Question about Acer Aspire 7720 Notebook
BSOD? I've had my notebook a grand total of 3 days and it is now not working....kind of. I can access all aspects of my computer as my My Documents pops up when I log in. No other things show up. I can obviously navigate, opening FF or IE to surf the web, but I've got no start bar, no background, no icons, nothing. So I've basically got a black screen of death. Any ideas until I call customer support?
  • Boo200206 Mar 22, 2008
    I can make one, I still oddly have full access to my computer, its just acting like the start bar and desktop can't load.
    Genius:
  • 3,587 Answers
Sounds like you need a reinstall of the operating system..did you get a recovery disk?
Posted on Mar 22, 2008
  • Patrick Michaels
    Patrick Michaels Mar 22, 2008
    ok..then do that, and see what happens...
SOURCE:
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
I have an ASUS U52F series, and every time I launch Empire: Total war. The Game crashes my computer on startup, nothing works, not ctrl+alt+delete , I've even let it sit for 3 hours, and nothing
Well it might be that your asking too much from your laptops graphics card. My solution would be installing a later fersion of direct x. Also some other hot keys to try are: ctrl + shift + esc. And : alt + tab or f4. Hope this helps.
Oct 20, 2012 | ASUS U52FBBL5 156 Notebook PC
I've had my compaq presario cq61 for about 2-3 years. A while back it would occasionally have a kind of shaky/blinky screen but just in the past week it's like the screen has stopped working.
The problem may be due the graphics card or data cable or backlighting.
The data cable can be severed over time though opening and closing the display. This can be replaced.
The backlighting/inverter dies, some-times the windows desktop screen can be seen if one looks carefully. This can also be replaced.
Try connect your notebook to another computer's monitor via VGA or HDMI out.
If this works then the problem lies with your LCD screen.
Take care!
damnor01
Sep 11, 2012 | HEWLETT-PACKARD Compaq Presario CQ61412NR...
I have a Gateway MX8734 laptop - it's about 4 years old or so. Almost every time it's moved while on, it shuts down instantly. Other times, we get a BSOD error indicating that something's up...
I see how frustrating it can be to have a computer that is as unreliable. In this issue, as you described, I see that there are a couple of things that might be causing the failure in your portable system. One is the video card driver, another is the memory module. The reason for the failure on the memory module is that once an operating system is loaded into a computer, it gets loaded in the memory module, and failure of the device will usually result to BSOD.
Here is what you can try to do to further isolate the issue.
1. uninstall the video driver of your computer
a. press the windows key + R
b. type devmgmt.msc then click on ok
c. click on the plus sign beside the display adapter and you should see there something that says Intel GMA 950 Dynamic Video.
d. right click on that item and then choose uninstall.
e. download this file into your computer desktop: video driver
f. restart your computer. when it asks for a video driver for your computer, cancel it then double click on the driver that you downloaded into your desktop.
if this does not resolve the issue, you will need to do trial and error on the memory module on your computer.
2. Reseat the memory module on your computer. Download this user manual so that you will be guided in getting access to the memory module of your computer.
3. if step 2 does not work try to work your computer with one memory module at a time (assuming that you have two memory module installed in your computer. This is to find out if there are any defective memory module installed in your computer.
I do hope this information is enough to fix your computer. Do give me an update on what happens so that we will be able to further diagnose your concern.
Note: it would help much if you take a note on the BSOD error that you encounter.
Jul 21, 2011 | Gateway MX8734 PC Notebook
My mouse is lock need help please
Good day there, glad to be of assistance to you today.
What kind of mouse is it? Is it a bluetooth mouse with batteries?
1.Is it a regular usb mouse with lights on it? If so, please check if you've got lights on the mouse,it means it's being detected by the notebook. 2.Please shut down your computer first, as soon as the the computer turns off, unplug and plug the mouse back in then power it back on. 3.If that doesn't work, try plugging it to a different usb port and restart the notebook. If it's the same issue, please check if the mouse will work on another notebook when plugged in.
I hope this has helped you resolve your concern. Have a wonderful day.
May 12, 2011 | Dell Inspiron Mini 10 Notebook
Bsod 0x00000034
Check the size of Random Access Memory (RAM) in your computer. Its small size could be the reason for this problem as many of today's software need large amount of memory to operate in smooth manner. Additional RAM will also increase the efficiency of your computing particularly for gaming.
• Excessive use of computer or a malfunctioning cooling system can make computer/laptop overheated. Whenever system is heated, its efficiency will go down. BSOD is one possible consequence of over heated system. Keep fan of your computer in fully functional mode.
• Registry is the most vital part of Win 7. Corrupt registry is the biggest reason for BSOD in Win 7. One way is to clean registry manually but manual tricks could wreck your system completely if you are not a top notch computer expert. More appropriate way is to buy a good registry cleaner reginout and PC optimizer
Sep 30, 2010 | HP Pavilion Dv3-1075us Notebook
Black screen
• Registry is the most vital part of Win 7. Corrupt registry is the biggest reason for BSOD in Win 7. One way is to clean registry manually but manual tricks could wreck your system completely if you are not a top notch computer expert. More appropriate way is to buy a good registry cleaner and PC optimizer. It will clean registry to fix BSOD and regular scan will make sure that it will not happen in future. Moreover, it will speed up your computer.
Do you need quick fix for BSOD and want to increase PC speed? The above guidelines allow you to take measures to fix and keep your Windows properly maintained. Prevention is the best cure.Download reginout registry cleaner intel partner
Sep 01, 2010 | MSI S260 (S260100) PC Notebook
ACER ASPIRE NOTEBOOK MODEL ASPIRE 4736ZG, IF I CHANGE RESOLUTION TO 1024X768 SCREEN SIZE BECOMES SMALL. HOW TO ADJUST VERTICAL AND HORIZONTAL SIZE SO WHOLE SCREEN CAN FILL IN.
i have acer 4736zg ;that i bought 4 months ago my computer gets heated and shuts down automatically; it works nicely for a week; and gets heated and shut down automatically 3 to 4 times in a day; i am using windows 7 and kapresky anti virus before my computer has windows vista and mcafee antivirus. yesterday my computer showed blue screen death for six times each time i connected net ; i checked the memory status and now its ok but it shutdown for three time in last 12 hours; can u plz help me out
Dec 16, 2009 | Acer Aspire 4720 Notebook
Bsod problem due to reliance lxu 800 usb modem drivers
Hello dear, I'm one of the users of LXU 800 modem. I tried all the sources and found there is no way resolving this issue because the manufacturer has not yet released any updates till now. I also heard the team at Reliance doesn't care about this issue because the actual manufacturer is LG. Anything to share? Meet me at [email protected] Have a great day. Yours truly, N Bhargav Reddy.
Aug 15, 2009 | Computers & Internet
Acer Aspire 7720 Notebook Logo
37 people viewed this question
Ekse
Alun Cox
