If your Pioneer SW-8 subwoofer is not powering on, there are a few things you can try to troubleshoot the issue:
Check the power cord: Make sure that the power cord is securely plugged into both the subwoofer and a working electrical outlet. If the power cord is loose, try unplugging it and plugging it back in.
Check the power switch: Make sure that the power switch on the back of the subwoofer is turned on.
Check the circuit breaker: The subwoofer may have a circuit breaker that has tripped. Check the circuit breaker on the back of the subwoofer to see if it has tripped. If it has, reset it by pushing the button back in.
Check the fuse: The subwoofer may have a blown fuse. Check the fuse on the back of the subwoofer to see if it has blown. If it has, replace it with a fuse of the same rating.
Check the auto power function: The subwoofer may have an auto power function that turns it off after a certain amount of time if there is no audio signal. Make sure that the audio source is playing and sending a signal to the subwoofer.
If none of these steps resolve the issue, there may be a problem with the amplifier or power supply in the subwoofer.
I manage to slove to my DPX-U5120 Subwoofer level adjustment. In STANDBY mode, Press the Main Volume button and turn to Setting, turn until you find the SW Preout, Swith to normal mode, its won't work if u switch to REAR
Go back to CD/USB Mode, Then Press the Main Volume and find Audio Adjustment and now u can find the Subwoofer Level , Sub Phrase and Sub LPF adjustment.. Um Glad i found this and Happy Setting
If I understand you, you're observing the speaker cone moving in one direction without any input. That would say the internal amp is malfunctioning and pushing DC to the speaker. Beyond that I can't say, but it is endangering the driver.
Here's your manual. Check Pg. 9 for correct Sub Woofer connection. Leave the SW=YES setting as is if you any small speakers in the system. It can be set to SW=PLUS if you want all bass signals sent to the Sub Woofer. It should only be set to SW=NO if no Sub Woofer is connected. Experiment between the YES and PLUS settings and leave it where it sounds best to you.
If this was helpful, please rate it "4 thumbs up" - thanks & good luck!
Disconnect its input cable to see if a true lack of signal lets it go to sleep. If not, it has a bug. Otherwise, you probably have some sort of signal present on the sub cable.
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
