LEXMARK Printrio X1150 / Windows 98SE Scanner works fine but Printing and Copying give message "PC not communicating with Printer". Removed and re-setup from LEXMARK CD - same result. Changed USB cable and checked connections - repeated above - same result From Syslog.txt : USB INFORMATION *************** USB Host Controller Intel 82371AB/EB PCI to USB Universal Host Controller Root Hub Name 0000000000000009#{f18a0e88-c30c-11d0-8815-00a0c906bed8} Root Hub Ports 2 Details of Installed Devices to USB =================================== Total Number of Devices Installed is: 5 --------------------------------------- Device Name USB Root Hub Device Type USB Hardware ID USB\ROOT_HUB,USB\OTHER_ID Device Status Device Not Connected Device Name USB Printing Support Device Type USB Hardware ID USB\VID_04E8&PID_3256&REV_0100,USB\VID_04E8&PID_3256 Device Status Device Not Connected Device Name Generic USB Hub Device Type USB Hardware ID USB\VID_043D&PID_007A&REV_0100,USB\VID_043D&PID_007A Device Status Device Connected Device Name Lexmark X1100 Series Device Type Image Hardware ID USB\VID_043D&PID_007C&REV_0100,USB\VID_043D&PID_007C Device Status Device Connected Device Name InkJet Color Printer Device Type USBPrinting Hardware ID USB\VID_043D&PID_007B&REV_0100,USB\VID_043D&PID_007B Device Status Device Connected
  • 12 Answers
SOURCE: lexmark 730 printer problems
go to file in the top left corner of your screen,click on it and the click on print
Posted on Mar 03, 2008
  • 148 Answers
SOURCE: unsupported printer cartridge
uninstall printer, reboot and then reinstall using the lexmark printer cd or downloaded drivers.
Posted on Mar 10, 2008
Agent Blue
  • 39 Answers
SOURCE: Hi. I have previously downloaded the
I'm assuming you're using Windows XP. If not, these directions may differ a little.
  1. Click Start > Printers and Faxes.
  2. Right-click on Lexmark X75, and then click on Properties.
  3. Click on the Ports tab.
  4. Find Lexmark X75 under the Printers column (or look for which item under the Port column is checked).
  5. Chances are it somehow got changed to COM or LPT. Find any available USB port and check it. Click Apply.
  6. Try to print. If it doesn't work now, you'll probably get a different error, something like "Cannot Communicate". If that happens, go back to theProperties window and try checking any other USB ports you see there. If there aren't any more to try, you may have to uninstall and reinstall the drivers to get it working.
Posted on Aug 07, 2008
Posted on Sep 19, 2008
  • 928 Answers
SOURCE: Device will work faster on USB 2.0 pop-up message occurs when USB Device is plugged in
That means that the USB drive that you have on your computer is either on the USB 1.1 driver and you have to update it or your computers USB is not capable of USB 2.0 speed. First thing you need to do is find out the model number and brand of your motherboard. Then go to the manufacturers website then look at the manual for the board to find out if you have USB 1.1 or USB 2.0. If you have USB 2.0 then download the latest drivers for your board. If you only have USB 1.1 then your only options is to buy a USB 2.0 to PCI card that will give you USB 2.0 or just stay with the USB 1.1
Posted on Oct 26, 2008
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
I have a Lexmark X1150 printer that is printing purple only.
Try the "better" or "best" print options - They give more ink - might do the trick - (beware it also prints a lot more slowly....)
I have not had that type of problem as such as both my ink slots work, but I did have purple/bluish print instead of black once - It worked for me -
Hope that helps -
I have also found that despite cartridges being new somethimes they are not as full as they should....
May 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
Scanner and copier wouldn't work
i had same problem with hp i had to reinstall it
Jan 09, 2009 | Lexmark X1150 All-In-One InkJet Printer
I have lost the setup disk,
Yes, go to:,6959,204816596_652569478_0_en,00.html
And download your software there, if the model of your printer is not listed, use search bar and type the model there.
Nov 13, 2008 | Lexmark X1150 All-In-One InkJet Printer
I have a Lexmark X1150 PrinTrio that I am attempting to connect to a new laptop without a disc; however, I cannot find this model in any of the programs. How can I find the software to download in order to...
Got to the Lexmark web site.
on top, go to "Drivers & Downloads" and click on "Driver Finder"
On the "search by model" box, type your model "X1150".
Now, select your operating system, Windows XP, Vista, etc.
Finally click on "Download Now"
When it finishes downloading, open the file and follow the instructions.
Aug 04, 2008 | Computers & Internet
I dont know how to hook up my lexmark X1150 printrio to my Dell Windows Xp
If the lexmark has a usb, use a usb cord to the Dell. If it has a centronics connector (old), U can still get a cord online. If the question is software, then uninstall the printer software using the control panel - add/remove programs, assuming it didn't work and re U R here. Leave the printer connected. Use the control panel - system - hardware - devices and uninstall the printer. Reboot. When the system detects the printer, use the printer cd to load only the driver. Try it and if ok, than U can load the printer programs.
Jun 15, 2008 | Computers & Internet
Computers & Internet Logo
280 people viewed this question
David Payne
David Payne
