You can get the Unlock Code for Motorola V360 from ProUnlocking.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code for your Motorola V360 .
Hi, You can get the unlock code for a Motorola v360 from www.wickedunlock.com/motorola-v360/rs11wp9/ at affordable cost. Here are the steps for unlocking a Motorola V360, 1 - Switch ON your Motorola V360 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
When you change the ring on your Motorola V360 from the standard ring to another of your choice, you give the phone a personal touch. Rings, or ringtones, are included with your phone. You can also download and install ringtones from a mobile content provider or your mobile service provider. The ring you select sounds anytime you receive an incoming call. You can change the ring at anytime through the Motorola V360's settings menu.
Instructions
1.Press the "Menu" key on your Motorola V360 and click "Settings."
2.Click "Ring Styles" and select "Style Detail."
3.Highlight "Calls" and press the "Change" soft key.
4.Highlight the ring you want to use on your Motorola V360. When highlighted, a brief preview of the ringtone will play.
5.Press the "Select" soft key to choose the ringtone.
6.Press the "Back" key to set the ringtone on the Motorola V360
Read more: How to Change the Ring on a Motorola V360 ' eHow.com http://www.ehow.com/how_8468915_change-ring-motorola-v360.html#ixzz1XEda3gRH
---a score of 4 is highly appreciated-----
---if you think this resolution is helpful kindly click on "YES"----
---you may also leave testimonial-----
Thank you for choosing fixya
Roger
Do you have the PC Data cable drivers installed in your PC. If not, become a member of this website and you can get all of your downloads free.
Go to this site and sign up to become a member. (It's fast and free.)
The site has a download link for the Motorola Tools (PC) Suite - and PC
Driver download. (All free)
Are you using Micro SD transflsh memory?? Format the Card on the PC using FAT, after that use a CARDREADER and
put these folders on the card: MOBILE and in the mobile folder put
audio, video, kjava, picture, temp! Shutdown your Motorola, remove the
backcover and plug-in the card! After that Start Your Motorola and copy
a file from the mobile's memory on the CARD! It should work!
Hope it Helped You,If so give an "High Five!" [;)]
probably faulty firmware, or the battery blown.
if the firmware is faulty and cant usb connect, the fone is probably stuffed.
if battery blown, just buy new battery.
