Question about Sony Handycam DCR-TRV460 Digital Camcorder
Inserting tape into camcorder
When I put a tape in the camcorder and close the compartment, the tape will not retract within the camcorder. The motor runs but the tape will not go down. When I remove the tape and close the compartment, it will go down just fine.
  • Anonymous Apr 04, 2008
    The last time I try to put the tape back in, the tape holder would not retract. Now it is stuck in the open position. In the past it had done this, but was able to retract after a couple of tries. It had rarely been used and I have brought it brand new. Please help!
    Scholar:
  • 173 Answers
Bent guide pins, dried out grease, belts got old although you say new, some object stuck inside jamming gears.... the list goes on.
Posted on May 14, 2008
SOURCE:
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
Cannon zr100 digital video camera tape compartment will not retract and tells you to remove tape,, also tried other tapes.. What could be my problem?
This is caused by problems with the mechanism. There should be an indicator on the LCD screen when this happens. If the indicator shows a teardrop, it means the unit thinks it has moisture (dew sensor).
The most likely fault is a defective capstan motor, the motor that moves the tape through the camera. Time for a Canon service center.
Mar 28, 2010 | Canon ZR100 Mini DV Digital Camcorder
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Thanks.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
I cant close the tape compartment
Its a mechanism problem , you need to take it to service centre , will cost about $100 in India
cannot help sorry
Apr 20, 2009 | Sony Handycam DCR-PC101E Mini DV Digital...
Tape compartment will not close
This happened to my sony DCR-IP7E, I had to have this repaired by a camera shop of £129.00 with 12months gtee, work like a new one
Dec 30, 2008 | Sony Handycam DCR-IP7E Micro Digital...
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
Sony Handycam DCR-PC1E
Yeah ! Your problem is very simple. u can solve it on your own.
If you dont put the tape the comparment closes well and as soon as you pot the tape the compartment does not close , Right ?
The solution is there within ur hands itself.
If you want the compartment to be closed, then simply dont put the tape inside. let it be outside itself. U see, its so easy !
Aug 08, 2008 | Sony Handycam DCR-HC90 Mini DV Digital...
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
'Remove the Tape' message
if you havent found a solution already, basically it means your camera is screwed up and has dirt or something inside it. so you have to take it to a service centre. :)
Apr 14, 2007 | Canon MV800i Mini DV Digital Camcorder
Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Mar 15, 2007 | Canon ZR60 Mini DV Digital Camcorder
Sony Handycam DCR-TRV460 Digital Camcorder Logo
181 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
