Question about TruTech PVS31170S1W 17 in. LCD Television
Trutech tv and computer hookup
I purchased a VGA cable and connected it to the Tv and Computer but the TV is telling me no signal. Do you have any idea what I am doing wrong?
Thanks
  • Anonymous Dec 21, 2008
    This is a 19" HDTV DVD and PC Monitor. Plays DVDs perfectly but no signal for TV. As a computer monitor I am sure it will will work with the right connection, but that is not what it was purchased for.
  • ramon_cis Dec 30, 2008
    no sign for vga and can not use por mi pc!
Press the function key on your remote and then the up/down button and change it to PC. Also you can adjust the PC screen by going into the TV Menu then into settings then PC
Posted on Mar 28, 2008
How to connect Acer Aspire 5530 to TV
If your TV is liquid crystal, or with VGA interface of the TV, the computer also WITH VGA interface don't need to buy TV card.Otherwise not only buy TV card, still need to buy a VGA connections, five meters. But VGA connections only transfer video, not transmit audio. So, you need purchase another audio signal lines, according to TV and computer their audio interface situation choose, both prominent circle mouth speakers audio signal lines. , 5 m.Also you can buy take S terminals output graphics CARDS, but it also requires TV also have S terminal input interface.
just have a try,I do not know if useful!,source from autodvdgps
Jan 09, 2012 | Computers & Internet
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
How to connect hitachi tv 42" to internet inorder
A computer and a VGA computer cable. The TV has to have the computer VGA hookup in the back of the set. Once hooked up you will need to get the proper input on the TV to VGA or PC.
Jun 23, 2011 | Hitachi 42HDS69 42 in. Plasma Television
What do i need to attatch lg model# lh40 or 1080p to ny computer?
U have a VGA signal cable right there out of ur computer LCD monitor used that.Used a VGA signal cable connected to ur computer and than to ur tv VGA input than find the tv input like in 1,2,3,4 find the computer VGA signal that it.If u have new and a recent computers like a DUO CORE processor 2 or 3 it have a HDMI cable hub design in this computers.Just used a HDMI cable connected between the computer and tv to for work the best in HD.
May 09, 2011 | LG Televison & Video
I own a Toshiba NB 205 Notebook PC. I connected my flat screen TV to the notebook so I can use the TV as the Toshiba's monitor. I purchased a male-to-male VGA cable and plugged it into the VGA port on...
you need to tell the computer to move the signal over ---look for a picture of 2 tv screens on the laptop usually F5 or F8 (use with Fn key)otherwise right click on the desktop>choose PROPERTIES>SETTINGS
Jan 01, 2011 | Toshiba Computers & Internet
PC to tv VGA cord hookup. Installed but it said it has no single, will be used as main monetor. Workes but I ca'nt use my keybord to try to get single to tv. a1600n has onley one VGA port and nothing else...
First idea to try: make sure the TV is on (saying no signal) before you turn on the computer. Several TV/monitor units will not respond if the computer is already on when the TV is turned on. Check that you have a good cable (they do fail) and well-seated connections. Then double check that your VGA port is sending a signal out; use another monitor to check. You may have to change your BIOS or graphics card settings. If no signal at the port, you should also check, if using a graphics card, that you have sufficient power to the card from your power supply and it is well-seated in the slot.
I hope this helps.
Dec 20, 2009 | HP Pavilion a1600n (882780776265) PC...
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
VGA cable from the computer to the TV the TV shows no signal
Tell me model of your computer and TV. How do you connect PC to TV, with s-video cable (looks like circle) or width two colored cables? Try to adjust video-card driver. There must be function like "find my TV".
Mar 27, 2009 | Sony BRAVIA KDL-40V3000 Television
Hocking up my computer to a t.v.
Hook The VGA Cord (PC INPUT) into Your Laptop's Hookup Spot
Turn The TV Input to VGA Or PC or Computer and on the Laptop it should show up if you Hit The Function Key + F8
If You Are using A Desktop Hook It To the VGA Out Just Like You Where Hooking Up To A Computer and Turn The INPUT on the TV to VGA or PC or Computer and it should show up just like A Computer Monitor
Hope I Helped
Dec 20, 2008 | TruTech PM1919BXA1 19 in. LCD TV
Flat Panel Insignia 19
Lets see the cableing..
So you have a mac with a mini-dvi slot, you have a mini-dvi to dvi adapter, and then Dvi to vga adapter which connects to the tv?
The mini-dvi to dvi adapter doesn't have the analog VGA signal your tv needs. If I understood right.
Apple's mini-DVI to DVI-D cable does not carry the analog signal coming from the mini-DVI port on the Apple computer. This means that instead of buying a single mini-DVI cable from Apple and using a cheap DVI-to-VGA adaptor when you need VGA output, you must purchase another mini-DVI cable from Apple.
May 20, 2008 | Insignia IS-LCDTV32 32 in. Television
TruTech PVS31170S1W 17 in. LCD Television Logo
312 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
