the drive. then go to my computer and right click on the drive one time. then you should see scan for viruses. do that to check for and delete viruses. then go and open the usb drive and try to delete the files
Mar 21, 2012 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Why is my intelligent stick write protected and why can't i format it or at least take the write protection off of it
Remove the device from your computer and check the side of the stick for a small switch that has a picture of a lock around it somewhere. If there is then push it to the other position and that should unlock it for you
Mar 02, 2010 | PQI 512MB Intelligent Stick USB 2.0 Flash...
I have an 8G Imation flash uSB. It has worked fine till recently but when I insert into port now it shows the files with hieroglyphic names and says it can't open them. Is there something I can do? Thanks...
i think you can defrag a usb drive, if it shows on your 'my computer' list of removable drives- you might try this- you can also run an anti-virus check on it, if you have an anti-virus prog. if that don't work, and the data is stored on your hd, then try re-formatting it.
if that don't work, toss it, and get a new usb flash drive!
good luck!
Oct 04, 2009 | PQI 512MB Intelligent Stick USB 2.0 Flash...
My usb intelligent stick installs ok and shows
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Mar 27, 2009 | PQI 128MB Intelligent Stick USB 2.0 Flash...
PQI 1GB Intelligent Stick USB 2.0 Flash Drive
clean your usb port if it does not work open my comp then watch in that window and keep inserting and uninserting until u see my comp reconize it if you have to do the ladder it is time for a new flash drive they do not last forever
Dec 03, 2008 | PQI 512MB Intelligent Stick USB 2.0 Flash...
When I plug it to my PC,It says "please insert a disk into drive".And I can't format it. T with Tanks
Jul 11, 2008 | PQI 512MB Intelligent Stick USB 2.0 Flash...
I found no instruction booklet and I never used a flash drive USB 2.0 Flash drive. Is there somewhere I can find this on line?
This device is very easy to use you don't actually need a booklet for it , this use as a portable storage disk just plug it to a usb port of you computer then you can save files on it.
May 12, 2008 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Swap files in a flash 1gb
copy pictures from hdd and paste to stick drive
Jan 05, 2008 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Open Questions:
See all PQI Intelligent Stick (267027) Hard Drive Questions
PQI Intelligent Stick (267027) Hard Drive Logo
364 people viewed this question
Top PQI Computers & Internet Experts
Ekse
Alun Cox
Are you a PQI Computer and Internet Expert? Answer questions, earn points and help others
