Question about Pioneer DEH-P4100
Hello I installed a p4100 in my 2000 mustang, it turns on but no sound from the speakers?
    Brigadier General:
  • 6,966 Answers
Pls verify your wiring. The Pioneer DEH-P4100 uses the below speaker wiring.
whereas a typical 2000 Ford Mustang that does uses an external amplifier would be using the below wiring scheme in its two (2) connectors.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 22, 2008
  • Louie  Role
    Louie Role Mar 22, 2008
    Hi again,
    that should read as "...that does not uses an external..."
  • Louie  Role
    Additionally, if you have verified that indeed all the wires are connected as to where they are supposed to be connected, pls try:
    1. Activating Internal Speaker to ON in the DFS Alarm Function'
    2. the brown wire (or whatever color wire it is that is to be attached to a mobile phone) must not be connected to anything;
    3. try all sources, AM, FM, CD;
    4. check that none of the speaker wires is grounded.
SOURCE:
Speakers not working
if you have installed a aftermarket stereo I would check your connections sounds like you're heading metal inside of the housing somewhere had a Mustang do the same thing to me.
Feb 08, 2014 | Ford Cars & Trucks
Mustang 3 amp, no sound
first check with fender, fender.com go to amps they should have a ---Ask program-- there.
Nov 12, 2013 | Fender Mustang 3 Modeling Amplifier 100...
Hello i like to install speaker sound drivers ...
Speakers do not need any drivers!! Your sound card need drivers.
If your sound card is PCI, remove it and reinsert it to the PCI slot again and see whether your system detect the device and use the sound CD to install the drivers. (Change PCI slots if necessary and turn off the PC before changes the PCI sound card).
If your audio device is intergrated device, check the Bios to make sure the sound/audio is enable.
Note: Check the device manager first to see any audio device had been install properly.
May 20, 2010 | Computers & Internet
I Have a 97 mustang gt with the mach system in and I am trying to install a deh-p3700mp into it. I have power but no sound can you help
could be as simple as hooking up the amp turn on wire, or wrong harness, or bad amps or blown amp fuses
May 19, 2010 | Car Audio & Video
Bought a '90 Mustang GT with these speakers in the
sounds like the wires maybe crossed try this 1st fade your stereo left or right if it sounds better with one speaker playing your polarity is backwards unhook 1 of the speakers and reverse the wires hope this helps
May 11, 2010 | Boston Acoustics CX8 Car Speaker
All wires connected but no sound to sub
have you connected sub direct to rear speakers ? you need to connect direct to head unit for enough power or headunit to amp to sub dependant on wattage of the sub
May 15, 2009 | Scosche Industries Scosche 05 Mustang...
2000 mustang convertable amp problems
Are you sure the amplifiers are trashed? Have you checked the fuses? A reputable car audio shop could help for a fee of course, but it may be worth the price. It's odd that (all) the amps would malfuntion simultaniously unless someone unqualified messed with the wiring or the radio has a defective trigger wire (turns the amps on). You'll be sadly disapointed with any new radio without the factory amps, especially with the convertable ... I strongly suggest getting the amps (the factory system) working again.
Apr 17, 2009 | Metra Turbowire 70-5605
Sound still appear at speaker even when headphone was installed
Hello Again,
When you Plug in HeadPhones into the Laptop the Sound Playing should automatically Bi-Pass the Speakers and go Straight to the Headphones
-Unless there is a Faulty Input for the Speaker/ Headphone, Try Pushing in the Headphones More to see if the Speakers Turn Off
Hope this Works --P3NGYJ03
Jan 23, 2009 | Audio Players & Recorders
Amplifier installation
Since there's been no response in over a month, I guess I'll assume the problem was fixed!
Feb 19, 2008 | Kenwood KAC-X520 Car Audio Amplifier
Pioneer DEH-P4100 Logo
523 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
